주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Mpow 059 Battery Replacement
필요한 것
    1. Mpow 059 Battery  Replacement, Ear Cushion: 1 단계, 이미지 2개 중 1개 Mpow 059 Battery  Replacement, Ear Cushion: 1 단계, 이미지 2개 중 2개
      • Place the iFixit opening tool between the soft ear cushion and the hard plastic of the speaker.
      • Pry the soft ear cushion away from the hard plastic using a moderate amount of pressure.
      • There is adhesive holding the ear cushion to the speaker so it may take a little patience to remove.
      • Applying too much pressure can damage ear cushion.
      댓글 쓰기
    2. Mpow 059 Battery  Replacement: 2 단계, 이미지 1개 중 1개
      • Remove the ear cushion away from the speaker to completely detach it from the headphones.
      댓글 쓰기
    1. Mpow 059 Battery  Replacement, Battery: 3 단계, 이미지 2개 중 1개 Mpow 059 Battery  Replacement, Battery: 3 단계, 이미지 2개 중 2개
      • Use the Phillips #1 screwdriver to remove the six screws holding the red plastic cover in place.
      • Carefully peel the plastic cover off the left cup to reveal the ear cup's internal components.
      • There is some adhesive holding the red cover down so be careful as you remove it so it doesn't break or crack.
      댓글 쓰기
    2. Mpow 059 Battery  Replacement: 4 단계, 이미지 1개 중 1개
      • Use the JIS J00 screwdriver to remove the 3 screws that secure the black cover.
      댓글 쓰기
    3. Mpow 059 Battery  Replacement: 5 단계, 이미지 1개 중 1개
      • Remove the black cover to reveal the battery. The battery is attached to the back of the black cover.
      • The plastic cover of the headphones is connected to the battery housing by a wire connector. Be careful not to harm this cable by pulling the cap too hard during disassembly.
      • Undo the cable and remove the battery.
      댓글 쓰기
결론
취소: 해당 안내서를 완성하지 않았습니다.
다른 7명이 해당 안내서를 완성하였습니다.
작성자
3다른 기여자 명과 함께
Danielle Furtado
회원 가입일: 03/25/22
511 평판
안내서 2개를 작성함
UMass Dartmouth, Team E-1, Gurgel Spring 2022 UMass Dartmouth, Team E-1, Gurgel Spring 2022 회원
UMASSD-GURGEL-S22SEG1
3 회원들
안내서 8개를 작성함
8가이드 댓글
Hello
What kind of glue should I use to put new pad?
Martin Dromigny - 답글 공유
What is the part number for the replacement battery? Where can I find one?
hdm_1@comcast.net - 답글 공유
Battery is a 503030 3.7v 420mAh
Mark Jobe - 답글 공유
First, you need to pry the piece behind the R headphone, which is itself adhered. THEN you need to pry the battery off of the backing.
And finally, you can realize you did all of this for nothing if you don't know how to solder. The battery cables are soldered onto the chip, making it impossible to replace without soldering in the replacement wires.
biggles1701 bob - 답글 공유
This is good to know. I was thinking there was something missing as to how the battery is connected. While I'd like to save my headphones from the landfill, it looks like a case of planned obsolescence. Guess I'll be hunting for new headphones with better repair-ability
Nell - 답글 공유
댓글 쓰기
조회 통계:
지난 24시간: 5
지난 7일: 19
지난 30일: 92
전체 시간: 8,437
