주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Mr. Coffee TF6 Internal Water Tubes Replacement
필요한 것
    1. Mr. Coffee TF6 Internal Water Tubes Replacement, Bottom Cover: 1 단계, 이미지 1개 중 1개
      • Facing the bottom of the TF6, carefully pull the two rubber feet out with your hands.
      댓글 쓰기
    2. Mr. Coffee TF6 Internal Water Tubes Replacement: 2 단계, 이미지 2개 중 1개 Mr. Coffee TF6 Internal Water Tubes Replacement: 2 단계, 이미지 2개 중 2개
      • Using a Phillips #1 screwdriver, remove the six 11mm Phillips screws that are holding the bottom cover in place.
      댓글 쓰기
    3. Mr. Coffee TF6 Internal Water Tubes Replacement: 3 단계, 이미지 1개 중 1개
      • Gently lift the bottom cover, detaching it from the main body of the TF6.
      댓글 쓰기
    1. Mr. Coffee TF6 Internal Water Tubes Replacement, Internal Water Tubes: 4 단계, 이미지 1개 중 1개
      • Using your fingers, gently pinch and detach the two metal clips that secure the silicone tubing to the metal tubing on the TF6.
      댓글 쓰기
    2. Mr. Coffee TF6 Internal Water Tubes Replacement: 5 단계, 이미지 1개 중 1개
      • Carefully pull the silicon tubing off of the metal tubing.
      댓글 쓰기
    3. Mr. Coffee TF6 Internal Water Tubes Replacement: 6 단계, 이미지 1개 중 1개
      • Using a Phillips #1 screwdriver, remove the three 13mm Phillips screws that hold the lower and upper assemblies together.
      댓글 쓰기
    4. Mr. Coffee TF6 Internal Water Tubes Replacement: 7 단계, 이미지 1개 중 1개
      • Gripping the lower assembly with one hand and the upper assembly with the other, gently pull the assemblies apart.
      • If all screws have been removed and the tubes have been detached, the assemblies should separate easily.
      댓글 쓰기
    5. Mr. Coffee TF6 Internal Water Tubes Replacement: 8 단계, 이미지 1개 중 1개
      • Using your fingers, gently pinch and detach the two metal clips that secure the silicone tubing to the plastic tubes on the upper assembly.
      댓글 쓰기
    6. Mr. Coffee TF6 Internal Water Tubes Replacement: 9 단계, 이미지 1개 중 1개
      • Carefully pull the silicon tubing off of the plastic tubing on the upper assembly.
      댓글 쓰기
결론
취소: 해당 안내서를 완성하지 않았습니다.
다른 한 분이 해당 안내서를 완성하였습니다.
작성자
3다른 기여자 명과 함께
Jordan
회원 가입일: 01/31/14
204 평판
안내서 2개를 작성함
Cal Poly, Team 13-18, Regan Winter 2014 Cal Poly, Team 13-18, Regan Winter 2014 회원
CPSU-REGAN-W14S13G18
4 회원들
안내서 15개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 2
지난 7일: 12
지난 30일: 49
전체 시간: 2,238
