주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Motorola V276 Flex Cable Replacement
필요한 것
  1. Motorola V276 Flex Cable Replacement, Battery: 1 단계, 이미지 1개 중 1개
    • Locate the silver button on the back of the phone, near the bottom.
    • Depress the silver button with one hand and slide the back cover of the phone away from the antenna.
    • The back cover should slide off easily.
    댓글 쓰기
  2. Motorola V276 Flex Cable Replacement: 2 단계, 이미지 1개 중 1개
    • Insert a plastic spudger near one corner of the battery (preferably one furthest from the phone's antenna).
    • Gently pry the battery up and away from the phone. The battery should easily raise out of its place.
    • Now that the battery is exposed, use your fingers to remove the it from the phone.
    댓글 쓰기
  3. Motorola V276 Flex Cable Replacement: 3 단계, 이미지 2개 중 1개 Motorola V276 Flex Cable Replacement: 3 단계, 이미지 2개 중 2개
    • Note the metal connections on the phone, which are now exposed with the battery removed.
    • There are corresponding metal connectors on the replacement battery.
    • When you install the battery, be sure both connectors are matched up. Otherwise, your battery will be unable to supply power to your phone.
    댓글 쓰기
  4. Motorola V276 Flex Cable Replacement, Motherboard: 4 단계, 이미지 1개 중 1개
    • Use a spudger to remove the rubber plug from the upper left corner of the back of the phone.
    댓글 쓰기
  5. Motorola V276 Flex Cable Replacement: 5 단계, 이미지 1개 중 1개
    • Use a Torx T6 screwdriver to remove the 4 screws that secure the back plate of the phone.
    댓글 쓰기
  6. Motorola V276 Flex Cable Replacement: 6 단계, 이미지 3개 중 1개 Motorola V276 Flex Cable Replacement: 6 단계, 이미지 3개 중 2개 Motorola V276 Flex Cable Replacement: 6 단계, 이미지 3개 중 3개
    • Three tabs will hold the back plastic plate in.
    • To remove the back plate, pull the tabs towards the outside of the phone and lift the plate up simultaneously
    • Be careful when removing the back plate; don't put too much stress on the back plate or the plastic may snap
    댓글 쓰기
  7. Motorola V276 Flex Cable Replacement: 7 단계, 이미지 3개 중 1개 Motorola V276 Flex Cable Replacement: 7 단계, 이미지 3개 중 2개 Motorola V276 Flex Cable Replacement: 7 단계, 이미지 3개 중 3개
    • Use a spudger to remove the ribbon cable from the motherboard.
    • Be delicate while removing the ribbon cable because it is slightly fragile and it is necessary for the phone to function
    댓글 쓰기
  8. Motorola V276 Flex Cable Replacement: 8 단계, 이미지 1개 중 1개
    • Gently peel back the motherboard from the main part of the phone.
    댓글 쓰기
  9. Motorola V276 Flex Cable Replacement, Flex Cable: 9 단계, 이미지 1개 중 1개
    • Remove the keypad from the bottom half of the phone.
    댓글 쓰기
  10. Motorola V276 Flex Cable Replacement: 10 단계, 이미지 2개 중 1개 Motorola V276 Flex Cable Replacement: 10 단계, 이미지 2개 중 2개
    • Detach the bottom half of the phone by pulling out on the bottom half and pulling up on the top half.
    • A small amount of force is necessary to pull the two pieces apart, but be careful because the plastic may break.
    댓글 쓰기
  11. Motorola V276 Flex Cable Replacement: 11 단계, 이미지 2개 중 1개 Motorola V276 Flex Cable Replacement: 11 단계, 이미지 2개 중 2개
    • Use a plastic opening tool to remove the front cover of the phone.
    댓글 쓰기
  12. Motorola V276 Flex Cable Replacement: 12 단계, 이미지 2개 중 1개 Motorola V276 Flex Cable Replacement: 12 단계, 이미지 2개 중 2개
    • Remove the four screws holding in the metal cover.
    댓글 쓰기
  13. Motorola V276 Flex Cable Replacement: 13 단계, 이미지 1개 중 1개
    • Use a spudger to remove the plastic protector case around the camera.
    댓글 쓰기
  14. Motorola V276 Flex Cable Replacement: 14 단계, 이미지 1개 중 1개
    • Use a plastic opening tool to peel off the gold tape that holds the flex cable in place.
    댓글 쓰기
  15. Motorola V276 Flex Cable Replacement: 15 단계, 이미지 1개 중 1개
    • Slide the ribbon cable through the tiny slit located in the hole on the side of the frame.
    댓글 쓰기
  16. Motorola V276 Flex Cable Replacement: 16 단계, 이미지 2개 중 1개 Motorola V276 Flex Cable Replacement: 16 단계, 이미지 2개 중 2개
    • Slide the ribbon cable through the rectangular hole in the bottom half of the frame.
    댓글 쓰기
  17. Motorola V276 Flex Cable Replacement: 17 단계, 이미지 1개 중 1개
    • Remove the ribbon cable and the motherboard (still connected) from the frame of the phone.
    댓글 쓰기
  18. Motorola V276 Flex Cable Replacement: 18 단계, 이미지 2개 중 1개 Motorola V276 Flex Cable Replacement: 18 단계, 이미지 2개 중 2개
    • Use a spudger to detach the ribbon cable from the motherboard.
    댓글 쓰기
결론
취소: 해당 안내서를 완성하지 않았습니다.
작성자
4다른 기여자 명과 함께
Jonathan Cheung
회원 가입일: 04/11/10
1 평판
안내서 3개를 작성함
Cal Poly, Team 27-96, Amido Spring 2010 Cal Poly, Team 27-96, Amido Spring 2010 회원
CPSU-AMIDO-S10S27G96
4 회원들
안내서 26개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 1
지난 7일: 5
지난 30일: 43
전체 시간: 1,776
