주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Mpow MPBH063 Battery Replacement
필요한 것
  1. Mpow MPBH063 Battery Replacement, Battery: 1 단계, 이미지 3개 중 1개 Mpow MPBH063 Battery Replacement, Battery: 1 단계, 이미지 3개 중 2개 Mpow MPBH063 Battery Replacement, Battery: 1 단계, 이미지 3개 중 3개
    • Remove four Hex 10 mm screws from the outer speaker cover displaying the speaker's serial number indicated by the red circle.
    • Carefully insert the spudger tool into one of the holes in the cover to pry open the outer cover of the speaker.
    댓글 쓰기
  2. Mpow MPBH063 Battery Replacement: 2 단계, 이미지 1개 중 1개
    이 단계에 사용된 도구:
    • Remove four JIS J00 12mm screws.
    • Remove the inner speaker cover with the precision tweezers and a spudger if needed.
    댓글 쓰기
  3. Mpow MPBH063 Battery Replacement: 3 단계, 이미지 1개 중 1개
    • Carefully detach the battery from the adhesive securing the battery to the inner wall of the speaker.
    • Use the iFixit Adhesive Remover as directed to remove the battery from the inner wall of the speaker.
    • Detach the battery from the inner wall without detaching the wires connecting the battery to the motherboard.
    댓글 쓰기
  4. Mpow MPBH063 Battery Replacement: 4 단계, 이미지 1개 중 1개
    • Hold down the small lever on the white, plastic plug attached to the battery wires, and detach the wires from the white, plastic plug outlet on the motherboard.
    댓글 쓰기
결론
To insert a new replacement battery and reassemble your device, follow these instructions in reverse order.
취소: 해당 안내서를 완성하지 않았습니다.
작성자
4다른 기여자 명과 함께
Lianna Cook
회원 가입일: 10/09/18
272 평판
안내서 2개를 작성함
Sam Houston State, Team S15-G5, Blackburne Fall 2018 Sam Houston State, Team S15-G5, Blackburne Fall 2018 회원
SHSU-BLACKBURNE-F18S15G5
3 회원들
안내서 5개를 작성함
2가이드 댓글
Where can I find a replacement battery for this speaker?
Sean DuBois - 답글 공유
I’ve owned this speaker for ages and have never been able to use it to charge anything. Can someone tell me what sequence of button I have to press to get it to work as a power bank?
RJ En - 답글 공유
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 3
지난 30일: 28
전체 시간: 4,781
