주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Nabi Jr Battery Replacement
필요한 것
    1. Nabi Jr Battery Replacement, Rear Case: 1 단계, 이미지 1개 중 1개
      • Remove the red rubber case from the device. This should come off with ease.
      댓글 쓰기
    2. Nabi Jr Battery Replacement: 2 단계, 이미지 1개 중 1개
      • Turn the device so the screen is facing away from you.
      • Using a philips head, size #00, screwdriver, remove the screws in each corner of the plastic casing.(total of 4 screws)
      댓글 쓰기
    3. Nabi Jr Battery Replacement: 3 단계, 이미지 1개 중 1개
      • Remove the device casing using a small plastic pry bar.
      • This might take a little bit of force to accomplish, don't be afraid to go at it with a little gusto.
      댓글 쓰기
    4. Nabi Jr Battery Replacement: 4 단계, 이미지 1개 중 1개
      • After loosening the back cover, remove it from the device so you can get at the innards.
      댓글 쓰기
    1. Nabi Jr Battery Replacement, Battery: 5 단계, 이미지 1개 중 1개
      • Lift the battery up from the motherboard.
      • Don't rip the soldered wires from the board.
      • The battery is stuck to the motherboard with adhesive, it may take a little pull to separate.
      댓글 쓰기
    2. Nabi Jr Battery Replacement: 6 단계, 이미지 1개 중 1개
      • Remove the battery from the motherboard
      • De-solder the colored wires
      • Be sure to note the order in which the wires are connected to the board before desoldering them.
      • Be careful while removing the solder off of the colored battery wires. The soldering iron will be extremely hot
      댓글 쓰기
    3. Nabi Jr Battery Replacement: 7 단계, 이미지 2개 중 1개 Nabi Jr Battery Replacement: 7 단계, 이미지 2개 중 2개
      • Replace the old battery with the new one
      • Solder the wires of the new battery into the pads on the motherboard
      • Be careful when soldering the wires in. Soldering iron will be extremely hot
      댓글 쓰기
    4. Nabi Jr Battery Replacement: 8 단계, 이미지 1개 중 1개
      • Once the wires are fully soldered, put the new battery back to the initial position
      • Close the case by putting the back cover back on the device
      • Will take some force
      • Make sure the battery is not in the way of the back cover
      댓글 쓰기
    5. Nabi Jr Battery Replacement: 9 단계, 이미지 1개 중 1개
      • Once the back cover is on, screw in the four screws that you had taken off in the beginning
      • Put the red rubber casing back on.
      댓글 쓰기
결론
If all the steps were followed correctly, the device should be fully closed and ready to go
취소: 해당 안내서를 완성하지 않았습니다.
다른 4명이 해당 안내서를 완성하였습니다.
작성자
4다른 기여자 명과 함께
Jimmy Nguyen
회원 가입일: 03/24/15
271 평판
안내서 2개를 작성함
UMass Dartmouth, Team 4-3, Vijaybhaskar Spring 2015 UMass Dartmouth, Team 4-3, Vijaybhaskar Spring 2015 회원
UMASSD-VIJAYBHASKAR-S15S4G3
3 회원들
안내서 12개를 작성함
7가이드 댓글
Thank you for sharing the idea ,but I need that NABI JR battery. So ,where from I can purchase it .
Lus Ka - 답글 공유
I have seen them on ebay but it's easier to find a Nabi 2 battery on ebay. The Nabi 2 battery is quite a bit larger but with a very minor mod to the Nabi Jr. the Nabi 2 battery will fit and give you a much longer run time from a single charge.
darcshadow - 답글 공유
My old Nabi jr battery is a plug in with 2 reds 1 white and 2 black wires. My new Cameron sino battery is blue green red yellow black. What is the order to resolder them.
Dennis Blixt - 답글 공유
I have the same problem with the problem of the replacement battery not having the same wiring configuration or plug. Did you ever get this resolved?
Delores Duke - 답글 공유
Where can I buy the battery live in Mexico
Roos - 답글 공유
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 14
지난 30일: 43
전체 시간: 12,364
