주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Nerf N-Strike Elite Retaliator Trigger Spring Replacement
필요한 것
    1. Nerf N-Strike Elite Retaliator Trigger Spring Replacement, Case Disassembly: 1 단계, 이미지 1개 중 1개
      • While holding the blaster, rotate the barrel assembly in the counter-clockwise direction and pull away from the blaster.
      댓글 쓰기
    2. Nerf N-Strike Elite Retaliator Trigger Spring Replacement: 2 단계, 이미지 1개 중 1개
      • Remove the stock of the blaster by pushing the orange tabs downward while pulling the stock away from the blaster.
      댓글 쓰기
    3. Nerf N-Strike Elite Retaliator Trigger Spring Replacement: 3 단계, 이미지 1개 중 1개
      • Remove the magazine from the blaster by forcing the sliding mechanism backwards, pushing the orange tabs downward, and pulling the magazine away.
      댓글 쓰기
    4. Nerf N-Strike Elite Retaliator Trigger Spring Replacement: 4 단계, 이미지 2개 중 1개 Nerf N-Strike Elite Retaliator Trigger Spring Replacement: 4 단계, 이미지 2개 중 2개
      • Remove the stock attachment point by removing the two 8mm Phillips head screws.
      댓글 쓰기
    5. Nerf N-Strike Elite Retaliator Trigger Spring Replacement: 5 단계, 이미지 2개 중 1개 Nerf N-Strike Elite Retaliator Trigger Spring Replacement: 5 단계, 이미지 2개 중 2개
      • Remove the eleven 8mm and two 10mm Phillips head screws from the left side of the blaster, and carefully remove the outer casing.
      • Two of the screws must be removed with the sliding mechanism in the forward position. Another two must be removed with the sliding mechanism in the back position.
      • There are several springs that may become displaced during this procedure. Proceed with the utmost caution.
      댓글 쓰기
    1. Nerf N-Strike Elite Retaliator Trigger Spring Replacement, Trigger Spring: 6 단계, 이미지 3개 중 1개 Nerf N-Strike Elite Retaliator Trigger Spring Replacement, Trigger Spring: 6 단계, 이미지 3개 중 2개 Nerf N-Strike Elite Retaliator Trigger Spring Replacement, Trigger Spring: 6 단계, 이미지 3개 중 3개
      • Carefully pull the orange trigger upward and backward to remove it from the blaster.
      • This component is under spring pressure. Wear appropriate personal protective equipment to shield your eyes.
      • Remove the spring from the rear of the trigger.
      댓글 쓰기
결론
취소: 해당 안내서를 완성하지 않았습니다.
다른 한 분이 해당 안내서를 완성하였습니다.
작성자
2다른 기여자 명과 함께
ericharman
회원 가입일: 03/02/16
1,440 평판
안내서 5개를 작성함
1가이드 댓글
ok, taken the spring out. now what?
Kelvin Mead - 답글 공유
댓글 쓰기
조회 통계:
지난 24시간: 1
지난 7일: 6
지난 30일: 26
전체 시간: 10,134
