주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Motorola T720c Keypad replacement or cleaning
필요한 것
  1. Motorola T720c Keypad replacement or cleaning, Antenna: 1 단계, 이미지 1개 중 1개
    • At the base of the antenna, use your fingers to unscrew the stem counterclockwise.
    • The antenna will pull out with little effort.
    댓글 쓰기
  2. Motorola T720c Keypad replacement or cleaning, Battery: 2 단계, 이미지 1개 중 1개
    • On the back of the phone, locate the tab with the down arrow.
    • Using your finger, press the tab and slide the back cover down to release it from the phone.
    댓글 쓰기
  3. Motorola T720c Keypad replacement or cleaning: 3 단계, 이미지 1개 중 1개
    • Inserting your finger in the recess at the top edge of the battery, pull the battery away from the housing to remove it.
    댓글 쓰기
  4. Motorola T720c Keypad replacement or cleaning, keypad: 4 단계, 이미지 1개 중 1개
    • Locate the three screws that secure the back battery housing to the phone.
    • Use a Torx T6 screwdriver to unscrew the screws and then remove them with your fingers.
    댓글 쓰기
  5. Motorola T720c Keypad replacement or cleaning: 5 단계, 이미지 2개 중 1개 Motorola T720c Keypad replacement or cleaning: 5 단계, 이미지 2개 중 2개
    • Using a spudger (not shown), separate by gently prying the front from the back of the phone housing.
    • Remove the back.
    댓글 쓰기
  6. Motorola T720c Keypad replacement or cleaning: 6 단계, 이미지 1개 중 1개
    • The fragile wire strip connecting the display housing to the circuit board is located on the right corner of the inner hinge.
    • In the same direction you would flip open the phone, use your finger to gently lift the circuit board from the plastic keypad.
    댓글 쓰기
  7. Motorola T720c Keypad replacement or cleaning: 7 단계, 이미지 1개 중 1개
    • While avoiding contact with the inner electronics, use the spudger to lift the plastic keypad from the phone.
    댓글 쓰기
  8. Motorola T720c Keypad replacement or cleaning: 8 단계, 이미지 2개 중 1개 Motorola T720c Keypad replacement or cleaning: 8 단계, 이미지 2개 중 2개
    • Using a lens cloth, wipe away any build-up on or between the keys.
    • Wait for the keypad to dry before reassembling.
    댓글 쓰기
결론
취소: 해당 안내서를 완성하지 않았습니다.
작성자
8다른 기여자 명과 함께
Amy
회원 가입일: 10/15/12
1 평판
안내서 4개를 작성함
University of Maine, Team 1-4, Diaz Fall 2012 University of Maine, Team 1-4, Diaz Fall 2012 회원
UMAINE-DIAZ-F12S1G4
5 회원들
안내서 12개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 2
지난 7일: 8
지난 30일: 31
전체 시간: 618
