주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Motorola V557 Rear Casing Replacement
필요한 것
  1. Motorola V557 Rear Casing Replacement, Battery: 1 단계, 이미지 3개 중 1개 Motorola V557 Rear Casing Replacement, Battery: 1 단계, 이미지 3개 중 2개 Motorola V557 Rear Casing Replacement, Battery: 1 단계, 이미지 3개 중 3개
    • First, on the back of the phone find the silver button on the top left corner of the phone.
    • Simultaneously push down the button and slide the back plate down to reveal the battery.
    댓글 쓰기
  2. Motorola V557 Rear Casing Replacement: 2 단계, 이미지 2개 중 1개 Motorola V557 Rear Casing Replacement: 2 단계, 이미지 2개 중 2개
    • Grab the lower edge of the battery at the two bottom corners.
    • Pull upward on the edges to remove the battery.
    댓글 쓰기
  3. Motorola V557 Rear Casing Replacement, SIM Card: 3 단계, 이미지 3개 중 1개 Motorola V557 Rear Casing Replacement, SIM Card: 3 단계, 이미지 3개 중 2개 Motorola V557 Rear Casing Replacement, SIM Card: 3 단계, 이미지 3개 중 3개
    • Push the metal slider towards the top of the phone until it clicks out of the original position.
    • Gently slide out and remove the SIM card.
    댓글 쓰기
  4. Motorola V557 Rear Casing Replacement, Antenna: 4 단계, 이미지 2개 중 1개 Motorola V557 Rear Casing Replacement, Antenna: 4 단계, 이미지 2개 중 2개
    • Grip the antenna and twist it counterclockwise to loosen it.
    • When it has been loosened all the way, pull gently to remove the antenna piece.
    댓글 쓰기
  5. Motorola V557 Rear Casing Replacement, Rear Casing: 5 단계, 이미지 3개 중 1개 Motorola V557 Rear Casing Replacement, Rear Casing: 5 단계, 이미지 3개 중 2개 Motorola V557 Rear Casing Replacement, Rear Casing: 5 단계, 이미지 3개 중 3개
    • Using the push pin, gently pry the top two screws of the cover off.
    • The cover in the upper left of the back plate does not need to be removed.
    댓글 쓰기
  6. Motorola V557 Rear Casing Replacement: 6 단계, 이미지 3개 중 1개 Motorola V557 Rear Casing Replacement: 6 단계, 이미지 3개 중 2개 Motorola V557 Rear Casing Replacement: 6 단계, 이미지 3개 중 3개
    • At the corners of the phone, remove all four 6.0 mm Torx screws, using your screwdriver.
    댓글 쓰기
  7. Motorola V557 Rear Casing Replacement: 7 단계, 이미지 3개 중 1개 Motorola V557 Rear Casing Replacement: 7 단계, 이미지 3개 중 2개 Motorola V557 Rear Casing Replacement: 7 단계, 이미지 3개 중 3개
    • Next, insert a spudger into the marked holes. One at a time pry away from the phone to release the internal tabs.
    • Then, separate and detach the rear casing.
    댓글 쓰기
결론
취소: 해당 안내서를 완성하지 않았습니다.
작성자
11다른 기여자 명과 함께
Alex Georges
회원 가입일: 10/02/10
40 평판
안내서 4개를 작성함
Cal Poly, Team 7-50, Amido Fall 2010 Cal Poly, Team 7-50, Amido Fall 2010 회원
CPSU-AMIDO-F10S7G50
4 회원들
안내서 36개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 1
지난 7일: 6
지난 30일: 31
전체 시간: 1,773
