주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Motorola i886 Main Keyboard Replacement
필요한 것
  1. Motorola i886 Main Keyboard Replacement, Back Cover: 1 단계, 이미지 2개 중 1개 Motorola i886 Main Keyboard Replacement, Back Cover: 1 단계, 이미지 2개 중 2개
    • Undo the headphone jack and USB port cover with your fingertip. Place your middle finger in the indent on the upper left side of the back of the phone.
    댓글 쓰기
  2. Motorola i886 Main Keyboard Replacement, Open: 2 단계, 이미지 1개 중 1개
    • Pull back until cover is removed. Place cover aside.
    댓글 쓰기
  3. Motorola i886 Main Keyboard Replacement, Battery: 3 단계, 이미지 1개 중 1개
    • Locate battery and use your index finger to grasp the upper left side of the battery and pull back to remove. Set battery aside.
    댓글 쓰기
  4. Motorola i886 Main Keyboard Replacement, SIM Card: 4 단계, 이미지 1개 중 1개
    • Locate and use your thumb to slide the SIM card to the right until it is removed and set it aside.
    댓글 쓰기
  5. Motorola i886 Main Keyboard Replacement, Screw Removal: 5 단계, 이미지 2개 중 1개 Motorola i886 Main Keyboard Replacement, Screw Removal: 5 단계, 이미지 2개 중 2개
    • Remove eight black .4 centimeter screws on the top, bottom, and sides of the phone with a T5 Torx screwdriver by inserting it into the screws and turning it to the left. Set screws aside.
    댓글 쓰기
  6. Motorola i886 Main Keyboard Replacement, Separating: 6 단계, 이미지 1개 중 1개
    • Loosen four fastener pieces on the side and bottom with a plastic opening tool to pry them backwards.
    • Insert the plastic opening tool between the loosened casing and the rest of the phone and pry the two pieces apart to remove the casing.
    댓글 쓰기
  7. Motorola i886 Main Keyboard Replacement: 7 단계, 이미지 1개 중 1개
    • Remove the .3 centimeter silver screw with the T5 Torx screwdriver.
    • Use your fingertips to lift up the circuit board and lay it on the side of the phone. Note that the two pieces are attached by a gold and black strip.
    댓글 쓰기
  8. Motorola i886 Main Keyboard Replacement, Keyboard Removal: 8 단계, 이미지 1개 중 1개
    • Locate and grip the black, white, and blue keyboard layer with your fingernail, lift up to remove it.
    댓글 쓰기
  9. Motorola i886 Main Keyboard Replacement, Disconnect: 9 단계, 이미지 1개 중 1개
    • Disconnect piece connecting the two parts of the phone by using your index finger and thumb to pry them apart, you will hear a soft click.
    • Set aside the part of the phone without the strip.
    댓글 쓰기
  10. Motorola i886 Main Keyboard Replacement: 10 단계, 이미지 3개 중 1개 Motorola i886 Main Keyboard Replacement: 10 단계, 이미지 3개 중 2개 Motorola i886 Main Keyboard Replacement: 10 단계, 이미지 3개 중 3개
    • Remove the loose volume, speaker, and camera buttons.
    • Remove four silver .2 centimeter screws above and below the gold and black strip with a T4 Torx screwdriver.
    • Separate the two parts of the phone by holding one side in each hand and pulling them apart. Set the part that held the slide-out keyboard aside.
    댓글 쓰기
  11. Motorola i886 Main Keyboard Replacement, Screws: 11 단계, 이미지 3개 중 1개 Motorola i886 Main Keyboard Replacement, Screws: 11 단계, 이미지 3개 중 2개 Motorola i886 Main Keyboard Replacement, Screws: 11 단계, 이미지 3개 중 3개
    이 단계에 사용된 도구:
    • Remove six silver .3 centimeter screws from the top, bottom, and sides with the T4 Torx screwdriver.
    • One silver screw will be hidden by the sliding mechanism. Once you have removed the screw visible on one side, slide the mechanism over to reveal the other one.
    • The four screws on the top and bottom may not be visible. If your phone is new or has not been taken apart before, the four screw tops will be hidden by little circular stickers. These can be peeled off with tweezers.
    댓글 쓰기
  12. Motorola i886 Main Keyboard Replacement: 12 단계, 이미지 1개 중 1개
    • Insert the flat end of a Spudger in between these two pieces of the phone and move it along the sides to loosen and pry apart.
    댓글 쓰기
  13. Motorola i886 Main Keyboard Replacement: 13 단계, 이미지 1개 중 1개
    • There will be a short, wide, black strip connecting the two parts. Separate in the same manner as the black and gold strip. Set aside the piece with the strip attached.
    댓글 쓰기
  14. Motorola i886 Main Keyboard Replacement, Screen: 14 단계, 이미지 2개 중 1개 Motorola i886 Main Keyboard Replacement, Screen: 14 단계, 이미지 2개 중 2개
    • Peel back the yellow tape on the side of the screen using tweezers or your fingernails. Lift away screen and board.
    댓글 쓰기
  15. Motorola i886 Main Keyboard Replacement, Remove Keyboard: 15 단계, 이미지 1개 중 1개
    • Remove keyboard by lifting it out with your fingertips.
    댓글 쓰기
결론
취소: 해당 안내서를 완성하지 않았습니다.
작성자
2다른 기여자 명과 함께
Felicita Correa
회원 가입일: 09/03/14
418 평판
안내서 4개를 작성함
USF Sarasota-Manatee, Team 1-2, Stewart Fall 2014 USF Sarasota-Manatee, Team 1-2, Stewart Fall 2014 회원
USFSM-STEWART-F14S1G2
3 회원들
안내서 17개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 1
지난 30일: 30
전체 시간: 416
