주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Nerf N-Strike Firestrike Wire Replacement
필요한 것
    1. Nerf N-Strike Firestrike Wire Replacement, Remove battery cover: 1 단계, 이미지 1개 중 1개
      • Use a #1 Phillips screwdriver to remove the 10 -mm screw that secures the battery plate, then remove the battery cover using your hands.
      댓글 쓰기
    2. Nerf N-Strike Firestrike Wire Replacement: 2 단계, 이미지 2개 중 1개 Nerf N-Strike Firestrike Wire Replacement: 2 단계, 이미지 2개 중 2개
      • Slide out the two AAA batteries using your fingers.
      댓글 쓰기
    1. Nerf N-Strike Firestrike Wire Replacement, Blaster Casing: 3 단계, 이미지 1개 중 1개
      • Remove the seven 10-mm black Phillips screws from the blaster casing with a #1 Phillips Screwdriver.
      댓글 쓰기
    2. Nerf N-Strike Firestrike Wire Replacement: 4 단계, 이미지 2개 중 1개 Nerf N-Strike Firestrike Wire Replacement: 4 단계, 이미지 2개 중 2개
      • Slowly pull apart the blaster casing, starting at the battery location.
      • Keep pulling apart slowly until it separates completely. Be cautious as to not send the internal components flying.
      댓글 쓰기
    3. Nerf N-Strike Firestrike Wire Replacement: 5 단계, 이미지 2개 중 1개 Nerf N-Strike Firestrike Wire Replacement: 5 단계, 이미지 2개 중 2개
      • For reassembly, ensure that the chrome nut gets put back in the proper location, signified by the red box.
      • For reassembly, ensure that all the parts are lined up correctly on the dowels, signified by the four orange boxes.
      • For reassembly, note the location of the springs as highlighted in the second photo.
      댓글 쓰기
    1. Nerf N-Strike Firestrike Wire Replacement, Firing Trigger: 6 단계, 이미지 2개 중 1개 Nerf N-Strike Firestrike Wire Replacement, Firing Trigger: 6 단계, 이미지 2개 중 2개
      • Remove the firing trigger by grabbing the trigger with your fingers and pulling it up and out.
      댓글 쓰기
    1. Nerf N-Strike Firestrike Wire Replacement, Laser Trigger: 7 단계, 이미지 2개 중 1개 Nerf N-Strike Firestrike Wire Replacement, Laser Trigger: 7 단계, 이미지 2개 중 2개
      • Remove the laser trigger by grabbing the trigger with your fingers and pulling it up and out.
      댓글 쓰기
    1. Nerf N-Strike Firestrike Wire Replacement, Laser Assembly: 8 단계, 이미지 1개 중 1개
      • Gently pull up on the circuit board located near the gun handle until it separates from the gun.
      • The wire that attaches to the circuit board is also attached to the laser. Be careful not to use excessive force and damage or disconnect the wire.
      댓글 쓰기
    2. Nerf N-Strike Firestrike Wire Replacement: 9 단계, 이미지 3개 중 1개 Nerf N-Strike Firestrike Wire Replacement: 9 단계, 이미지 3개 중 2개 Nerf N-Strike Firestrike Wire Replacement: 9 단계, 이미지 3개 중 3개
      • Grip the circuit board located at the base of the laser with your fingers; rotate it towards the ammo compartment on the blaster until the guide hole is clear of the guide pin.
      • Slide the laser assembly out.
      댓글 쓰기
    1. Nerf N-Strike Firestrike Wire Replacement, Wire: 10 단계, 이미지 2개 중 1개 Nerf N-Strike Firestrike Wire Replacement, Wire: 10 단계, 이미지 2개 중 2개
      • Pinch the clips holding the circuit board to the laser assembly and remove the circuit board.
      댓글 쓰기
    2. Nerf N-Strike Firestrike Wire Replacement: 11 단계, 이미지 1개 중 1개
      • Desolder the wires from the circuit board.
      • The positive wire is attached at the lower left, while the negative wire is attached at the middle of the bottom.
      댓글 쓰기
    3. Nerf N-Strike Firestrike Wire Replacement: 12 단계, 이미지 2개 중 1개 Nerf N-Strike Firestrike Wire Replacement: 12 단계, 이미지 2개 중 2개
      • Use a soldering iron to melt the solder attaching the wires to the circuit board.
      • The positive lead is attached at the middle right of the board, while the negative lead is attached at the bottom right of the board.
      댓글 쓰기
결론
취소: 해당 안내서를 완성하지 않았습니다.
다른 한 분이 해당 안내서를 완성하였습니다.
작성자
2다른 기여자 명과 함께
Hayes Kimball
회원 가입일: 04/19/15
742 평판
안내서 5개를 작성함
Cal Poly, Team 15-6, Amido Spring 2015 Cal Poly, Team 15-6, Amido Spring 2015 회원
CPSU-AMIDO-S15S15G6
3 회원들
안내서 72개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 6
지난 30일: 22
전체 시간: 1,252
