주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Nerf N-Strike Elite Hail-Fire Right Shell Replacement
필요한 것
    1. Nerf N-Strike Elite Hail-Fire Right Shell Replacement, Left Shell: 1 단계, 이미지 3개 중 1개 Nerf N-Strike Elite Hail-Fire Right Shell Replacement, Left Shell: 1 단계, 이미지 3개 중 2개 Nerf N-Strike Elite Hail-Fire Right Shell Replacement, Left Shell: 1 단계, 이미지 3개 중 3개
      • Before disassembling your Nerf Hail-Fire, be sure to remove the batteries.
      • Remove the two 9.0 mm Phillips screws securing the battery compartment.
      • Slide the battery compartment out.
      댓글 쓰기
    2. Nerf N-Strike Elite Hail-Fire Right Shell Replacement: 2 단계, 이미지 1개 중 1개
      • Remove the five 9.0 mm Phillips screws securing the trigger.
      댓글 쓰기
    3. Nerf N-Strike Elite Hail-Fire Right Shell Replacement: 3 단계, 이미지 2개 중 1개 Nerf N-Strike Elite Hail-Fire Right Shell Replacement: 3 단계, 이미지 2개 중 2개
      • Remove the single 11.0 mm Phillips screw securing the magazine cartridge chambers.
      • Pull the entire chamber upwards to separate it from the rest of the Nerf Gun.
      댓글 쓰기
    4. Nerf N-Strike Elite Hail-Fire Right Shell Replacement: 4 단계, 이미지 3개 중 1개 Nerf N-Strike Elite Hail-Fire Right Shell Replacement: 4 단계, 이미지 3개 중 2개 Nerf N-Strike Elite Hail-Fire Right Shell Replacement: 4 단계, 이미지 3개 중 3개
      • Remove both halves of the ring by tugging on it upwards until the lock gets freed.
      • This requires quite a bit of force and if you are not careful, you may break the plastic lock.
      댓글 쓰기
    5. Nerf N-Strike Elite Hail-Fire Right Shell Replacement: 5 단계, 이미지 1개 중 1개
      • Remove the four 9.0 mm Phillips screws from the newly revealed cylinder.
      댓글 쓰기
    6. Nerf N-Strike Elite Hail-Fire Right Shell Replacement: 6 단계, 이미지 1개 중 1개
      • Remove the three 9.0 mm Phillips screws holding the top latch of the Nerf Gun together.
      댓글 쓰기
    7. Nerf N-Strike Elite Hail-Fire Right Shell Replacement: 7 단계, 이미지 1개 중 1개
      • Remove the three 9.0 mm Phillips screws holding together the firing chamber.
      • Remove the single 7.0 mm Phillips screw below the barrel.
      • Remove the two 14.0 mm Philips screws using a screwdriver with a length of approximately 4.0 inches and a diameter of approximately 0.2 cm.
      댓글 쓰기
    8. Nerf N-Strike Elite Hail-Fire Right Shell Replacement: 8 단계, 이미지 1개 중 1개
      • Remove the single 14.0 mm Phillips screw holding together the handle and the Nerf Gun.
      댓글 쓰기
    9. Nerf N-Strike Elite Hail-Fire Right Shell Replacement: 9 단계, 이미지 2개 중 1개 Nerf N-Strike Elite Hail-Fire Right Shell Replacement: 9 단계, 이미지 2개 중 2개
      • Remove the two 9.0 mm Phillips screws holding together the handle.
      • Remove the plastic cover of the handle.
      댓글 쓰기
    10. Nerf N-Strike Elite Hail-Fire Right Shell Replacement: 10 단계, 이미지 2개 중 1개 Nerf N-Strike Elite Hail-Fire Right Shell Replacement: 10 단계, 이미지 2개 중 2개
      • Insert one plastic opening tool inside one side of the orange part depicted in the picture.
      • Insert a second plastic opening tool to the other side of the orange part and gradually pull the piece out, freeing it from the handle.
      댓글 쓰기
    11. Nerf N-Strike Elite Hail-Fire Right Shell Replacement: 11 단계, 이미지 3개 중 1개 Nerf N-Strike Elite Hail-Fire Right Shell Replacement: 11 단계, 이미지 3개 중 2개 Nerf N-Strike Elite Hail-Fire Right Shell Replacement: 11 단계, 이미지 3개 중 3개
      • Pull one end of the handle away from the orange latch.
      • Repeat the procedure on the other side to completely remove the handle from the rest of the Nerf Gun.
      댓글 쓰기
    12. Nerf N-Strike Elite Hail-Fire Right Shell Replacement: 12 단계, 이미지 3개 중 1개 Nerf N-Strike Elite Hail-Fire Right Shell Replacement: 12 단계, 이미지 3개 중 2개 Nerf N-Strike Elite Hail-Fire Right Shell Replacement: 12 단계, 이미지 3개 중 3개
      • Lift the entire left shell slowly. The process should be easy and if there is any resistance, there is something wrong. You may have forgotten a screw.
      • Completely remove the left shell from the rest of the Nerf Gun.
      댓글 쓰기
    1. Nerf N-Strike Elite Hail-Fire Right Shell Replacement, Inner Plastic Components: 13 단계, 이미지 3개 중 1개 Nerf N-Strike Elite Hail-Fire Right Shell Replacement, Inner Plastic Components: 13 단계, 이미지 3개 중 2개 Nerf N-Strike Elite Hail-Fire Right Shell Replacement, Inner Plastic Components: 13 단계, 이미지 3개 중 3개
      • Remove the cartridge support.
      댓글 쓰기
    2. Nerf N-Strike Elite Hail-Fire Right Shell Replacement: 14 단계, 이미지 3개 중 1개 Nerf N-Strike Elite Hail-Fire Right Shell Replacement: 14 단계, 이미지 3개 중 2개 Nerf N-Strike Elite Hail-Fire Right Shell Replacement: 14 단계, 이미지 3개 중 3개
      • Remove the handle crank.
      댓글 쓰기
    3. Nerf N-Strike Elite Hail-Fire Right Shell Replacement: 15 단계, 이미지 2개 중 1개 Nerf N-Strike Elite Hail-Fire Right Shell Replacement: 15 단계, 이미지 2개 중 2개
      • Remove the clear plastic barrel cover.
      댓글 쓰기
    4. Nerf N-Strike Elite Hail-Fire Right Shell Replacement: 16 단계, 이미지 2개 중 1개 Nerf N-Strike Elite Hail-Fire Right Shell Replacement: 16 단계, 이미지 2개 중 2개
      • Remove the firing pin.
      댓글 쓰기
    1. Nerf N-Strike Elite Hail-Fire Right Shell Replacement, Right Shell: 17 단계, 이미지 2개 중 1개 Nerf N-Strike Elite Hail-Fire Right Shell Replacement, Right Shell: 17 단계, 이미지 2개 중 2개
      • Lift the trigger mechanism out of the shell.
      • You cannot fully remove the trigger mechanism just yet. However taking it out of the shell helps in later steps.
      댓글 쓰기
    2. Nerf N-Strike Elite Hail-Fire Right Shell Replacement: 18 단계, 이미지 3개 중 1개 Nerf N-Strike Elite Hail-Fire Right Shell Replacement: 18 단계, 이미지 3개 중 2개 Nerf N-Strike Elite Hail-Fire Right Shell Replacement: 18 단계, 이미지 3개 중 3개
      • Remove the two 9.0 mm Phillips screws.
      댓글 쓰기
    3. Nerf N-Strike Elite Hail-Fire Right Shell Replacement: 19 단계, 이미지 3개 중 1개 Nerf N-Strike Elite Hail-Fire Right Shell Replacement: 19 단계, 이미지 3개 중 2개 Nerf N-Strike Elite Hail-Fire Right Shell Replacement: 19 단계, 이미지 3개 중 3개
      • To remove the motor and trigger mechanism you have to detach these two wires which are glued to the shell.
      • Hold close to the wire and pull upward slowly.
      • If you pull too quickly you can potentially damage the wire.
      댓글 쓰기
    4. Nerf N-Strike Elite Hail-Fire Right Shell Replacement: 20 단계, 이미지 2개 중 1개 Nerf N-Strike Elite Hail-Fire Right Shell Replacement: 20 단계, 이미지 2개 중 2개
      • Once all the pieces are removed the right shell should be fully accessible.
      댓글 쓰기
결론
취소: 해당 안내서를 완성하지 않았습니다.
다른 2명이 해당 안내서를 완성하였습니다.
작성자
3다른 기여자 명과 함께
sage
회원 가입일: 01/24/14
301 평판
안내서 3개를 작성함
Cal Poly, Team 13-13, Regan Winter 2014 Cal Poly, Team 13-13, Regan Winter 2014 회원
CPSU-REGAN-W14S13G13
4 회원들
안내서 56개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 1
지난 7일: 9
지난 30일: 42
전체 시간: 5,109
