주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Nextbook 8 Camera Replacement
필요한 것
    1. Nextbook 8 Camera Replacement, Battery: 1 단계, 이미지 2개 중 1개 Nextbook 8 Camera Replacement, Battery: 1 단계, 이미지 2개 중 2개
      • Use the plastic opening tool to remove the back cover. Carefully slide the tool between the front glass and back cover.
      • Slide the tool along the edge to work the back cover off.
      • It helps to have an extra tool to stick in the gap and keep the back cover separated from the glass as you slide the other tool.
      댓글 쓰기
    2. Nextbook 8 Camera Replacement: 2 단계, 이미지 2개 중 1개 Nextbook 8 Camera Replacement: 2 단계, 이미지 2개 중 2개
      • Remove the tape covering the motherboard.
      • Remove the silver tape holding the white ribbon cables to the battery.
      댓글 쓰기
    3. Nextbook 8 Camera Replacement: 3 단계, 이미지 2개 중 1개 Nextbook 8 Camera Replacement: 3 단계, 이미지 2개 중 2개
      • Use a spudger to carefully disconnect the battery connector from the motherboard.
      • When working with electronics, it's important to choose a tool that's ESD-safe to avoid accidental damage to the device. The regular black nylon spudger or a plastic opening tool should be used whenever possible.
      댓글 쓰기
    4. Nextbook 8 Camera Replacement: 4 단계, 이미지 1개 중 1개
      이 단계에 사용된 도구:
      • Use a spudger to lift up the black bar on the two ZIF connectors located above the battery.
      • Pull the ribbon cables out of the connectors with tweezers or two fingers.
      댓글 쓰기
    5. Nextbook 8 Camera Replacement: 5 단계, 이미지 2개 중 1개 Nextbook 8 Camera Replacement: 5 단계, 이미지 2개 중 2개
      • Using the flat end of a spudger, carefully work the spudger under the battery, lifting it off of the device.
      • The battery is very malleable, so do not try to pull it off all at once.
      댓글 쓰기
    1. Nextbook 8 Camera Replacement, Camera: 6 단계, 이미지 1개 중 1개
      • Slowly pull up masking tape by pulling down from the top.
      • Be careful because both the front and rear cameras are attached to each other.
      댓글 쓰기
    2. Nextbook 8 Camera Replacement: 7 단계, 이미지 1개 중 1개
      • Peel the bottom part of the masking tape off to reveal the ribbon connector.
      댓글 쓰기
    3. Nextbook 8 Camera Replacement: 8 단계, 이미지 1개 중 1개
      • Pull both camera lenses out of the holes.
      댓글 쓰기
    4. Nextbook 8 Camera Replacement: 9 단계, 이미지 1개 중 1개
      • Use a spudger to disconnect the two camera lenses from the device.
      • Carefully lift the black connector to release the cameras.
      댓글 쓰기
    5. Nextbook 8 Camera Replacement: 10 단계, 이미지 1개 중 1개
      • Pull both camera lenses out of the ribbon connector.
      댓글 쓰기
결론
취소: 해당 안내서를 완성하지 않았습니다.
작성자
1다른 기여자 명과 함께
Dylan Wiese
회원 가입일: 03/11/15
1,889 평판
안내서 5개를 작성함
Colorado Springs, Team 5-1, Panko Spring 2015 Colorado Springs, Team 5-1, Panko Spring 2015 회원
UCCS-PANKO-S15S5G1
3 회원들
안내서 10개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 1
지난 7일: 8
지난 30일: 34
전체 시간: 1,604
