주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Motorola Xoom Wifi Display Assembly Replacement
필요한 것
    1. Motorola Xoom Wifi Display Assembly Replacement, Back Cover Disassembly: 1 단계, 이미지 2개 중 1개 Motorola Xoom Wifi Display Assembly Replacement, Back Cover Disassembly: 1 단계, 이미지 2개 중 2개
      • There are two 6.6 mm screws that hold ports into place as well as the back panel. Remove these with a T5 Torx screwdriver.
      댓글 쓰기
    2. Motorola Xoom Wifi Display Assembly Replacement: 2 단계, 이미지 2개 중 1개 Motorola Xoom Wifi Display Assembly Replacement: 2 단계, 이미지 2개 중 2개
      • Apply light pressure with hand and slide the back plate till it stops in this position.
      • There is a flex clip on both sides that need to be pushed down in order for the plate to slide off completely. Use a plastic opening tool to release the flex clips. They are located under the back cover near the sides.
      • As soon as the clips are released the back should slide off.
      댓글 쓰기
    3. Motorola Xoom Wifi Display Assembly Replacement: 3 단계, 이미지 3개 중 1개 Motorola Xoom Wifi Display Assembly Replacement: 3 단계, 이미지 3개 중 2개 Motorola Xoom Wifi Display Assembly Replacement: 3 단계, 이미지 3개 중 3개
      • Remove last two 4.2 mm screws from the remaining back piece with a T5 Torx screwdriver.
      • Once both screws are taken out, lift the rest of the backing out of the way.
      댓글 쓰기
    1. Motorola Xoom Wifi Display Assembly Replacement, Battery: 4 단계, 이미지 2개 중 1개 Motorola Xoom Wifi Display Assembly Replacement, Battery: 4 단계, 이미지 2개 중 2개
      • Remove the two battery leads with a T-5 Torx screwdriver.
      • Grab the red and black wires with your fingers and gently lift to disconnect black wire connector from the motherboard.
      댓글 쓰기
    2. Motorola Xoom Wifi Display Assembly Replacement: 5 단계, 이미지 2개 중 1개 Motorola Xoom Wifi Display Assembly Replacement: 5 단계, 이미지 2개 중 2개
      • All that holds the battery in are twelve screws. Remove them with a T-6 Torx screwdriver.
      • The battery should lift out easily.
      댓글 쓰기
    1. Motorola Xoom Wifi Display Assembly Replacement, Speakers: 6 단계, 이미지 2개 중 1개 Motorola Xoom Wifi Display Assembly Replacement, Speakers: 6 단계, 이미지 2개 중 2개
      • Use a plastic opening tool to pop out the speaker. Make sure to carefully pull off the wire as well.
      • Replace speaker if necessary.
      댓글 쓰기
    1. Motorola Xoom Wifi Display Assembly Replacement, Back-Facing Camera: 7 단계, 이미지 2개 중 1개 Motorola Xoom Wifi Display Assembly Replacement, Back-Facing Camera: 7 단계, 이미지 2개 중 2개
      • Use a spudger or a fine tip to lift the black tab to a vertical position.
      • A spudger is needed to remove the plastic border around the camera.
      댓글 쓰기
    2. Motorola Xoom Wifi Display Assembly Replacement: 8 단계, 이미지 2개 중 1개 Motorola Xoom Wifi Display Assembly Replacement: 8 단계, 이미지 2개 중 2개
      • When lifting the camera out, be sure to pull the orange ribbon cable as well.
      댓글 쓰기
    1. Motorola Xoom Wifi Display Assembly Replacement, Motherboard: 9 단계, 이미지 3개 중 1개 Motorola Xoom Wifi Display Assembly Replacement, Motherboard: 9 단계, 이미지 3개 중 2개 Motorola Xoom Wifi Display Assembly Replacement, Motherboard: 9 단계, 이미지 3개 중 3개
      • Take a plastic opening tool and carefully pry off the touch screen controller connection.
      • Be careful with the black cover under the connection.
      댓글 쓰기
    2. Motorola Xoom Wifi Display Assembly Replacement: 10 단계, 이미지 3개 중 1개 Motorola Xoom Wifi Display Assembly Replacement: 10 단계, 이미지 3개 중 2개 Motorola Xoom Wifi Display Assembly Replacement: 10 단계, 이미지 3개 중 3개
      • There are two relay wires that must be disconnected.
      • Pull both relay wires out of their connection ports.
      • Make sure to flip up the small black tab before you pull out the wire.
      댓글 쓰기
    3. Motorola Xoom Wifi Display Assembly Replacement: 11 단계, 이미지 2개 중 1개 Motorola Xoom Wifi Display Assembly Replacement: 11 단계, 이미지 2개 중 2개
      • Using a plastic opener, lift the metal bar clasping the wire harness to the motherboard.
      댓글 쓰기
    4. Motorola Xoom Wifi Display Assembly Replacement: 12 단계, 이미지 3개 중 1개 Motorola Xoom Wifi Display Assembly Replacement: 12 단계, 이미지 3개 중 2개 Motorola Xoom Wifi Display Assembly Replacement: 12 단계, 이미지 3개 중 3개
      • There are eight 3.5mm screws that hold the motherboard in. Use a T-5 Torx screwdriver to take the screws loose. These screws are outlined in a gold color on the motherboard.
      • Two gold colored screws with brackets are located in the orange circles. A T-5 Torx screwdriver is needed to take these 3.1mm screws.
      • Motherboard should lift out easily and completely.
      댓글 쓰기
    1. Motorola Xoom Wifi Display Assembly Replacement, Display Assembly: 13 단계, 이미지 2개 중 1개 Motorola Xoom Wifi Display Assembly Replacement, Display Assembly: 13 단계, 이미지 2개 중 2개
      • Using the T-6 Torx screwdriver, unscrew the 17 4mm screws along the edge of the screen frame.
      댓글 쓰기
    2. Motorola Xoom Wifi Display Assembly Replacement: 14 단계, 이미지 2개 중 1개 Motorola Xoom Wifi Display Assembly Replacement: 14 단계, 이미지 2개 중 2개
      • Take the small plastic opening tool and separate the front glass from the screen frame.
      • Unfold the glass and the frame flat on the table.
      댓글 쓰기
    3. Motorola Xoom Wifi Display Assembly Replacement: 15 단계, 이미지 3개 중 1개 Motorola Xoom Wifi Display Assembly Replacement: 15 단계, 이미지 3개 중 2개 Motorola Xoom Wifi Display Assembly Replacement: 15 단계, 이미지 3개 중 3개
      • Using the T-5 Torx screwdriver, unscrew the 12 4.1mm screws along the edge of the screen.
      • Pull ribbon wire out of slot in the frame to pull the screen off of the frame.
      댓글 쓰기
결론
취소: 해당 안내서를 완성하지 않았습니다.
다른 5명이 해당 안내서를 완성하였습니다.
작성자
4다른 기여자 명과 함께
Andrew Mercier
회원 가입일: 04/14/14
532 평판
안내서 3개를 작성함
Cal Poly, Team 3-39, Maness Spring 2014 Cal Poly, Team 3-39, Maness Spring 2014 회원
CPSU-MANESS-S14S3G39
4 회원들
안내서 16개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 8
지난 30일: 34
전체 시간: 2,025
