주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Motorola V60s Button Key Pad Replacement
필요한 것
  1. Motorola V60s Button Key Pad Replacement, Battery: 1 단계, 이미지 3개 중 1개 Motorola V60s Button Key Pad Replacement, Battery: 1 단계, 이미지 3개 중 2개 Motorola V60s Button Key Pad Replacement, Battery: 1 단계, 이미지 3개 중 3개
    • Push in release lever towards top of phone, then use blue spudger to pry case off.
    • After case is removed from the back of the phone, you can simply use your hands to take it the rest of the way off.
    • Set cover aside in a safe location.
    댓글 쓰기
  2. Motorola V60s Button Key Pad Replacement: 2 단계, 이미지 2개 중 1개 Motorola V60s Button Key Pad Replacement: 2 단계, 이미지 2개 중 2개
    • Carefully grab battery towards bottom of phone.
    • Lift from bottom and take out of phone, set aside in a safe location.
    댓글 쓰기
  3. Motorola V60s Button Key Pad Replacement, Motherboard: 3 단계, 이미지 2개 중 1개 Motorola V60s Button Key Pad Replacement, Motherboard: 3 단계, 이미지 2개 중 2개
    • Remove the four corner screws with a T6 screwdriver.
    • The two top screws are short and silver. The two bottom screws are black and long.
    댓글 쓰기
  4. Motorola V60s Button Key Pad Replacement: 4 단계, 이미지 3개 중 1개 Motorola V60s Button Key Pad Replacement: 4 단계, 이미지 3개 중 2개 Motorola V60s Button Key Pad Replacement: 4 단계, 이미지 3개 중 3개
    • Use a spudger to gently pry off back chassis. Wedge the spudger in crevice between back panel and phone and lift.
    댓글 쓰기
  5. Motorola V60s Button Key Pad Replacement: 5 단계, 이미지 3개 중 1개 Motorola V60s Button Key Pad Replacement: 5 단계, 이미지 3개 중 2개 Motorola V60s Button Key Pad Replacement: 5 단계, 이미지 3개 중 3개
    • Starting from left side of phone, remove side buttons and place aside.
    • There are three buttons. One on each side, and the top.
    • Return phone to starting orientation when done.
    댓글 쓰기
  6. Motorola V60s Button Key Pad Replacement: 6 단계, 이미지 3개 중 1개 Motorola V60s Button Key Pad Replacement: 6 단계, 이미지 3개 중 2개 Motorola V60s Button Key Pad Replacement: 6 단계, 이미지 3개 중 3개
    • Gently remove orange ribbon cable by prying up with spudger.
    댓글 쓰기
  7. Motorola V60s Button Key Pad Replacement: 7 단계, 이미지 2개 중 1개 Motorola V60s Button Key Pad Replacement: 7 단계, 이미지 2개 중 2개
    • Use a spudger to pry up logic board by wedging in between logic board and chassis and lifting.
    • Orange ribbon cable is fragile and can be broken.
    댓글 쓰기
  8. Motorola V60s Button Key Pad Replacement, Button Key Board: 8 단계, 이미지 2개 중 1개 Motorola V60s Button Key Pad Replacement, Button Key Board: 8 단계, 이미지 2개 중 2개
    • Insert an opening tool under the button board and gently lift.
    댓글 쓰기
  9. Motorola V60s Button Key Pad Replacement, Button Key Pad: 9 단계, 이미지 2개 중 1개 Motorola V60s Button Key Pad Replacement, Button Key Pad: 9 단계, 이미지 2개 중 2개
    • Life button keypad with spudger and set aside.
    댓글 쓰기
결론
취소: 해당 안내서를 완성하지 않았습니다.
작성자
6다른 기여자 명과 함께
Eric Freeman
회원 가입일: 01/26/10
12 평판
안내서 7개를 작성함
Cal Poly, Team 8-48, Regan Winter 2010 Cal Poly, Team 8-48, Regan Winter 2010 회원
CPSU-REGAN-W10S8G48
4 회원들
안내서 20개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 2
지난 30일: 28
전체 시간: 3,310
