주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Munchkinz Motherboard Replacement
필요한 것
  1. Munchkinz Motherboard Replacement, Opening Device: 1 단계, 이미지 1개 중 1개
    • Insert spudger into the USB Micro slot and pry the case apart.
    • Be careful not to go too deep and bend the prong inside the Micro USB port.
    댓글 쓰기
  2. Munchkinz Motherboard Replacement, Pry Device Apart: 2 단계, 이미지 2개 중 1개 Munchkinz Motherboard Replacement, Pry Device Apart: 2 단계, 이미지 2개 중 2개
    • Slide the wide plastic opening tool across the seem, separating it if you can't pry the device open using just the spudger.
    • Gently separate the case so none of the cords inside are disconnected
    댓글 쓰기
  3. Munchkinz Motherboard Replacement, Separated Device: 3 단계, 이미지 1개 중 1개
    • After prying the device apart, it should look like this.
    댓글 쓰기
  4. Munchkinz Motherboard Replacement, Pry Camera: 4 단계, 이미지 1개 중 1개
    • Use the slim plastic opening tool to pry the camera from its initial position.
    댓글 쓰기
  5. Munchkinz Motherboard Replacement, Disconnect Ribbon: 5 단계, 이미지 1개 중 1개
    이 단계에 사용된 도구:
    • Use the precision tweezers to gently disconnect the camera ribbon that is connected to the motherboard.
    댓글 쓰기
  6. Munchkinz Motherboard Replacement, Pry Speaker: 6 단계, 이미지 2개 중 1개 Munchkinz Motherboard Replacement, Pry Speaker: 6 단계, 이미지 2개 중 2개
    • Use the slim plastic opening tool to remove the speaker from its position on the case.
    댓글 쓰기
  7. Munchkinz Motherboard Replacement, Locate Wires: 7 단계, 이미지 1개 중 1개
    • Locate the red and black wires that connect the speaker to the motherboard.
    댓글 쓰기
  8. Munchkinz Motherboard Replacement, Solder Wires: 8 단계, 이미지 1개 중 1개
    • Un-solder the red and black speaker wires that are connected to the motherboard
    댓글 쓰기
  9. Munchkinz Motherboard Replacement, Volume Button: 9 단계, 이미지 1개 중 1개
    • Remove the plastic volume button.
    댓글 쓰기
  10. Munchkinz Motherboard Replacement, Unscrew Module: 10 단계, 이미지 1개 중 1개
    • Remove the two screws that hold the volume button assembly in place.
    댓글 쓰기
  11. Munchkinz Motherboard Replacement, Solder Module Wires: 11 단계, 이미지 1개 중 1개
    • Un-solder the yellow, red, and black wires that connect the volume module to the motherboard.
    댓글 쓰기
  12. Munchkinz Motherboard Replacement, Removing battery: 12 단계, 이미지 3개 중 1개 Munchkinz Motherboard Replacement, Removing battery: 12 단계, 이미지 3개 중 2개 Munchkinz Motherboard Replacement, Removing battery: 12 단계, 이미지 3개 중 3개
    • Use the wide plastic opening tool to slowly pry each side of the battery up.
    • Be careful not to bend the battery too much.
    댓글 쓰기
  13. Munchkinz Motherboard Replacement, Remove battery completely: 13 단계, 이미지 1개 중 1개
    • Use the Soldering Iron to disconnect the each cable.
    댓글 쓰기
  14. Munchkinz Motherboard Replacement, Remove Tape: 14 단계, 이미지 1개 중 1개
    • Remove black tape covering any of the ribbons that have it.
    댓글 쓰기
  15. Munchkinz Motherboard Replacement, Remove Ribbons: 15 단계, 이미지 1개 중 1개
    • Pull the ribbons out from the plugs.
    댓글 쓰기
  16. Munchkinz Motherboard Replacement, Remove Camera/Hidden Screw: 16 단계, 이미지 1개 중 1개
    • After removing the camera, remove the hidden screw.
    댓글 쓰기
  17. Munchkinz Motherboard Replacement, Remove Screws: 17 단계, 이미지 1개 중 1개
    • Remove screws located on the opposite side of the battery.
    댓글 쓰기
  18. Munchkinz Motherboard Replacement, Lift: 18 단계, 이미지 1개 중 1개
    • Carefully lift up the motherboard. Your accessory parts such as battery, speaker, volume button assembly, and camera wires will be disconnected, not connected, like in this picture.
    댓글 쓰기
결론
취소: 해당 안내서를 완성하지 않았습니다.
작성자
4다른 기여자 명과 함께
Austin Oliveira
회원 가입일: 02/05/15
204 평판
안내서 2개를 작성함
UW Tacoma, Team 3-6, Rose Winter 2015 UW Tacoma, Team 3-6, Rose Winter 2015 회원
UWT-ROSE-W15S3G6
3 회원들
안내서 14개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 5
지난 30일: 24
전체 시간: 508
