주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Nikon Coolpix 3500 Lens Replacement
필요한 것
    1. Nikon Coolpix 3500 Lens Replacement, Battery: 1 단계, 이미지 1개 중 1개
      • Unlatch the battery cover and slide the cover out. Place cover to the side, it will not be needed for the next few steps.
      • Remove the battery.
      • Remove the battery cover without using excessive force. Keep in mind this cover is fragile.
      댓글 쓰기
    1. Nikon Coolpix 3500 Lens Replacement, Front Cover: 2 단계, 이미지 1개 중 1개
      • Remove the two 4.5 mm screws that sit next to the battery slot.
      • Remove the 3 mm screw that sits below the CF card slot.
      • Remove the 4.5 mm screw that sits above the digital I/O cover.
      댓글 쓰기
    2. Nikon Coolpix 3500 Lens Replacement: 3 단계, 이미지 1개 중 1개
      • Remove the two 4.5 mm screws that sit inside the battery slot.
      댓글 쓰기
    3. Nikon Coolpix 3500 Lens Replacement: 4 단계, 이미지 1개 중 1개
      • Remove the two 5 mm screws that sit near the camera strap eyelet.
      • Remove the camera strap eyelet.
      댓글 쓰기
    4. Nikon Coolpix 3500 Lens Replacement: 5 단계, 이미지 1개 중 1개
      • Remove the 5 mm screw and cap that were underneath the camera strap eyelet.
      댓글 쓰기
    5. Nikon Coolpix 3500 Lens Replacement: 6 단계, 이미지 2개 중 1개 Nikon Coolpix 3500 Lens Replacement: 6 단계, 이미지 2개 중 2개
      • Remove the five 3.5 mm screws that sit at the bottom of the camera.
      • Remove the grey plastic piece, which the five screws held in place, by gently detaching the front cover.
      • Do not apply too much force; two wires still connect the front cover to the motherboard.
      댓글 쓰기
    6. Nikon Coolpix 3500 Lens Replacement: 7 단계, 이미지 2개 중 1개 Nikon Coolpix 3500 Lens Replacement: 7 단계, 이미지 2개 중 2개
      • Using a spudger, detach the white-capped wire.
      • Using a spudger, detach the orange-capped wire and set the front cover aside.
      댓글 쓰기
    1. Nikon Coolpix 3500 Lens Replacement, Lens: 8 단계, 이미지 1개 중 1개
      • Disconnect the grey-capped wire from the motherboard.
      • Disconnect the blue wire attached to the green chip from the center of the motherboard.
      댓글 쓰기
    2. Nikon Coolpix 3500 Lens Replacement: 9 단계, 이미지 2개 중 1개 Nikon Coolpix 3500 Lens Replacement: 9 단계, 이미지 2개 중 2개
      • Remove the 3.5 mm screw from the motherboard next to the rotating lens.
      • Invert the motherboard and lens toward the orange and blue wires still connecting the motherboard to the LED screen.
      댓글 쓰기
    3. Nikon Coolpix 3500 Lens Replacement: 10 단계, 이미지 2개 중 1개 Nikon Coolpix 3500 Lens Replacement: 10 단계, 이미지 2개 중 2개
      • Disconnect the blue wire connecting the motherboard to the LED screen.
      • Disconnect the orange wire using a spudger while pushing out horizontally.
      • Disconnect the red capped wire from the motherboard.
      • Lift the motherboard and lens (still connected) out of the back case.
      댓글 쓰기
    4. Nikon Coolpix 3500 Lens Replacement: 11 단계, 이미지 1개 중 1개
      • Lift up on the black covering and remove the orange wire connecting the lens to the motherboard.
      댓글 쓰기
결론
취소: 해당 안내서를 완성하지 않았습니다.
작성자
7다른 기여자 명과 함께
richard guenther
회원 가입일: 04/19/10
183 평판
안내서 6개를 작성함
Cal Poly, Team 30-38, Garner Spring 2010 Cal Poly, Team 30-38, Garner Spring 2010 회원
CPSU-GARNER-S10S30G38
5 회원들
안내서 11개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 1
지난 7일: 8
지난 30일: 37
전체 시간: 3,516
