주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Nerf Dart Tag Furyfire Trigger Replacement
필요한 것
    1. Nerf Dart Tag Furyfire Trigger Replacement, Remove the screws: 1 단계, 이미지 1개 중 1개
      • Using a 00 Phillips screwdriver, remove all screws from the front panel. The screws have a length of .95 cm.
      댓글 쓰기
    2. Nerf Dart Tag Furyfire Trigger Replacement, Remove Panel: 2 단계, 이미지 1개 중 1개
      • After the screws have been removed, gently lift the panel from the gun and set it aside.
      댓글 쓰기
    1. Nerf Dart Tag Furyfire Trigger Replacement, Remove Black Cylinder: 3 단계, 이미지 1개 중 1개
      • Locate the black cylinder connected to the large spring near the top of the device.
      • Once located, push the black cylinder against the spring and lift it out of the device.
      댓글 쓰기
    2. Nerf Dart Tag Furyfire Trigger Replacement, Remove Spring: 4 단계, 이미지 2개 중 1개 Nerf Dart Tag Furyfire Trigger Replacement, Remove Spring: 4 단계, 이미지 2개 중 2개
      • Using your hand, lift the large spring and attached plastic stabilizing piece out of the gun and set aside.
      • Ensure that the small spring connected to the stabilizing piece remains connected.
      댓글 쓰기
    1. Nerf Dart Tag Furyfire Trigger Replacement, Remove Pump Handle: 5 단계, 이미지 1개 중 1개
      • Remove the two screws circled in blue. They are .95 cm in length.
      • Remove the three screw circled in green. They are .7 cm in length.
      댓글 쓰기
    2. Nerf Dart Tag Furyfire Trigger Replacement, Remove the Pump Handle: 6 단계, 이미지 1개 중 1개
      • Once all of the screws have been removed lift the pump handle off and set it aside.
      댓글 쓰기
    3. Nerf Dart Tag Furyfire Trigger Replacement, Remove Attached Spring: 7 단계, 이미지 2개 중 1개 Nerf Dart Tag Furyfire Trigger Replacement, Remove Attached Spring: 7 단계, 이미지 2개 중 2개
      • In order to remove the white plastic holder, you must remove the spring that keeps it in place. Using a 00 Phillips screwdriver, carefully remove the screw while holding the spring in place.
      댓글 쓰기
    4. Nerf Dart Tag Furyfire Trigger Replacement, Disengage White Piece: 8 단계, 이미지 1개 중 1개
      • Using a plastic opening tool, lift the white piece out of the gun and set it aside.
      댓글 쓰기
    5. Nerf Dart Tag Furyfire Trigger Replacement, Remove the Pump Track: 9 단계, 이미지 2개 중 1개 Nerf Dart Tag Furyfire Trigger Replacement, Remove the Pump Track: 9 단계, 이미지 2개 중 2개
      • Using your hand, slide the track out of the gun by pulling it away form the device.
      댓글 쓰기
    1. Nerf Dart Tag Furyfire Trigger Replacement, Detach Black Piece from Trigger: 10 단계, 이미지 1개 중 1개
      • Using a plastic opening tool, detach the black piece from the trigger. You do not need to remove the black piece from the gun.
      댓글 쓰기
    2. Nerf Dart Tag Furyfire Trigger Replacement, Remove Trigger: 11 단계, 이미지 1개 중 1개
      • Once the black piece has been detached, the trigger can be lifted out of the device.
      댓글 쓰기
결론
To reassemble your device, follow these instructions in reverse order. Ensure that the spring located behind the trigger is attached to the limb on the backside of the trigger.
취소: 해당 안내서를 완성하지 않았습니다.
작성자
3다른 기여자 명과 함께
Bradley Penrow
회원 가입일: 09/23/14
37 평판
안내서 4개를 작성함
USF Tampa, Team 11-2, Blackwell Fall 2014 USF Tampa, Team 11-2, Blackwell Fall 2014 회원
USFT-BLACKWELL-F14S11G2
4 회원들
안내서 5개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 1
지난 7일: 5
지난 30일: 34
전체 시간: 1,198
