주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Motorola i710 Keypad Cover Replacement
필요한 것
  1. Motorola i710 Keypad Cover Replacement, Battery Cover: 1 단계, 이미지 2개 중 1개 Motorola i710 Keypad Cover Replacement, Battery Cover: 1 단계, 이미지 2개 중 2개
    • Slide the cover release button towards the bottom of the phone
    • Once the battery cover pops up, slide the cover towards the top of the phone and lift up.
    댓글 쓰기
  2. Motorola i710 Keypad Cover Replacement, Battery: 2 단계, 이미지 1개 중 1개
    • Push the battery towards the top of the phone and lift up.
    댓글 쓰기
  3. Motorola i710 Keypad Cover Replacement, Back Casing: 3 단계, 이미지 3개 중 1개 Motorola i710 Keypad Cover Replacement, Back Casing: 3 단계, 이미지 3개 중 2개 Motorola i710 Keypad Cover Replacement, Back Casing: 3 단계, 이미지 3개 중 3개
    • With a T5 screwdriver, unscrew the four T5 sized screws that hold the case back cover onto the rest of the case.
    • Remove the plastic case back cover by gently pulling it away from the body of the phone, starting at one edge and working your way down to the other.
    댓글 쓰기
  4. Motorola i710 Keypad Cover Replacement, Motherboard: 4 단계, 이미지 3개 중 1개 Motorola i710 Keypad Cover Replacement, Motherboard: 4 단계, 이미지 3개 중 2개 Motorola i710 Keypad Cover Replacement, Motherboard: 4 단계, 이미지 3개 중 3개
    • Lift the motherboard away from the case of the phone, being careful not to break the wire that goes up into the hinge.
    • Peel the motherboard off of the keypad. The two pieces are glued together and separate without much effort.
    • The motherboard should now be completely disconnected from the phone.
    댓글 쓰기
  5. Motorola i710 Keypad Cover Replacement, Keypad Sensor: 5 단계, 이미지 2개 중 1개 Motorola i710 Keypad Cover Replacement, Keypad Sensor: 5 단계, 이미지 2개 중 2개
    • Once the motherboard has been removed from the keypad, the keypad sensor can be detached from the phone at the hinge.
    • Gently pry off the cable connecting the keypad sensor. The keypad sensor should now be completely separated from the phone.
    댓글 쓰기
  6. Motorola i710 Keypad Cover Replacement, Keypad Cover: 6 단계, 이미지 2개 중 1개 Motorola i710 Keypad Cover Replacement, Keypad Cover: 6 단계, 이미지 2개 중 2개
    • Once the keypad has been removed, the keypad cover can be easily peeled back from the front phone cover molding.
    • Care must be taken when inserting a new keypad cover. The keypad cover will have to be lined up to the corresponding holes of the phone casing.
    댓글 쓰기
결론
취소: 해당 안내서를 완성하지 않았습니다.
작성자
6다른 기여자 명과 함께
Katelyn
회원 가입일: 10/22/12
1 평판
안내서 2개를 작성함
Clemson, Team 14-2, Benson Fall 2012 Clemson, Team 14-2, Benson Fall 2012 회원
CLEM-BENSON-F12S14G2
4 회원들
안내서 29개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 1
지난 7일: 8
지난 30일: 37
전체 시간: 732
