주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Nabi Jr Screen Replacement
필요한 것
    1. Nabi Jr Screen Replacement, Rear Case: 1 단계, 이미지 1개 중 1개
      • Remove the red rubber case from the device. This should come off with ease.
      댓글 쓰기
    2. Nabi Jr Screen Replacement: 2 단계, 이미지 1개 중 1개
      • Turn the device so the screen is facing away from you.
      • Using a philips head, size #00, screwdriver, remove the screws in each corner of the plastic casing.(total of 4 screws)
      댓글 쓰기
    3. Nabi Jr Screen Replacement: 3 단계, 이미지 1개 중 1개
      • Remove the device casing using a small plastic pry bar.
      • This might take a little bit of force to accomplish, don't be afraid to go at it with a little gusto.
      댓글 쓰기
    4. Nabi Jr Screen Replacement: 4 단계, 이미지 1개 중 1개
      • After loosening the back cover, remove it from the device so you can get at the innards.
      댓글 쓰기
    1. Nabi Jr Screen Replacement, Motherboard: 5 단계, 이미지 1개 중 1개
      • Use the Philips #00 screwdriver to remove the 5 screws from the motherboard
      댓글 쓰기
    2. Nabi Jr Screen Replacement: 6 단계, 이미지 1개 중 1개
      • De-solder the grey wire from motherboard
      댓글 쓰기
    3. Nabi Jr Screen Replacement: 7 단계, 이미지 1개 중 1개
      이 단계에 사용된 도구:
      • Use tweezers to peel off all yellow tape from the motherboard
      • Yellow tape is used in all locations where there is ribbon cable present.
      댓글 쓰기
    4. Nabi Jr Screen Replacement: 8 단계, 이미지 2개 중 1개 Nabi Jr Screen Replacement: 8 단계, 이미지 2개 중 2개
      • Remove all three ribbon cables from the motherboard by lifting up the locking tabs.
      • Pull black locking tabs up in opposite direction of ribbon cable to remove.
      • Use tweezers to pull the ribbon cable out of the locking tab's slot
      댓글 쓰기
    5. Nabi Jr Screen Replacement: 9 단계, 이미지 2개 중 1개 Nabi Jr Screen Replacement: 9 단계, 이미지 2개 중 2개
      • Lift motherboard to separate it the from the case shell.
      댓글 쓰기
    1. Nabi Jr Screen Replacement, Screen: 10 단계, 이미지 1개 중 1개
      • Remove the 6 screws that hold the screen in place
      댓글 쓰기
    2. Nabi Jr Screen Replacement: 11 단계, 이미지 2개 중 1개 Nabi Jr Screen Replacement: 11 단계, 이미지 2개 중 2개
      • Remove the screen from the front casing
      댓글 쓰기
    3. Nabi Jr Screen Replacement: 12 단계, 이미지 1개 중 1개
      • Separate the screen from the plastic casing.
      댓글 쓰기
    4. Nabi Jr Screen Replacement: 13 단계, 이미지 1개 중 1개
      • Replace the old screen with the new screen
      댓글 쓰기
결론
취소: 해당 안내서를 완성하지 않았습니다.
다른 한 분이 해당 안내서를 완성하였습니다.
작성자
3다른 기여자 명과 함께
Jimmy Nguyen
회원 가입일: 03/24/15
271 평판
안내서 2개를 작성함
UMass Dartmouth, Team 4-3, Vijaybhaskar Spring 2015 UMass Dartmouth, Team 4-3, Vijaybhaskar Spring 2015 회원
UMASSD-VIJAYBHASKAR-S15S4G3
3 회원들
안내서 12개를 작성함
3가이드 댓글
Do you know of anywhere I can send a nabi jr to have a cracked screen replaced?
Katie - 답글 공유
Yes thank you for the information but where do we find a screen to replace this?
davemel - 답글 공유
My navi jr is the nick jr edition and looks a bit different inside. I replaced the screen, as mentioned here but has to remove the outter glass-like screen that has the second smaller ribbonattach from the original screen, and put it on my screen because the new screen did not have that part. All buttons work, the screen looks perfect and vibrant, but the EFEN TOUCH Does not work!!! What did I do wrong? I attached all the ribbons properly!!!
vane.lpz - 답글 공유
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 6
지난 30일: 24
전체 시간: 5,864
