주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Nikon Coolpix 7900 LCD Screen Replacement
필요한 것
    1. Nikon Coolpix 7900 LCD Screen Replacement, Back Cover: 1 단계, 이미지 1개 중 1개
      • Remove the four 3.0mm screws on the bottom of the camera.
      댓글 쓰기
    2. Nikon Coolpix 7900 LCD Screen Replacement: 2 단계, 이미지 1개 중 1개
      • Remove the two 3.0mm screws on the left side of the camera near the memory card compartment.
      댓글 쓰기
    3. Nikon Coolpix 7900 LCD Screen Replacement: 3 단계, 이미지 1개 중 1개
      • Remove the two 3.0mm screws on the right side of the camera.
      댓글 쓰기
    4. Nikon Coolpix 7900 LCD Screen Replacement: 4 단계, 이미지 1개 중 1개
      • Carefully open the back cover. Take care as there are connectors still attached.
      댓글 쓰기
    5. Nikon Coolpix 7900 LCD Screen Replacement: 5 단계, 이미지 1개 중 1개
      • Disconnect the cable by pulling the head upward along the green circuit board. If you only are changing the LCD, skip this step.
      댓글 쓰기
    6. Nikon Coolpix 7900 LCD Screen Replacement: 6 단계, 이미지 1개 중 1개
      • Disconnect the ribbon cable by grabbing the two handles and pulling it directly out of the socket. If you are only changing LCD, skip this step.
      • The back cover will be disconnected from the camera
      댓글 쓰기
    1. Nikon Coolpix 7900 LCD Screen Replacement, LCD Screen: 7 단계, 이미지 1개 중 1개
      • First remove the three 2.5mm screws securing the LCD screen to the substrate. Make sure not to keep hold of the little metal connector by the top left screw!
      • Carefully flip the screen down to reveal the back of the screen
      댓글 쓰기
    2. Nikon Coolpix 7900 LCD Screen Replacement: 8 단계, 이미지 1개 중 1개
      • Disconnect the ribbon cable and gray connector with red and black wires.
      • Depending on your spare part, you may now need to carefully pry the screen back cover off. It is held by a double sided sticky tape on the inside. Be gentle!
      댓글 쓰기
결론
취소: 해당 안내서를 완성하지 않았습니다.
다른 한 분이 해당 안내서를 완성하였습니다.
작성자
7다른 기여자 명과 함께
Kaky Payne
회원 가입일: 04/17/12
121 평판
안내서 5개를 작성함
Cal Poly, Team 12-38, Regan Spring 2012 Cal Poly, Team 12-38, Regan Spring 2012 회원
CPSU-REGAN-S12S12G38
4 회원들
안내서 10개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 1
지난 7일: 9
지난 30일: 38
전체 시간: 2,098
