주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Motorola V710 Camera Replacement
필요한 것
  1. Motorola V710 Camera Replacement, Screen: 1 단계, 이미지 3개 중 1개 Motorola V710 Camera Replacement, Screen: 1 단계, 이미지 3개 중 2개 Motorola V710 Camera Replacement, Screen: 1 단계, 이미지 3개 중 3개
    • Insert the spudger between the gray and black plates of the screen casing.
    • Using a twist and pry motion work your way around the phone slowly prying the two plates apart.
    • Note: this part of the phone is glued and will require re-gluing to return the phone to its original state.
    댓글 쓰기
  2. Motorola V710 Camera Replacement: 2 단계, 이미지 2개 중 1개 Motorola V710 Camera Replacement: 2 단계, 이미지 2개 중 2개
    • If you look at the side of the now exposed screen there should be a metal casing held onto the phone by two tabs.
    • Insert the spudger underneath one of the corners of the metal and bend it out enough to slip it over the tabs.
    • This metal is reasonably resistant to bending and will likely require a good deal of force to get it off the phone.
    댓글 쓰기
  3. Motorola V710 Camera Replacement: 3 단계, 이미지 2개 중 1개 Motorola V710 Camera Replacement: 3 단계, 이미지 2개 중 2개
    • Orient the phone so that the main screen is facing upward.
    • Locate the hinge casing, a dark gray piece that covers the hinge.
    • Insert the spudger under one of the top corners of this piece and using a twist and pry motion remove from the phone.
    댓글 쓰기
  4. Motorola V710 Camera Replacement: 4 단계, 이미지 2개 중 1개 Motorola V710 Camera Replacement: 4 단계, 이미지 2개 중 2개
    • Use the spudger to pry upward and remove the plug that connects the screen to the main body of the phone.
    댓글 쓰기
  5. Motorola V710 Camera Replacement: 5 단계, 이미지 2개 중 1개 Motorola V710 Camera Replacement: 5 단계, 이미지 2개 중 2개
    • Insert the spudger under the screen and pry the screen forward.
    • Remove the plug on the back of the screen that connects it to the camera.
    댓글 쓰기
  6. Motorola V710 Camera Replacement: 6 단계, 이미지 2개 중 1개 Motorola V710 Camera Replacement: 6 단계, 이미지 2개 중 2개
    • Use the spudger to remove the screen.
    댓글 쓰기
  7. Motorola V710 Camera Replacement, Camera: 7 단계, 이미지 3개 중 1개 Motorola V710 Camera Replacement, Camera: 7 단계, 이미지 3개 중 2개 Motorola V710 Camera Replacement, Camera: 7 단계, 이미지 3개 중 3개
    • Use the spudger to remove the camera module.
    • Note: The camera has an adhesive holding it in place, so a slight force is necessary to remove it.
    댓글 쓰기
결론
취소: 해당 안내서를 완성하지 않았습니다.
작성자
4다른 기여자 명과 함께
Karl Sanders
회원 가입일: 01/26/10
8 평판
안내서 7개를 작성함
Cal Poly, Team 8-49, Regan Winter 2010 Cal Poly, Team 8-49, Regan Winter 2010 회원
CPSU-REGAN-W10S8G49
5 회원들
안내서 24개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 8
지난 30일: 34
전체 시간: 1,941
