주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
NVIDIA (2015) Remote P2575 Battery Replacement and Breakdown
필요한 것
    1. NVIDIA (2015) Remote P2575 Battery Replacement and Breakdown, Get Item and tools in area for dismantle: 1 단계, 이미지 3개 중 1개 NVIDIA (2015) Remote P2575 Battery Replacement and Breakdown, Get Item and tools in area for dismantle: 1 단계, 이미지 3개 중 2개 NVIDIA (2015) Remote P2575 Battery Replacement and Breakdown, Get Item and tools in area for dismantle: 1 단계, 이미지 3개 중 3개
      • Suggested Items Listed
      댓글 쓰기
    2. NVIDIA (2015) Remote P2575 Battery Replacement and Breakdown, Removing the Top Cover: 2 단계, 이미지 2개 중 1개 NVIDIA (2015) Remote P2575 Battery Replacement and Breakdown, Removing the Top Cover: 2 단계, 이미지 2개 중 2개
      • From here you will want to use the Jimmy or similar item to get under the bottom corner to get past the inner clips. From here you can carefully get both sides of the bottom top cover and lift it off. The remainder of the cover should come off fairly easily. If not use the jimmy to unclip the others.
      댓글 쓰기
    3. NVIDIA (2015) Remote P2575 Battery Replacement and Breakdown, Removing buttons and Exposing the circuit: 3 단계, 이미지 2개 중 1개 NVIDIA (2015) Remote P2575 Battery Replacement and Breakdown, Removing buttons and Exposing the circuit: 3 단계, 이미지 2개 중 2개
      • The Buttons are easily removed. The Volume Touch pad is also seen here; it is attached by glue.
      댓글 쓰기
    4. NVIDIA (2015) Remote P2575 Battery Replacement and Breakdown, Removing the first Circuit Board: 4 단계, 이미지 3개 중 1개 NVIDIA (2015) Remote P2575 Battery Replacement and Breakdown, Removing the first Circuit Board: 4 단계, 이미지 3개 중 2개 NVIDIA (2015) Remote P2575 Battery Replacement and Breakdown, Removing the first Circuit Board: 4 단계, 이미지 3개 중 3개
      • Use the Jimmy to prop the circuit board from the glue attached to the casing. Becareful of the ribbon attached. The circuit board will come out away from the ribbon if you remove it from the glue.
      댓글 쓰기
    5. NVIDIA (2015) Remote P2575 Battery Replacement and Breakdown, Removing the Ribbon Cable from Circuit: 5 단계, 이미지 2개 중 1개 NVIDIA (2015) Remote P2575 Battery Replacement and Breakdown, Removing the Ribbon Cable from Circuit: 5 단계, 이미지 2개 중 2개
      • Once you have the Circuit out of the glue you will see the shown Ribbon attachment clip moved up to be removed. Second picture the board is removed.
      댓글 쓰기
    6. NVIDIA (2015) Remote P2575 Battery Replacement and Breakdown, Removing the Ribbon Sensor and Battery Compartment: 6 단계, 이미지 3개 중 1개 NVIDIA (2015) Remote P2575 Battery Replacement and Breakdown, Removing the Ribbon Sensor and Battery Compartment: 6 단계, 이미지 3개 중 2개 NVIDIA (2015) Remote P2575 Battery Replacement and Breakdown, Removing the Ribbon Sensor and Battery Compartment: 6 단계, 이미지 3개 중 3개
      이 단계에 사용된 도구:
      • The Sensor Ribbon is carefully peeled away from the glue. There are two options available to get the battery compartment out. You can either use the Tweezers and push near the ribbon cable or you can use the tweezers to push from the other end inside and under the Sensor place as seen in the picture.
      댓글 쓰기
    7. NVIDIA (2015) Remote P2575 Battery Replacement and Breakdown, Removing the Battery from the housing: 7 단계, 이미지 3개 중 1개 NVIDIA (2015) Remote P2575 Battery Replacement and Breakdown, Removing the Battery from the housing: 7 단계, 이미지 3개 중 2개 NVIDIA (2015) Remote P2575 Battery Replacement and Breakdown, Removing the Battery from the housing: 7 단계, 이미지 3개 중 3개
      • From here you can remove the Single Phillips Screw using the Phillips 00 Driver Bit. This will let you pry the circuit and battery from the Glue . You can lift the Battery from the Circuit board as it is made to lift upward and away from the board.
      댓글 쓰기
    8. NVIDIA (2015) Remote P2575 Battery Replacement and Breakdown, Battery and Overall Component Picture: 8 단계, 이미지 3개 중 1개 NVIDIA (2015) Remote P2575 Battery Replacement and Breakdown, Battery and Overall Component Picture: 8 단계, 이미지 3개 중 2개 NVIDIA (2015) Remote P2575 Battery Replacement and Breakdown, Battery and Overall Component Picture: 8 단계, 이미지 3개 중 3개
      • Insert wisdom here.
      댓글 쓰기
결승점
취소: 해당 안내서를 완성하지 않았습니다.
다른 5명이 해당 안내서를 완성하였습니다.
작성자
4다른 기여자 명과 함께
Kevin Jones
회원 가입일: 11/27/12
1,332 평판
안내서 2개를 작성함
9가이드 댓글
I have one slight problem. I opened my remote, now i cant put it back together. The clamp near the charging port just wont get back into place. Nothing is broken. i checked, all clamps are there, but this one just wont slide back in to let me close back the remote. Any tip ?
Remus C - 답글 공유
YouTube Comment
YouTube Comment
I would double check the female Clamp end on the bottom part. You my have broken the receiving end of the clamp.
YouTube Comment
Thank you for the reply. Sadly both of clamps were ok. I managed to fix by bending the male clamp in the outside position. Also, the female clamp was made of aluminum, so breaking it was impossible. I finally closed it somehow, but it still has a little wiggle on the sides. Well, thats about all that can be done.
Kevin Jones - 답글 공유
Has anyone else experienced that the microphone stops working? I’m thinking maybe it could be fixed by opening it up and.. ?
Thomas Novin - 답글 공유
Where i can buy the battery?
Samir Selmanovic - 답글 공유
댓글 쓰기
조회 통계:
지난 24시간: 3
지난 7일: 24
지난 30일: 168
전체 시간: 13,367
