주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Nerf Vortex Vigilon Clip Attachment Replacement
필요한 것
    1. Nerf Vortex Vigilon Clip Attachment Replacement, Removing the slide screws: 1 단계, 이미지 1개 중 1개
      • The two slide pieces hold the orange sight in place. Expect that the sight will come off when you remove the slide pieces.
      • Using a screwdriver, carefully unscrew the three #00 1 cm Phillips screws holding the two slide pieces together.
      • Both sides of the slide will come off when the screws are removed.
      댓글 쓰기
    2. Nerf Vortex Vigilon Clip Attachment Replacement, Removing the slide pieces: 2 단계, 이미지 1개 중 1개
      • Lift both slide pieces off of the gun.
      댓글 쓰기
    1. Nerf Vortex Vigilon Clip Attachment Replacement, Removing the outer screws: 3 단계, 이미지 2개 중 1개 Nerf Vortex Vigilon Clip Attachment Replacement, Removing the outer screws: 3 단계, 이미지 2개 중 2개
      • Remove the twelve #00 1 cm Phillips screws.
      • Because the holes for the screws are deeper than the screw size, some of the screws may not come out even after you have completely unscrewed them. They will come out when you take off the outside cover in the next step, which is okay.
      • Rotate the gun so that the front is facing you to remove the final screw.
      댓글 쓰기
    2. Nerf Vortex Vigilon Clip Attachment Replacement, Removing the outside cover: 4 단계, 이미지 1개 중 1개
      • When removing the cover, the clip attachment and the spring will likely fall out of the gun.
      • Lift the outside cover off of the gun. Only the side where you removed the screws will come off.
      • The magazine will slide down automatically as you remove the cover.
      댓글 쓰기
    1. Nerf Vortex Vigilon Clip Attachment Replacement, Removing the clip attachment: 5 단계, 이미지 2개 중 1개 Nerf Vortex Vigilon Clip Attachment Replacement, Removing the clip attachment: 5 단계, 이미지 2개 중 2개
      • At the top left area of the gun, lift the clip towards you, and it will easily slide out.
      댓글 쓰기
결론
취소: 해당 안내서를 완성하지 않았습니다.
다른 한 분이 해당 안내서를 완성하였습니다.
작성자
2다른 기여자 명과 함께
Cara Pew
회원 가입일: 09/29/14
932 평판
안내서 7개를 작성함
Cal Poly, Team 13-6, Forte Fall 2014 Cal Poly, Team 13-6, Forte Fall 2014 회원
CPSU-FORTE-F14S13G6
5 회원들
안내서 7개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 7
지난 30일: 26
전체 시간: 1,489
