주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Munchkinz LCD Assembly
필요한 것
    1. Munchkinz LCD Assembly, Opening Device: 1 단계, 이미지 1개 중 1개
      • Insert spudger into the USB Micro slot and pry the case apart.
      • Be careful not to go too deep and bend the prong inside the Micro USB port.
      댓글 쓰기
    2. Munchkinz LCD Assembly, Pry Device Apart: 2 단계, 이미지 2개 중 1개 Munchkinz LCD Assembly, Pry Device Apart: 2 단계, 이미지 2개 중 2개
      • Slide the wide plastic opening tool across the seem, separating it if you can't pry the device open using just the spudger.
      • Gently separate the case so none of the cords inside are disconnected
      댓글 쓰기
    3. Munchkinz LCD Assembly, Separated Device: 3 단계, 이미지 1개 중 1개
      • After prying the device apart, it should look like this.
      댓글 쓰기
    1. Munchkinz LCD Assembly, Remove Speaker: 4 단계, 이미지 1개 중 1개
      • Use the plastic opening tool to remove the speaker from the casing.
      댓글 쓰기
    2. Munchkinz LCD Assembly, Pry Camera: 5 단계, 이미지 1개 중 1개
      • Use the slim plastic opening tool to pry the camera from its position.
      댓글 쓰기
    3. Munchkinz LCD Assembly, Unscrew Volume Module: 6 단계, 이미지 2개 중 1개 Munchkinz LCD Assembly, Unscrew Volume Module: 6 단계, 이미지 2개 중 2개
      • Unscrew the two screws that hold the volume module to the casing.
      댓글 쓰기
    4. Munchkinz LCD Assembly, Pry Battery: 7 단계, 이미지 1개 중 1개
      • Use the plastic opening tool to slowly pry each side of the battery up.
      • Be careful not to bend the battery too much.
      댓글 쓰기
    5. Munchkinz LCD Assembly, Remove Ribbons: 8 단계, 이미지 1개 중 1개
      • Remove the two highlighted ribbons from the motherboard.
      댓글 쓰기
    6. Munchkinz LCD Assembly, Remove Screws: 9 단계, 이미지 1개 중 1개
      • Use the screw driver to remove the highlighted screws.
      댓글 쓰기
    7. Munchkinz LCD Assembly, Remove Hidden Screw: 10 단계, 이미지 1개 중 1개
      • Use the plastic opening tool to hold the camera ribbon back.
      • Unscrew the screw under ribbon with the screw driver.
      댓글 쓰기
    8. Munchkinz LCD Assembly, Remove Motherboard: 11 단계, 이미지 1개 중 1개
      • Remove the motherboard from the casing.
      댓글 쓰기
    9. Munchkinz LCD Assembly, Pry Up Screen: 12 단계, 이미지 3개 중 1개 Munchkinz LCD Assembly, Pry Up Screen: 12 단계, 이미지 3개 중 2개 Munchkinz LCD Assembly, Pry Up Screen: 12 단계, 이미지 3개 중 3개
      • Oriented the device so the battery is closest to the user.
      • Use the plastic opening tool to pry the clips up to release LCD screen.
      • Gently lift the northern end of the screen and slide it out horizontally.
      댓글 쓰기
    10. Munchkinz LCD Assembly, Solder LCD Wires: 13 단계, 이미지 1개 중 1개
      • Unsolder the black and red LCD wires.
      댓글 쓰기
결론
취소: 해당 안내서를 완성하지 않았습니다.
다른 한 분이 해당 안내서를 완성하였습니다.
작성자
3다른 기여자 명과 함께
David Wood
회원 가입일: 02/05/15
440 평판
안내서 4개를 작성함
UW Tacoma, Team 3-6, Rose Winter 2015 UW Tacoma, Team 3-6, Rose Winter 2015 회원
UWT-ROSE-W15S3G6
3 회원들
안내서 14개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 1
지난 7일: 4
지난 30일: 24
전체 시간: 651
