주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Motorola i710 LCD Screen Replacement
필요한 것
  1. Motorola i710 LCD Screen Replacement, Battery Cover: 1 단계, 이미지 2개 중 1개 Motorola i710 LCD Screen Replacement, Battery Cover: 1 단계, 이미지 2개 중 2개
    • Slide the cover release button towards the bottom of the phone
    • Once the battery cover pops up, slide the cover towards the top of the phone and lift up.
    댓글 쓰기
  2. Motorola i710 LCD Screen Replacement, Battery: 2 단계, 이미지 1개 중 1개
    • Push the battery towards the top of the phone and lift up.
    댓글 쓰기
  3. Motorola i710 LCD Screen Replacement, LCD Screen Cover: 3 단계, 이미지 3개 중 1개 Motorola i710 LCD Screen Replacement, LCD Screen Cover: 3 단계, 이미지 3개 중 2개 Motorola i710 LCD Screen Replacement, LCD Screen Cover: 3 단계, 이미지 3개 중 3개
    • Although the lower half of the phone in these images has been disassembled, it is not necessary for removing the LCD screen.
    • With the help of plastic opening tools, remove the i710 name plate and Motorola logo from the backside of the phone.
    • The four screws holding the upper half of the phone together should now be visible.
    댓글 쓰기
  4. Motorola i710 LCD Screen Replacement: 4 단계, 이미지 2개 중 1개 Motorola i710 LCD Screen Replacement: 4 단계, 이미지 2개 중 2개
    • With a H1.5 screwdriver, unscrew the four H1.5 sized screws from the back of the phone.
    • Flip the phone onto its back and, with the help of a plastic opening tool, remove the metal speaker cover that is above the LCD screen.
    댓글 쓰기
  5. Motorola i710 LCD Screen Replacement: 5 단계, 이미지 3개 중 1개 Motorola i710 LCD Screen Replacement: 5 단계, 이미지 3개 중 2개 Motorola i710 LCD Screen Replacement: 5 단계, 이미지 3개 중 3개
    • Slide a plastic opening tool along the edge of the LCD Screen Cover to separate the cover from the phone casing. Apply a small amount of force towards the cover if necessary.
    • The LCD screen should now be completely separated from the phone.
    댓글 쓰기
  6. Motorola i710 LCD Screen Replacement, LCD Screen: 6 단계, 이미지 3개 중 1개 Motorola i710 LCD Screen Replacement, LCD Screen: 6 단계, 이미지 3개 중 2개 Motorola i710 LCD Screen Replacement, LCD Screen: 6 단계, 이미지 3개 중 3개
    • Use a spudger to detach the ribbon cable connecting the the LCD screen to the rest of the phone.
    • The TFT LCD screen will now lift out from the phone casing.
    • Be careful not to break the speaker's ribbon cable that sits behind the LCD Screen.
    댓글 쓰기
결론
취소: 해당 안내서를 완성하지 않았습니다.
다른 한 분이 해당 안내서를 완성하였습니다.
작성자
8다른 기여자 명과 함께
Carson Meena
회원 가입일: 10/22/12
16 평판
안내서 5개를 작성함
Clemson, Team 14-2, Benson Fall 2012 Clemson, Team 14-2, Benson Fall 2012 회원
CLEM-BENSON-F12S14G2
4 회원들
안내서 29개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 6
지난 30일: 33
전체 시간: 770
