주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
NABI XD Screen Replacement
필요한 것
    1. NABI XD Screen Replacement, Rear panel: 1 단계, 이미지 2개 중 1개 NABI XD Screen Replacement, Rear panel: 1 단계, 이미지 2개 중 2개
      • Use the plastic opening tool at the top left corner seam, then pry the corner apart.
      댓글 쓰기
    2. NABI XD Screen Replacement: 2 단계, 이미지 1개 중 1개
      • Next slide the plastic opening tool across the sides of the Nabi. It will slowly open.
      • There are small plastic clips that need to be release. Gently apply outwards pressure until the clips give.
      • Go around the NABI XD and separate the rear panel from the device.
      댓글 쓰기
    1. NABI XD Screen Replacement, Battery: 3 단계, 이미지 2개 중 1개 NABI XD Screen Replacement, Battery: 3 단계, 이미지 2개 중 2개
      • Place your fingernails on both sides of the connector and pull it straight back away from the holder.
      댓글 쓰기
    2. NABI XD Screen Replacement: 4 단계, 이미지 1개 중 1개
      • Battery is glued to the base, lift carefully.
      • To remove battery, lift the battery up from the motherboard.
      댓글 쓰기
    1. NABI XD Screen Replacement, Charging port: 5 단계, 이미지 2개 중 1개 NABI XD Screen Replacement, Charging port: 5 단계, 이미지 2개 중 2개
      이 단계에 사용된 도구:
      • Remove the two 4mm Phillips screws with the PH#0 screwdriver.
      • Disconnect the left (L) speaker wire from the charging port by grabbing it on both sides with the tweezers and pulling straight back.
      댓글 쓰기
    2. NABI XD Screen Replacement: 6 단계, 이미지 1개 중 1개
      • Use your fingernails or a spudger to flip up the small retaining flap, then pull the ribbon straight back to remove
      • Lift the charging port from the NABI XD.
      댓글 쓰기
    1. NABI XD Screen Replacement, Motherboard: 7 단계, 이미지 3개 중 1개 NABI XD Screen Replacement, Motherboard: 7 단계, 이미지 3개 중 2개 NABI XD Screen Replacement, Motherboard: 7 단계, 이미지 3개 중 3개
      이 단계에 사용된 도구:
      • To remove the marked ribbons, use your fingernails or a spudger to lift up small tab
      • Use the Precision Tweezers to gently pull the ribbons straight out of the connectors.
      • You need to remove 4 ribbons
      댓글 쓰기
    2. NABI XD Screen Replacement: 8 단계, 이미지 3개 중 1개 NABI XD Screen Replacement: 8 단계, 이미지 3개 중 2개 NABI XD Screen Replacement: 8 단계, 이미지 3개 중 3개
      • Disconnect the camera by lifting the ribbon straight up. Also disconnect the remaining ribbon by lifting up gently.
      • To disconnect antenna wire, use the tweezers to pry connector straight from the board.
      댓글 쓰기
    3. NABI XD Screen Replacement: 9 단계, 이미지 2개 중 1개 NABI XD Screen Replacement: 9 단계, 이미지 2개 중 2개
      • Disconnect the Right speaker by grabbing the wire head by its sides and pulling it back from the connector.
      댓글 쓰기
    4. NABI XD Screen Replacement: 10 단계, 이미지 2개 중 1개 NABI XD Screen Replacement: 10 단계, 이미지 2개 중 2개
      • Remove the four 4mm Phillips screws with the PH#0 screwdriver.
      댓글 쓰기
    5. NABI XD Screen Replacement: 11 단계, 이미지 1개 중 1개
      • Lift the motherboard up away from the Nabi XD.
      댓글 쓰기
    1. NABI XD Screen Replacement, Speakers: 12 단계, 이미지 3개 중 1개 NABI XD Screen Replacement, Speakers: 12 단계, 이미지 3개 중 2개 NABI XD Screen Replacement, Speakers: 12 단계, 이미지 3개 중 3개
      • Right (R) speaker removal:
      • Remove one 4mm Phillips screw.
      • Use the metal spudger to separate the speaker from the frame.
      • The speaker is glued to the Nabi XD it will require some force to separate them.
      댓글 쓰기
    2. NABI XD Screen Replacement: 13 단계, 이미지 2개 중 1개 NABI XD Screen Replacement: 13 단계, 이미지 2개 중 2개
      • Remove the left (L) speaker wire from the frame by pulling it to the side and up.
      • The wire in this step, is connected to the charging port. Removing it, is shown in detail on step 6.
      댓글 쓰기
    3. NABI XD Screen Replacement: 14 단계, 이미지 3개 중 1개 NABI XD Screen Replacement: 14 단계, 이미지 3개 중 2개 NABI XD Screen Replacement: 14 단계, 이미지 3개 중 3개
      • Left (L) speaker removal:
      • Remove two 4mm Phillips screws.
      댓글 쓰기
    1. NABI XD Screen Replacement, Screen: 15 단계, 이미지 3개 중 1개 NABI XD Screen Replacement, Screen: 15 단계, 이미지 3개 중 2개 NABI XD Screen Replacement, Screen: 15 단계, 이미지 3개 중 3개
      • The ribbons are glued to the frame so gently lift them up without ripping them.
      • Lightly lift the marked wires and ribbons from the frame by gently pulling them in the direction of the arrows and up.
      • Remove five 4mm Phillips screws from the frame.
      댓글 쓰기
    2. NABI XD Screen Replacement: 16 단계, 이미지 2개 중 1개 NABI XD Screen Replacement: 16 단계, 이미지 2개 중 2개
      • Use the Plastic Opening tools to lift the frame up.
      • The ribbons need to be detangled from the frame while you are lifting it up.
      • Do not yank the frame away from the Nabi XD it is connect to it by a ribbon. Gently lift.
      댓글 쓰기
    3. NABI XD Screen Replacement: 17 단계, 이미지 2개 중 1개 NABI XD Screen Replacement: 17 단계, 이미지 2개 중 2개
      • Lift the screen up with the black spudger.
      • Lift the frame up slowly and place it to the side.
      댓글 쓰기
결론
취소: 해당 안내서를 완성하지 않았습니다.
다른 한 분이 해당 안내서를 완성하였습니다.
작성자
1다른 기여자 명과 함께
Marissa Schiereck
회원 가입일: 09/15/16
638 평판
안내서 6개를 작성함
USF Tampa, Team 17-2, Blackwell Fall 2016 USF Tampa, Team 17-2, Blackwell Fall 2016 회원
USFT-BLACKWELL-F16S17G2
3 회원들
안내서 18개를 작성함
1가이드 댓글
Will the screen from an A or C model work with a B model?
Kevin Fifer - 답글 공유
댓글 쓰기
조회 통계:
지난 24시간: 3
지난 7일: 8
지난 30일: 27
전체 시간: 1,091
