주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Nextbook NXA116QC164 Display Assembly Replacement
    1. Nextbook NXA116QC164 Display Assembly Replacement, Detach Old Display Assembly: 1 단계, 이미지 2개 중 1개 Nextbook NXA116QC164 Display Assembly Replacement, Detach Old Display Assembly: 1 단계, 이미지 2개 중 2개
      • Use a pick and an opening tool here rather than your fingernail.
      • The blue plastic is part of the display assembly, so be sure to lift up under that.
      • DO NOT PRY UNDER THE GLASS
      댓글 쓰기
    2. Nextbook NXA116QC164 Display Assembly Replacement, Disconnect Battery: 2 단계, 이미지 1개 중 1개
      • I forgot to disconnect the battery, don't make the same mistake.
      • I believe that the connector inside the pink outline (see image) is the battery connector that must be unplugged.
      댓글 쓰기
    3. Nextbook NXA116QC164 Display Assembly Replacement, Unscrew logic board: 3 단계, 이미지 3개 중 1개 Nextbook NXA116QC164 Display Assembly Replacement, Unscrew logic board: 3 단계, 이미지 3개 중 2개 Nextbook NXA116QC164 Display Assembly Replacement, Unscrew logic board: 3 단계, 이미지 3개 중 3개
      • Each screw is pretty similar, so it is not the end of the world if you mix one of these up.
      • However, the two screws that hold down the keyboard smart connector (green outline) are different.
      댓글 쓰기
    4. Nextbook NXA116QC164 Display Assembly Replacement, Detach Keyboard Smart Connector: 4 단계, 이미지 2개 중 1개 Nextbook NXA116QC164 Display Assembly Replacement, Detach Keyboard Smart Connector: 4 단계, 이미지 2개 중 2개
      • Keep these screws apart from the others!
      • As shown, part of the ribbon cable may be glued down. Use a spudger tool and CAREFULLY lift up. Don't rush.
      댓글 쓰기
    5. Nextbook NXA116QC164 Display Assembly Replacement, Detach Webcams: 5 단계, 이미지 3개 중 1개 Nextbook NXA116QC164 Display Assembly Replacement, Detach Webcams: 5 단계, 이미지 3개 중 2개 Nextbook NXA116QC164 Display Assembly Replacement, Detach Webcams: 5 단계, 이미지 3개 중 3개
      이 단계에 사용된 도구:
      • The front facing camera can easily come out by prying it up with a plastic tool.
      • The rear facing camera is glued down and needs a little more elbow grease to unstick. If you're lucky, it'll remain sticky and can be reapplied on the new assembly.
      • TRANSFER PLASTIC SQUARE TO NEW ASSEMBLY
      • Using tweezers, the plastic square under the rear facing webcam (only) should be peeled up and transferred to the new assembly.
      • Use a plastic spudger tool to push down the new square if there is enough adhesive left to stick it. If not, use double-sided tape.
      댓글 쓰기
    6. Nextbook NXA116QC164 Display Assembly Replacement, Detach Speakers: 6 단계, 이미지 3개 중 1개 Nextbook NXA116QC164 Display Assembly Replacement, Detach Speakers: 6 단계, 이미지 3개 중 2개 Nextbook NXA116QC164 Display Assembly Replacement, Detach Speakers: 6 단계, 이미지 3개 중 3개
      • The right speaker can be pulled up however, it may rip the adhesive sticker. If this occurs, reapplying the bottom of the sticker to the new assembly and adding a drop of superglue will hold it back in place.
      • The left speaker can be lifted up when you lift up the rest of the logic board housing later.
      댓글 쓰기
    7. Nextbook NXA116QC164 Display Assembly Replacement, Disconnect display ribbon cable & power/volume ribbon cable: 7 단계, 이미지 3개 중 1개 Nextbook NXA116QC164 Display Assembly Replacement, Disconnect display ribbon cable & power/volume ribbon cable: 7 단계, 이미지 3개 중 2개 Nextbook NXA116QC164 Display Assembly Replacement, Disconnect display ribbon cable & power/volume ribbon cable: 7 단계, 이미지 3개 중 3개
      • The larger ribbon cable uses a ZIF style connector. Use an opening tool in order to pry it up safely.
      • The power and volume ribbon cable leads to the buttons at the top right of the assembly. This strip of buttons has adhesive on the bottom and should be lifted up carefully as to not bend it.
      • Transfer the strip to the new assembly using the guide holes. (See next step)
      댓글 쓰기
    8. Nextbook NXA116QC164 Display Assembly Replacement, Remove logic board housing (and button strip): 8 단계, 이미지 2개 중 1개 Nextbook NXA116QC164 Display Assembly Replacement, Remove logic board housing (and button strip): 8 단계, 이미지 2개 중 2개
      • Start lifting up the entire logic board here. Use a spudger if needed.
      • Notice here at the top right of the tablet is the button strip to be lifted up.
      • Remove and add this strip to the new assembly.
      댓글 쓰기
    9. Nextbook NXA116QC164 Display Assembly Replacement, Remove LCD brackets.: 9 단계, 이미지 3개 중 1개 Nextbook NXA116QC164 Display Assembly Replacement, Remove LCD brackets.: 9 단계, 이미지 3개 중 2개 Nextbook NXA116QC164 Display Assembly Replacement, Remove LCD brackets.: 9 단계, 이미지 3개 중 3개
      • Remove the four LCD brackets that hold the LCD display in place.
      • Each bracket appears to be similar and reversible thus, mixing them up is not an issue.
      댓글 쓰기
    10. Nextbook NXA116QC164 Display Assembly Replacement, Replace plastic piece for LED light(?): 10 단계, 이미지 2개 중 1개 Nextbook NXA116QC164 Display Assembly Replacement, Replace plastic piece for LED light(?): 10 단계, 이미지 2개 중 2개
      • If your new assembly does not have this plastic piece, replace it.
      • You may need to apply new adhesive if the old one is not usable.
      • Second image shows new assembly on the left.
      댓글 쓰기
결론
취소: 해당 안내서를 완성하지 않았습니다.
다른 6명이 해당 안내서를 완성하였습니다.
작성자
2다른 기여자 명과 함께
Hello Goodbye
회원 가입일: 12/21/17
351 평판
안내서 1개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 2
지난 7일: 7
지난 30일: 38
전체 시간: 1,165
