주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Nerf N-Strike Firestrike Laser Trigger Replacement
필요한 것
    1. Nerf N-Strike Firestrike Laser Trigger Replacement, Remove battery cover: 1 단계, 이미지 1개 중 1개
      • Use a #1 Phillips screwdriver to remove the 10 -mm screw that secures the battery plate, then remove the battery cover using your hands.
      댓글 쓰기
    2. Nerf N-Strike Firestrike Laser Trigger Replacement: 2 단계, 이미지 2개 중 1개 Nerf N-Strike Firestrike Laser Trigger Replacement: 2 단계, 이미지 2개 중 2개
      • Slide out the two AAA batteries using your fingers.
      댓글 쓰기
    1. Nerf N-Strike Firestrike Laser Trigger Replacement, Blaster Casing: 3 단계, 이미지 1개 중 1개
      • Remove the seven 10-mm black Phillips screws from the blaster casing with a #1 Phillips Screwdriver.
      댓글 쓰기
    2. Nerf N-Strike Firestrike Laser Trigger Replacement: 4 단계, 이미지 2개 중 1개 Nerf N-Strike Firestrike Laser Trigger Replacement: 4 단계, 이미지 2개 중 2개
      • Slowly pull apart the blaster casing, starting at the battery location.
      • Keep pulling apart slowly until it separates completely. Be cautious as to not send the internal components flying.
      댓글 쓰기
    3. Nerf N-Strike Firestrike Laser Trigger Replacement: 5 단계, 이미지 2개 중 1개 Nerf N-Strike Firestrike Laser Trigger Replacement: 5 단계, 이미지 2개 중 2개
      • For reassembly, ensure that the chrome nut gets put back in the proper location, signified by the red box.
      • For reassembly, ensure that all the parts are lined up correctly on the dowels, signified by the four orange boxes.
      • For reassembly, note the location of the springs as highlighted in the second photo.
      댓글 쓰기
    1. Nerf N-Strike Firestrike Laser Trigger Replacement, Laser Trigger: 6 단계, 이미지 2개 중 1개 Nerf N-Strike Firestrike Laser Trigger Replacement, Laser Trigger: 6 단계, 이미지 2개 중 2개
      • Remove the laser trigger by grabbing the trigger with your fingers and pulling it up and out.
      댓글 쓰기
결론
취소: 해당 안내서를 완성하지 않았습니다.
작성자
2다른 기여자 명과 함께
Jong Wan Kim
회원 가입일: 04/22/15
488 평판
안내서 2개를 작성함
Cal Poly, Team 15-6, Amido Spring 2015 Cal Poly, Team 15-6, Amido Spring 2015 회원
CPSU-AMIDO-S15S15G6
3 회원들
안내서 8개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 1
지난 7일: 6
지난 30일: 28
전체 시간: 2,175
