주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Necklace Chain Repair
필요한 것
    1. Necklace Chain Repair, Necklace Chain Repair: 1 단계, 이미지 1개 중 1개
      • Look closely at where the necklace chain came apart. You will see a split ring, otherwise known as a jump ring.
      • Figure A: The jump ring is located on one end of the necklace.
      댓글 쓰기
    2. Necklace Chain Repair: 2 단계, 이미지 2개 중 1개 Necklace Chain Repair: 2 단계, 이미지 2개 중 2개
      • Figures B and C: While holding the needle nose pliers in one hand, clamp onto one end of the jump ring and hold on to the other end with your thumb and index finger.
      • Carefully pull on the ends of the jump ring until the opening is large enough to accommodate one of the chain links.
      • Warning: Do not separate the jump ring ends too far apart, otherwise damage to the jump ring may occur.
      댓글 쓰기
    3. Necklace Chain Repair: 3 단계, 이미지 2개 중 1개 Necklace Chain Repair: 3 단계, 이미지 2개 중 2개
      • Now that the jump ring opening is separated, you can reattach the chain. Find the end of the chain that had detached from the necklace.
      • Figures D and E: While holding the jump ring in one hand and the end of the necklace in your other hand, proceed to loop the chain into the opened jump ring.
      댓글 쓰기
    4. Necklace Chain Repair: 4 단계, 이미지 1개 중 1개
      • Figure F: Using similar methods from Step 2 Figure C, clamp onto one end of the jump ring slit with your pliers and hold on to the other end with your thumb and index finger.
      • Carefully close the opening of the jump ring.
      댓글 쓰기
    5. Necklace Chain Repair: 5 단계, 이미지 2개 중 1개 Necklace Chain Repair: 5 단계, 이미지 2개 중 2개
      • Figure G: It is time to close the jump ring. With your pliers, clamp on both ends of the jump ring and push together so the two ends of the jump ring slightly overlap.
      • Refer to Figure H for finished assembly.
      댓글 쓰기
결론
To make sure the necklace is correctly reattached, gently pull on the chain. The jump ring should be firmly closed as to prevent the chain from slipping off the jump ring.
취소: 해당 안내서를 완성하지 않았습니다.
다른 5명이 해당 안내서를 완성하였습니다.
작성자
5다른 기여자 명과 함께
Stephanie Lascola
회원 가입일: 04/09/15
361 평판
안내서 1개를 작성함
Cal Poly, Team 28-4, Green Spring 2015 Cal Poly, Team 28-4, Green Spring 2015 회원
CPSU-GREEN-S15S28G4
6 회원들
안내서 25개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 3
지난 7일: 20
지난 30일: 74
전체 시간: 6,239
