주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Nexus 4 Battery Replacement
필요한 것
  1. Nexus 4 Battery Replacement, Back Cover: 1 단계, 이미지 2개 중 1개 Nexus 4 Battery Replacement, Back Cover: 1 단계, 이미지 2개 중 2개
    이 단계에 사용된 도구:
    SIM Card Eject Tool
    $2.99
    • Power off the phone, by long-pressing the power button and touching Power off.
    • Remove the SIM tray using the SIM Card Eject Tool.
    • This step is required in order to remove the back case.
    댓글 쓰기
  2. Nexus 4 Battery Replacement: 2 단계, 이미지 1개 중 1개
    이 단계에 사용된 도구:
    T5 Torx Screwdriver
    $5.49
    댓글 쓰기
  3. Nexus 4 Battery Replacement: 3 단계, 이미지 3개 중 1개 Nexus 4 Battery Replacement: 3 단계, 이미지 3개 중 2개 Nexus 4 Battery Replacement: 3 단계, 이미지 3개 중 3개
    • Gently open the back case by prying along the edge of the cover, starting at a corner of the phone and circling around the phone using a plastic opening tool.
    • The opening process may take a few minutes. The plastic will make a light snapping noise as the back cover separates from the rest of the phone.
    댓글 쓰기
  4. Nexus 4 Battery Replacement, Battery: 4 단계, 이미지 2개 중 1개 Nexus 4 Battery Replacement, Battery: 4 단계, 이미지 2개 중 2개
    • Remove the two 1.8 mm Phillips screws holding down the battery connector.
    • Using a plastic opening tool, disconnect the battery cable from its socket on the motherboard.
    댓글 쓰기
  5. Nexus 4 Battery Replacement, Battery removal: 5 단계, 이미지 2개 중 1개 Nexus 4 Battery Replacement, Battery removal: 5 단계, 이미지 2개 중 2개
    이 단계에 사용된 도구:
    Plastic Cards
    $2.99
    • Remove the blue tape that secures the white antenna cable to the battery.
    • Using a spudger, carefully disconnect the white antenna cable.
    • Carefully pry the battery out with a Plastic Opening Tool, starting at the top left-hand corner and working down towards the bottom right-hand corner.
    • If necessary, you can also use a plastic card to separate the battery from the metal midframe.
    • The battery is securely glued to the phone. When reinstalling the battery, press the battery firmly against the adhesive strip.
    댓글 쓰기
결론
To reassemble your device, follow these instructions in reverse order. Start by seating the top of the back to the phone, then gently snap the back in place working from the top to the bottom.
취소: 해당 안내서를 완성하지 않았습니다.
다른 153명이 해당 안내서를 완성하였습니다.
작성자
17다른 기여자 명과 함께
Kaitlyn Jones
회원 가입일: 01/27/13
4,964 평판
안내서 8개를 작성함
Cal Poly, Team 3-32, Amido Winter 2013 Cal Poly, Team 3-32, Amido Winter 2013 회원
CPSU-AMIDO-W13S3G32
4 회원들
안내서 24개를 작성함
14가이드 댓글
I have made some arrangement to clarify particularly using pictures from the teardown that are just perfect. The original picture was not detailed and did not show the battery in place.
Gaetan - 답글 공유
If you can't power on after battery replace:
Charge for an hour
Try holding down power plus volume down while plugging in power
If that doesn't work replug inside battery connector (this fixed for me)
Recommend data backup before in case you can't get it booting.
Chris Harrow - 답글 공유
Just did this - thanks for all the instructions, easy if you have the right tools
raymondw999 - 답글 공유
followed these instructions and the device boots up OK but then immediately shuts down. getting into recovery mode and checking the logs I can see that the phone thinks the battery is over temperature (790C vs max of 68C). Hopefully it's just a poor connection where I fitted it. I'll take it apart and try again later.
keith.griffiths - 답글 공유
Note that it is very easy to break a screw holding the battery connector - don't over tighten. I've managed to hold down the end of the connector, towards the center of the phone, with a washer fitted to a nearby screw. It's been working fine for 6 months
Rodney - 답글 공유
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 17
지난 30일: 80
전체 시간: 116,656
