주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Nest IQ Outdoor Camera Module Disassembly
필요한 것
    1. Nest IQ Outdoor Camera Module Disassembly, Prepare Camera: 1 단계, 이미지 1개 중 1개
      • Remove the power cord and set the camera firmly on your table.
      댓글 쓰기
    2. Nest IQ Outdoor Camera Module Disassembly, Open camera seal: 2 단계, 이미지 3개 중 1개 Nest IQ Outdoor Camera Module Disassembly, Open camera seal: 2 단계, 이미지 3개 중 2개 Nest IQ Outdoor Camera Module Disassembly, Open camera seal: 2 단계, 이미지 3개 중 3개
      • This step requires significant force, and has a chance of damaging your device. It takes around 10-minutes of creating gaps and prying to get it off. Perform at your own risk!
      • Carefully insert an iFixit "Jimmy" Tool (flat flexible steel blade) between the hard white plastic housing and edge of the LED light ring.
      • Pry the "Jimmy" tool slightly sideways and insert an iFixit "Metal Spudger" into the gap created. Slide it down inside the housing around half an inch.
      • Use the metal spudger to pry carefully slowly working your way in a circle around the LED Light ring to attempt to slowly work it backwards out of the housing.
      • There is glue holding down the led light ring, so it might take some decent force to pry it, (see third photo).
      • The LED Ring is sealed in place tightly using a rubber gasket, (see photo in next step).
      댓글 쓰기
    3. Nest IQ Outdoor Camera Module Disassembly, Remove the LED Ring: 3 단계, 이미지 3개 중 1개 Nest IQ Outdoor Camera Module Disassembly, Remove the LED Ring: 3 단계, 이미지 3개 중 2개 Nest IQ Outdoor Camera Module Disassembly, Remove the LED Ring: 3 단계, 이미지 3개 중 3개
      • Verify all connectors are unplugged before continuing with this guide.
      • Take care prying as there are three ribbon cables attached to the led light ring. Two for microphones, and one for the status LED. They are connected at the Camera Module and the components are lightly attached using some double-sided tape to the LED Light Ring.
      댓글 쓰기
    4. Nest IQ Outdoor Camera Module Disassembly, Remove plastic camera securing ring: 4 단계, 이미지 3개 중 1개 Nest IQ Outdoor Camera Module Disassembly, Remove plastic camera securing ring: 4 단계, 이미지 3개 중 2개 Nest IQ Outdoor Camera Module Disassembly, Remove plastic camera securing ring: 4 단계, 이미지 3개 중 3개
      • Remove each of the four screws securing the plastic ring that is holding down the camera module.
      • Pull the camera module upwards, and remove the black ring from around it by pulling it upward and over the camera module.
      • Be careful not to knock into the metal wifi "fins" that stick up right next to where the black plastic ring sits. If things feel stuck, pause and verify it is not caught up.
      • Reminders
      • 4 x 4.5(?)mm Torx T5 screws
      댓글 쓰기
    5. Nest IQ Outdoor Camera Module Disassembly, Unplug LED ZIF Connector: 5 단계, 이미지 3개 중 1개 Nest IQ Outdoor Camera Module Disassembly, Unplug LED ZIF Connector: 5 단계, 이미지 3개 중 2개 Nest IQ Outdoor Camera Module Disassembly, Unplug LED ZIF Connector: 5 단계, 이미지 3개 중 3개
      • Lift the camera module up and out of the housing.
      • Using your fingernail pull down on the black portion of the ZIF connector to flip it into the down position.
      • Slide the LED ribbon cable out of the ZIF connector.
      • You should not have to use ANY force at all to remove the ribbon cable. If you find yourself using force, pause and verify you have flipped down the ZIF connector properly.
      댓글 쓰기
    6. Nest IQ Outdoor Camera Module Disassembly, Unplug the Camera: 6 단계, 이미지 3개 중 1개 Nest IQ Outdoor Camera Module Disassembly, Unplug the Camera: 6 단계, 이미지 3개 중 2개 Nest IQ Outdoor Camera Module Disassembly, Unplug the Camera: 6 단계, 이미지 3개 중 3개
      • Using a flat plastic spudger push upwards on the black portion of the ZIF connector to flip it into the up position.
      • Slide the camera ribbon cable out from the connector.
      댓글 쓰기
    7. Nest IQ Outdoor Camera Module Disassembly, Set the camera module aside: 7 단계, 이미지 3개 중 1개 Nest IQ Outdoor Camera Module Disassembly, Set the camera module aside: 7 단계, 이미지 3개 중 2개 Nest IQ Outdoor Camera Module Disassembly, Set the camera module aside: 7 단계, 이미지 3개 중 3개
      • You can now set the camera module aside, if you wish to disassemble it further do so at your own risk.
      댓글 쓰기
    8. Nest IQ Outdoor Camera Module Disassembly, Remove Motherboard Module screws: 8 단계, 이미지 2개 중 1개 Nest IQ Outdoor Camera Module Disassembly, Remove Motherboard Module screws: 8 단계, 이미지 2개 중 2개
      • Remove the 4 long screws holding the motherboard module into the camera.
      • Screws used
      • 4 x 31mm Torx T9H screw
      댓글 쓰기
    9. Nest IQ Outdoor Camera Module Disassembly, Unplug power connector: 9 단계, 이미지 2개 중 1개 Nest IQ Outdoor Camera Module Disassembly, Unplug power connector: 9 단계, 이미지 2개 중 2개
      • Using your fingers unplug the power connector by gently pulling upwards on the cable until the connector comes out of its socket.
      댓글 쓰기
    10. Nest IQ Outdoor Camera Module Disassembly, Unplug speaker connector: 10 단계, 이미지 2개 중 1개 Nest IQ Outdoor Camera Module Disassembly, Unplug speaker connector: 10 단계, 이미지 2개 중 2개
      이 단계에 사용된 도구:
      • Unplug the speaker connector next to the power connector by gripping it with metal tweezers and gently pulling directly upward.
      댓글 쓰기
    11. Nest IQ Outdoor Camera Module Disassembly, Lift Power Transfer Pad: 11 단계, 이미지 2개 중 1개 Nest IQ Outdoor Camera Module Disassembly, Lift Power Transfer Pad: 11 단계, 이미지 2개 중 2개
      • Using the flat spudger slide it under the power transfer pad to separate the glue holding the pad down.
      • Fold it up out of the way.
      댓글 쓰기
    12. Nest IQ Outdoor Camera Module Disassembly, Lift Motherboard Module Out: 12 단계, 이미지 3개 중 1개 Nest IQ Outdoor Camera Module Disassembly, Lift Motherboard Module Out: 12 단계, 이미지 3개 중 2개 Nest IQ Outdoor Camera Module Disassembly, Lift Motherboard Module Out: 12 단계, 이미지 3개 중 3개
      • Using both hands, gently pull upwards making sure the power cable, speaker cable, and power pad route down through/around the motherboard module as you pull it upward.
      댓글 쓰기
    13. Nest IQ Outdoor Camera Module Disassembly, Remove Speaker Module Screws: 13 단계, 이미지 3개 중 1개 Nest IQ Outdoor Camera Module Disassembly, Remove Speaker Module Screws: 13 단계, 이미지 3개 중 2개 Nest IQ Outdoor Camera Module Disassembly, Remove Speaker Module Screws: 13 단계, 이미지 3개 중 3개
      • The spring that is under this module is quite powerful. While removing screws you must press down with significant force in order to remove the screws. If you do not hold down the module, it will be much more difficult to remove the screws.
      • Remove the three screws holding down the speaker module.
      • Screws Used
      • 3 x Torx T9 4.5(?)mm Screws
      댓글 쓰기
    14. Nest IQ Outdoor Camera Module Disassembly, Remove Speaker Module: 14 단계, 이미지 3개 중 1개 Nest IQ Outdoor Camera Module Disassembly, Remove Speaker Module: 14 단계, 이미지 3개 중 2개 Nest IQ Outdoor Camera Module Disassembly, Remove Speaker Module: 14 단계, 이미지 3개 중 3개
      • Lift the Speaker Module and Spring out of the case, threading the power cable down through the middle.
      • Because this was a dead unit being disassembled there is water damage on the bottom of this speaker module.
      댓글 쓰기
    15. Nest IQ Outdoor Camera Module Disassembly, Remove Power Board Screws: 15 단계, 이미지 3개 중 1개 Nest IQ Outdoor Camera Module Disassembly, Remove Power Board Screws: 15 단계, 이미지 3개 중 2개 Nest IQ Outdoor Camera Module Disassembly, Remove Power Board Screws: 15 단계, 이미지 3개 중 3개
      • Bend/move the power cable to the side and remove each of the two screws holding down the Power Board.
      • Screws Used
      • 2 x Torx T5 3(?)mm screws
      • Performing Step 16 first can make this step easier.
      댓글 쓰기
    16. Nest IQ Outdoor Camera Module Disassembly, Remove Power Cord Housing: 16 단계, 이미지 3개 중 1개 Nest IQ Outdoor Camera Module Disassembly, Remove Power Cord Housing: 16 단계, 이미지 3개 중 2개 Nest IQ Outdoor Camera Module Disassembly, Remove Power Cord Housing: 16 단계, 이미지 3개 중 3개
      • Using a pair of metal tweezers push on the two pink rubber bits on the top of the power cord housing and push downwards to slide the power cord out of the housing.
      • The power connector has a pretty tight fit at the top of the power cord housing, take care when trying to push the power connector through.
      댓글 쓰기
    17. Nest IQ Outdoor Camera Module Disassembly, Remove Power Board: 17 단계, 이미지 3개 중 1개 Nest IQ Outdoor Camera Module Disassembly, Remove Power Board: 17 단계, 이미지 3개 중 2개 Nest IQ Outdoor Camera Module Disassembly, Remove Power Board: 17 단계, 이미지 3개 중 3개
      • Using a heat gun melt the glue holding down the power board. The glue is placed directly under where the previous two screws were removed.
      • Using a thin tool (ideally a Male USB-C connector affixed to a rod) press out the power module. I do use the thinnest flathead screwdriver here to push on it, however this will likely damage the connector.
      • If attempting board level repair on the power board, use extreme care and caution pushing out the power board to prevent damaging the connector.
      • There is a thick slightly soft black goo covering a majority of the power board. It holds down the metal shield very tightly. It is unknown how to remove this black "goo", please leave a comment if you can get it off cleanly!
      댓글 쓰기
    18. Nest IQ Outdoor Camera Module Disassembly: 18 단계, 이미지 1개 중 1개
      • Remove the final two screws to release the base ball joint from the inside of the housing.
      • Screws Used
      댓글 쓰기
    19. Nest IQ Outdoor Camera Module Disassembly, Disassembly Complete!: 19 단계, 이미지 1개 중 1개
      • You are now done disassembling the unit to the module level!
      댓글 쓰기
결론
The Camera module and LED Ring should first be connected together with the microphones and status LED properly glued to the back of the LED Ring and the connectors are attached to the camera module.
When “re-sealing” the camera the Camera LED Ring combo assembly should be attached to the ribbon cables, then pressed/snapped down into place (into the black plastic ring with clips that hold down the camera module).
취소: 해당 안내서를 완성하지 않았습니다.
다른 11명이 해당 안내서를 완성하였습니다.
작성자
2다른 기여자 명과 함께
Sky Young
회원 가입일: 06/28/18
920 평판
안내서 2개를 작성함
19가이드 댓글
my power board has water damage. I'm trying to remove the board and direct wire it. any suggestions?
Mike Noerper - 답글 공유
My power board also has water damage! Did you have any luck repairing yours? Cheers
If I cannot repair my power adapter, I'm considering parting mine out as there seems to be zero parts available.
Jeff Prouty - 답글 공유
I can't find the video link
fixit - 답글 공유
Do you have the link to the video available?
I will be attempting a tear down in a few weeks; wish me luck.
brioquery - 답글 공유
Does anyone know where to buy parts etc, also my camera just turned off one day and will not turn back one if there a fix if I strip it please help me 😊
Adam Westerman - 답글 공유
댓글 쓰기
조회 통계:
지난 24시간: 6
지난 7일: 35
지난 30일: 131
전체 시간: 9,441
