주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Motorola V276 Battery Replacement
필요한 것
  1. Motorola V276 Battery Replacement, Battery: 1 단계, 이미지 1개 중 1개
    • Locate the silver button on the back of the phone, near the bottom.
    • Depress the silver button with one hand and slide the back cover of the phone away from the antenna.
    • The back cover should slide off easily.
    댓글 쓰기
  2. Motorola V276 Battery Replacement: 2 단계, 이미지 1개 중 1개
    • Insert a plastic spudger near one corner of the battery (preferably one furthest from the phone's antenna).
    • Gently pry the battery up and away from the phone. The battery should easily raise out of its place.
    • Now that the battery is exposed, use your fingers to remove the it from the phone.
    댓글 쓰기
  3. Motorola V276 Battery Replacement: 3 단계, 이미지 2개 중 1개 Motorola V276 Battery Replacement: 3 단계, 이미지 2개 중 2개
    • Note the metal connections on the phone, which are now exposed with the battery removed.
    • There are corresponding metal connectors on the replacement battery.
    • When you install the battery, be sure both connectors are matched up. Otherwise, your battery will be unable to supply power to your phone.
    댓글 쓰기
결론
취소: 해당 안내서를 완성하지 않았습니다.
작성자
6다른 기여자 명과 함께
Jason Kilroy
회원 가입일: 04/11/10
1 평판
안내서 3개를 작성함
Cal Poly, Team 27-96, Amido Spring 2010 Cal Poly, Team 27-96, Amido Spring 2010 회원
CPSU-AMIDO-S10S27G96
4 회원들
안내서 26개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 3
지난 7일: 10
지난 30일: 35
전체 시간: 2,046
