주요 콘텐츠로 건너뛰기
Nest x Yale Lock Deadbolt Button Replacement
필요한 것
  1. Nest x Yale Lock Deadbolt Button Replacement, Motherboard: 1 단계, 이미지 1개 중 1개
    • Before proceeding, make sure the batteries are removed to avoid being electrocuted and damage to the lock
    • If you do not know how to remove the batteries then I would recommend looking at our battery replacement guide for help.
  2. Nest x Yale Lock Deadbolt Button Replacement: 2 단계, 이미지 2개 중 1개 Nest x Yale Lock Deadbolt Button Replacement: 2 단계, 이미지 2개 중 2개
    • Remove 3 screws as shown to remove the first cover.
    • The 3 screws are 0.25 inches length
  3. Nest x Yale Lock Deadbolt Button Replacement: 3 단계, 이미지 1개 중 1개
    • Using a pin to push down the knot holding the wire and the tweezer to safely remove the wire from the motherboard
  4. Nest x Yale Lock Deadbolt Button Replacement: 4 단계, 이미지 2개 중 1개 Nest x Yale Lock Deadbolt Button Replacement: 4 단계, 이미지 2개 중 2개
    이 단계에 사용된 도구:
    • Use a spudger or plastic tool to lift the ZIF lock upward (as shown in the first picture).
    • Use tweezers to remove the ribbon cable from the motherboard.
  5. Nest x Yale Lock Deadbolt Button Replacement: 5 단계, 이미지 1개 중 1개
    • Continue to remove 2 screws holding the motherboard to the lock shell.
    • The screws are 0.20 inches in length.
  6. Nest x Yale Lock Deadbolt Button Replacement: 6 단계, 이미지 2개 중 1개 Nest x Yale Lock Deadbolt Button Replacement: 6 단계, 이미지 2개 중 2개
    • Use an opening tool to push the motherboard out as shown in the picture.
  7. Nest x Yale Lock Deadbolt Button Replacement, Deadbolt Button: 7 단계, 이미지 2개 중 1개 Nest x Yale Lock Deadbolt Button Replacement, Deadbolt Button: 7 단계, 이미지 2개 중 2개
    • After, fully removing the motherboard.
    • Remove the .25 in screws circled in red to remove the lock compartment.
    • Lastly, take out the lock as shown in the second picture.
  8. Nest x Yale Lock Deadbolt Button Replacement: 8 단계, 이미지 1개 중 1개
    • Move onto removing the .25 inches screws in red to take out the battery holder.
    • Remove the .15 inches screws in orange as well.
  9. Nest x Yale Lock Deadbolt Button Replacement: 9 단계, 이미지 2개 중 1개 Nest x Yale Lock Deadbolt Button Replacement: 9 단계, 이미지 2개 중 2개
    • After unscrewing the battery holder you can now see the lights circled in red
    • The part squared in orange is a rubber that reflects the light of the LED.
결론
작성자
3다른 기여자 명과 함께
Christopher Gonzalez
회원 가입일: 09/26/22
313 평판
안내서 3개를 작성함
CSU Los Angeles, Team 5-3, Adachi Fall 2022 CSU Los Angeles, Team 5-3, Adachi Fall 2022 회원
CSULA-ADACHI-F22S5G3
5 회원들
안내서 5개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 6
지난 7일: 7
지난 30일: 19
전체 시간: 752
