주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Nikon COOLPIX S610c LCD Replacement
필요한 것
    1. Nikon COOLPIX S610c LCD Replacement, Battery: 1 단계, 이미지 1개 중 1개
      • On the bottom right of the camera, locate the battery flap switch.
      댓글 쓰기
    2. Nikon COOLPIX S610c LCD Replacement: 2 단계, 이미지 1개 중 1개
      • Move this switch to the right so the battery flap can flip open.
      댓글 쓰기
    3. Nikon COOLPIX S610c LCD Replacement: 3 단계, 이미지 1개 중 1개
      • Slide the orange switch to the right as shown. Now the battery can be pulled out. Reverse these steps to re-install.
      댓글 쓰기
    1. Nikon COOLPIX S610c LCD Replacement, Rear Casing: 4 단계, 이미지 1개 중 1개
      • Remove the three 3x3mm screws attached to the rear casing.
      댓글 쓰기
    2. Nikon COOLPIX S610c LCD Replacement: 5 단계, 이미지 1개 중 1개
      • The panel can be identified by the wifi logo on its upper half on the camera's side.
      • Remove the 5x3mm screw holding down the panel on the side closest to the lens.
      댓글 쓰기
    3. Nikon COOLPIX S610c LCD Replacement: 6 단계, 이미지 1개 중 1개
      • Pry the panel off from the bottom using your fingernail.
      댓글 쓰기
    4. Nikon COOLPIX S610c LCD Replacement: 7 단계, 이미지 1개 중 1개
      • Remove the 3x2mm screw underneath the panel near the top of the camera.
      댓글 쓰기
    5. Nikon COOLPIX S610c LCD Replacement: 8 단계, 이미지 2개 중 1개 Nikon COOLPIX S610c LCD Replacement: 8 단계, 이미지 2개 중 2개
      • Remove the 4x3mm on the opposite side near the selector wheel.
      • Remove the 2x2mm and 3x2mm screws underneath the a/v flap.
      댓글 쓰기
    6. Nikon COOLPIX S610c LCD Replacement: 9 단계, 이미지 2개 중 1개 Nikon COOLPIX S610c LCD Replacement: 9 단계, 이미지 2개 중 2개
      • Pry the back panel away from the body of the camera, using the space you just opened up.
      • Be careful not to damage the ribbon cable on the opposite end of the camera.
      • A small piece of the frame of the camera may fall off, but it can be easily put back into place during reassembly.
      댓글 쓰기
    7. Nikon COOLPIX S610c LCD Replacement: 10 단계, 이미지 2개 중 1개 Nikon COOLPIX S610c LCD Replacement: 10 단계, 이미지 2개 중 2개
      • Pry up the plastic ribbon connectors on the body of the camera to release the ribbon cables.
      • The center connector is detached by flipping the black latch up and away from the center of the camera.
      • The smaller connector is detached by flipping the tan latch up and away from the edge of the camera.
      댓글 쓰기
    1. Nikon COOLPIX S610c LCD Replacement, LCD: 11 단계, 이미지 2개 중 1개 Nikon COOLPIX S610c LCD Replacement, LCD: 11 단계, 이미지 2개 중 2개
      • Pry the display from the rear casing using a spudger.
      댓글 쓰기
결론
취소: 해당 안내서를 완성하지 않았습니다.
작성자
3다른 기여자 명과 함께
Kevin Backers
회원 가입일: 01/26/12
304 평판
안내서 4개를 작성함
Cal Poly, Team 9-5, Regan Winter 2012 Cal Poly, Team 9-5, Regan Winter 2012 회원
CPSU-REGAN-W12S9G5
5 회원들
안내서 12개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 1
지난 7일: 7
지난 30일: 36
전체 시간: 1,030
