주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Nextbook NXA8QC116B Front Camera Replacement
필요한 것
    1. Nextbook NXA8QC116B Front Camera Replacement, Battery: 1 단계, 이미지 3개 중 1개 Nextbook NXA8QC116B Front Camera Replacement, Battery: 1 단계, 이미지 3개 중 2개 Nextbook NXA8QC116B Front Camera Replacement, Battery: 1 단계, 이미지 3개 중 3개
      • If you see any leakage coming from the tablet do not open the back cover!
      • Ensure you do not pry around the buttons. This could result in damage and render them inoperable.
      • •With the tip of the thin metal spudger in place, use a prying motion to work the spudger down the side to the corner of the device.
      댓글 쓰기
    2. Nextbook NXA8QC116B Front Camera Replacement: 2 단계, 이미지 2개 중 1개 Nextbook NXA8QC116B Front Camera Replacement: 2 단계, 이미지 2개 중 2개
      • Continue working the spudger downward and pry with the spudger until the bottom left-hand corner of the tablet is reached.
      댓글 쓰기
    3. Nextbook NXA8QC116B Front Camera Replacement: 3 단계, 이미지 3개 중 1개 Nextbook NXA8QC116B Front Camera Replacement: 3 단계, 이미지 3개 중 2개 Nextbook NXA8QC116B Front Camera Replacement: 3 단계, 이미지 3개 중 3개
      • Along the bottom of the tablet, keep using a working and prying motion with the spudger to loosen the cover.
      댓글 쓰기
    4. Nextbook NXA8QC116B Front Camera Replacement: 4 단계, 이미지 3개 중 1개 Nextbook NXA8QC116B Front Camera Replacement: 4 단계, 이미지 3개 중 2개 Nextbook NXA8QC116B Front Camera Replacement: 4 단계, 이미지 3개 중 3개
      • Continue prying motion until the bottom right-hand corner of the tablet is reached.
      댓글 쓰기
    5. Nextbook NXA8QC116B Front Camera Replacement: 5 단계, 이미지 2개 중 1개 Nextbook NXA8QC116B Front Camera Replacement: 5 단계, 이미지 2개 중 2개
      • Work the spudger to the upper left-hand corner of the tablet.
      댓글 쓰기
    6. Nextbook NXA8QC116B Front Camera Replacement: 6 단계, 이미지 3개 중 1개 Nextbook NXA8QC116B Front Camera Replacement: 6 단계, 이미지 3개 중 2개 Nextbook NXA8QC116B Front Camera Replacement: 6 단계, 이미지 3개 중 3개
      • Be careful once you get to the top of the tablet with the spudger so as not to damage the headphone jack and other ports.
      • When prying along the top of the tablet, try to keep the spudger between 70 to 85 degrees (almost perpendicular) to the tablet screen.
      • Continue working the spudger around the tablet until the cover of the device comes off
      댓글 쓰기
    7. Nextbook NXA8QC116B Front Camera Replacement: 7 단계, 이미지 2개 중 1개 Nextbook NXA8QC116B Front Camera Replacement: 7 단계, 이미지 2개 중 2개
      • Separate from the cover from the tablet.
      댓글 쓰기
    8. Nextbook NXA8QC116B Front Camera Replacement: 8 단계, 이미지 3개 중 1개 Nextbook NXA8QC116B Front Camera Replacement: 8 단계, 이미지 3개 중 2개 Nextbook NXA8QC116B Front Camera Replacement: 8 단계, 이미지 3개 중 3개
      • Locate and carefully remove the yellow cellophane tape from the red and black speaker wires that connect the speaker to the edge of the motherboard.
      댓글 쓰기
    9. Nextbook NXA8QC116B Front Camera Replacement: 9 단계, 이미지 2개 중 1개 Nextbook NXA8QC116B Front Camera Replacement: 9 단계, 이미지 2개 중 2개
      이 단계에 사용된 도구:
      • Locate and carefully remove the yellow cellophane tape with tweezers from the battery connector and black and red speaker wires on the edge of the motherboard.
      댓글 쓰기
    10. Nextbook NXA8QC116B Front Camera Replacement: 10 단계, 이미지 3개 중 1개 Nextbook NXA8QC116B Front Camera Replacement: 10 단계, 이미지 3개 중 2개 Nextbook NXA8QC116B Front Camera Replacement: 10 단계, 이미지 3개 중 3개
      • Using small pliers, carefully disconnect the male battery connector from the motherboard.
      • If you are only replacing the front camera, skip to step 17 in the camera replacement guide and continue.
      댓글 쓰기
    11. Nextbook NXA8QC116B Front Camera Replacement: 11 단계, 이미지 1개 중 1개
      • If the battery is leaking or bulging, stop and get away from it!
      • Carefully remove the gray square pad glued to both the white ribbon cable and the battery by pulling slowly.
      댓글 쓰기
    12. Nextbook NXA8QC116B Front Camera Replacement: 12 단계, 이미지 1개 중 1개
      • Locate the white ribbon cable Zero Insertion Force (ZIF) connector between the battery and the motherboard, and peel the yellow cellophane tape off the connector.
      댓글 쓰기
    13. Nextbook NXA8QC116B Front Camera Replacement: 13 단계, 이미지 2개 중 1개 Nextbook NXA8QC116B Front Camera Replacement: 13 단계, 이미지 2개 중 2개
      • Flip up the gray retainer clip on the white ribbon cable ZIF connector on the motherboard with your fingernail. If you do not have fingernails long enough, carefully use a black plastic spudger.
      댓글 쓰기
    14. Nextbook NXA8QC116B Front Camera Replacement: 14 단계, 이미지 3개 중 1개 Nextbook NXA8QC116B Front Camera Replacement: 14 단계, 이미지 3개 중 2개 Nextbook NXA8QC116B Front Camera Replacement: 14 단계, 이미지 3개 중 3개
      • Remove the white ribbon cable and carefully peel it off the battery.
      댓글 쓰기
    15. Nextbook NXA8QC116B Front Camera Replacement: 15 단계, 이미지 3개 중 1개 Nextbook NXA8QC116B Front Camera Replacement: 15 단계, 이미지 3개 중 2개 Nextbook NXA8QC116B Front Camera Replacement: 15 단계, 이미지 3개 중 3개
      • Move the spudger in a left-to-right scraping motion to loosen the glue until the battery is separated from the tablet.
      댓글 쓰기
    16. Nextbook NXA8QC116B Front Camera Replacement: 16 단계, 이미지 1개 중 1개
      • Remove the battery.
      댓글 쓰기
    1. Nextbook NXA8QC116B Front Camera Replacement, Front Camera: 17 단계, 이미지 1개 중 1개
      • Locate the front camera on the upper left-hand corner
      댓글 쓰기
    2. Nextbook NXA8QC116B Front Camera Replacement: 18 단계, 이미지 2개 중 1개 Nextbook NXA8QC116B Front Camera Replacement: 18 단계, 이미지 2개 중 2개
      이 단계에 사용된 도구:
      • Remove the yellow cellophane tape with the tweezers from the ZIF connector.
      댓글 쓰기
    3. Nextbook NXA8QC116B Front Camera Replacement: 19 단계, 이미지 2개 중 1개 Nextbook NXA8QC116B Front Camera Replacement: 19 단계, 이미지 2개 중 2개
      • Using your fingernail, flip up the ZIF connector retainer. If you do not have fingernails long enough, use the black plastic spudger.
      댓글 쓰기
    4. Nextbook NXA8QC116B Front Camera Replacement: 20 단계, 이미지 2개 중 1개 Nextbook NXA8QC116B Front Camera Replacement: 20 단계, 이미지 2개 중 2개
      • Be careful when removing the camera. The underside of the camera head has adhesive and may be adhered to the tablet. If this happens, use the black plastic spudger to carefully pry up on the underside of the camera head to loosen it from the tablet before pulling on the ribbon cable with the tweezers.
      • Use tweezers to remove the front camera by pulling.
      댓글 쓰기
결론
취소: 해당 안내서를 완성하지 않았습니다.
다른 한 분이 해당 안내서를 완성하였습니다.
작성자
6다른 기여자 명과 함께
Robert Englehardt
회원 가입일: 09/27/17
682 평판
안내서 5개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 2
지난 7일: 7
지난 30일: 30
전체 시간: 585
