주요 콘텐츠로 건너뛰기
Nexus 5X Headphone Jack Replacement
필요한 것
  1. Nexus 5X Headphone Jack Replacement, SIM Card Tray: 1 단계, 이미지 1/3 Nexus 5X Headphone Jack Replacement, SIM Card Tray: 1 단계, 이미지 2/3 Nexus 5X Headphone Jack Replacement, SIM Card Tray: 1 단계, 이미지 3/3
    • Insert a SIM card ejection tool into the hole on the SIM card tray, located on the left edge of the phone.
    • Press in to eject the SIM card tray.
    • Remove the SIM card tray.
  2. Nexus 5X Headphone Jack Replacement, Rear Panel: 2 단계, 이미지 1/3 Nexus 5X Headphone Jack Replacement, Rear Panel: 2 단계, 이미지 2/3 Nexus 5X Headphone Jack Replacement, Rear Panel: 2 단계, 이미지 3/3
    • Place an opening pick in the opening of the SIM card tray slot and twist it sideways to release the first plastic clip that holds the rear panel in its place.
    • Slide the opening pick around the top edge of the phone to release the plastic clips that secure the rear panel.
  3. Nexus 5X Headphone Jack Replacement: 3 단계, 이미지 1/3 Nexus 5X Headphone Jack Replacement: 3 단계, 이미지 2/3 Nexus 5X Headphone Jack Replacement: 3 단계, 이미지 3/3
    • Continue to slide the opening pick around all sides of the phone to release all clips that secure the rear panel.
  4. Nexus 5X Headphone Jack Replacement: 4 단계, 이미지 1/2 Nexus 5X Headphone Jack Replacement: 4 단계, 이미지 2/2
    • Tilt the opening pick to lift the rear panel a little bit.
    • There are two more plastic clips next to the fingerprint sensor. Release them by gently pulling the rear panel.
    • Remove the rear panel.
  5. Nexus 5X Headphone Jack Replacement, Midframe: 5 단계, 이미지 1/1
    • Remove the ten 3.6 mm Phillips screws that secure the midframe.
  6. Nexus 5X Headphone Jack Replacement: 6 단계, 이미지 1/2 Nexus 5X Headphone Jack Replacement: 6 단계, 이미지 2/2
    • Insert an opening pick into the SIM card tray slot and twist the opening pick sideways to release the plastic clips.
  7. Nexus 5X Headphone Jack Replacement: 7 단계, 이미지 1/2 Nexus 5X Headphone Jack Replacement: 7 단계, 이미지 2/2
    • Continue sliding the opening pick around the upper part of the midframe to release the plastic clips.
  8. Nexus 5X Headphone Jack Replacement: 8 단계, 이미지 1/2 Nexus 5X Headphone Jack Replacement: 8 단계, 이미지 2/2
    • Use the plastic pick to pry open the plastic clips on the long edge of the midframe and on the bottom edge.
    • Make sure the clips on the long edge are released. The midframe is prone to break here if they are not disconnected properly.
  9. Nexus 5X Headphone Jack Replacement: 9 단계, 이미지 1/2 Nexus 5X Headphone Jack Replacement: 9 단계, 이미지 2/2
    • Make sure all the clips are free.
    • Carefully remove the midframe.
  10. Nexus 5X Headphone Jack Replacement, Battery Disconnect: 10 단계, 이미지 1/2 Nexus 5X Headphone Jack Replacement, Battery Disconnect: 10 단계, 이미지 2/2
    • Use the edge of a spudger to pry up and disconnect the battery flex cable located at the bottom right of the motherboard.
  11. Nexus 5X Headphone Jack Replacement, Headphone Jack: 11 단계, 이미지 1/1
    • Use an iOpener on the bottom front of the screen for about 30 seconds to loosen the adhesive beneath the headphone jack.
  12. Nexus 5X Headphone Jack Replacement: 12 단계, 이미지 1/3 Nexus 5X Headphone Jack Replacement: 12 단계, 이미지 2/3 Nexus 5X Headphone Jack Replacement: 12 단계, 이미지 3/3
    • Insert the pointed end of a spudger in the opening of the headphone jack.
    • Use the spudger to lever the headphone jack out of its gasket by tilting it upwards.
    • Remove the headphone jack with a pair of tweezers.
결론
Apply new adhesive where it’s necessary.
Repair didn’t go as planned? Check out our Nexus 5X Answers community for troubleshooting help.
다른 한 분이 해당 안내서를 완성하였습니다.
Dominik Schnabelrauch
회원 가입일: 11/23/16
203,353 평판
안내서 682개 작성하였습니다
iFixit iFixit 회원
Staff
135 회원들
안내서 16,817개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 1
30일 전: 2
전체 시간: 608
