주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Nikon Coolpix B700 Flash Unit Replacement
필요한 것
    1. Nikon Coolpix B700 Flash Unit Replacement, Back Frame Assembly: 1 단계, 이미지 1개 중 1개
      • Use the Phillips screwdriver to remove the two 5.5 mm screws on the left side of the camera.
      댓글 쓰기
    2. Nikon Coolpix B700 Flash Unit Replacement: 2 단계, 이미지 1개 중 1개
      • Use the Phillips screwdriver to remove seven 5.5 mm screws from the bottom of the camera.
      댓글 쓰기
    3. Nikon Coolpix B700 Flash Unit Replacement: 3 단계, 이미지 2개 중 1개 Nikon Coolpix B700 Flash Unit Replacement: 3 단계, 이미지 2개 중 2개
      • Use the Phillips screwdriver to remove the two 5.5mm screws on the right side of the camera.
      • Open the HDMI flap to remove a 5.5mm screw.
      • Don't forget to replace the hidden screw under the HDMI flap during reassembly.
      댓글 쓰기
    4. Nikon Coolpix B700 Flash Unit Replacement: 4 단계, 이미지 1개 중 1개
      • Use the Phillips screwdriver to remove the two 5.5mm screws under the LCD panel.
      댓글 쓰기
    5. Nikon Coolpix B700 Flash Unit Replacement: 5 단계, 이미지 3개 중 1개 Nikon Coolpix B700 Flash Unit Replacement: 5 단계, 이미지 3개 중 2개 Nikon Coolpix B700 Flash Unit Replacement: 5 단계, 이미지 3개 중 3개
      • Open the flash assembly and insert the spudger into the slot under the flash unit and twist.
      • While twisting, pry apart the shell to split the camera in half.
      댓글 쓰기
    6. Nikon Coolpix B700 Flash Unit Replacement: 6 단계, 이미지 1개 중 1개
      • Be careful not to damage the ribbons that connect the halves together.
      댓글 쓰기
    7. Nikon Coolpix B700 Flash Unit Replacement: 7 단계, 이미지 2개 중 1개 Nikon Coolpix B700 Flash Unit Replacement: 7 단계, 이미지 2개 중 2개
      • Place the pry tool under the black latch. Lift gently until the latch flips up.
      • Gently pull the ribbon away from the latch.
      • Be gentle when taking ribbons out and apart because they are fragile.
      댓글 쓰기
    1. Nikon Coolpix B700 Flash Unit Replacement, Internal Bracket: 8 단계, 이미지 1개 중 1개
      • Use the Phillips screwdriver to remove the remaining five 5.55mm screws.
      • Remove the single 6mm screw.
      댓글 쓰기
    2. Nikon Coolpix B700 Flash Unit Replacement: 9 단계, 이미지 1개 중 1개
      • Insert the pry tool under the latch and gently lift up to remove the ribbon.
      댓글 쓰기
    3. Nikon Coolpix B700 Flash Unit Replacement: 10 단계, 이미지 1개 중 1개
      • Move the ribbon out of the way to reveal the hidden screw.
      댓글 쓰기
    4. Nikon Coolpix B700 Flash Unit Replacement: 11 단계, 이미지 1개 중 1개
      • Lift the button assembly gently to give access to remove the 4mm screw.
      댓글 쓰기
    5. Nikon Coolpix B700 Flash Unit Replacement: 12 단계, 이미지 1개 중 1개
      • On the top of the camera, remove the 6mm screw.
      댓글 쓰기
    6. Nikon Coolpix B700 Flash Unit Replacement: 13 단계, 이미지 2개 중 1개 Nikon Coolpix B700 Flash Unit Replacement: 13 단계, 이미지 2개 중 2개
      • With the spudger tool gently pry off the white tap holding in the bracket.
      • Use the same tool to remove the glued-on ribbon.
      댓글 쓰기
    7. Nikon Coolpix B700 Flash Unit Replacement: 14 단계, 이미지 2개 중 1개 Nikon Coolpix B700 Flash Unit Replacement: 14 단계, 이미지 2개 중 2개
      • Gently lift up the button assembly to slide the bracket out.
      댓글 쓰기
    8. Nikon Coolpix B700 Flash Unit Replacement: 15 단계, 이미지 2개 중 1개 Nikon Coolpix B700 Flash Unit Replacement: 15 단계, 이미지 2개 중 2개
      • With the pry tool gently lift up the latch and pull the cable toward the lens assembly.
      • Use the pry tool again and place it under the ribbon and lift straight up to disconnect the ribbon.
      댓글 쓰기
    1. Nikon Coolpix B700 Flash Unit Replacement, Lens Assembly: 16 단계, 이미지 2개 중 1개 Nikon Coolpix B700 Flash Unit Replacement, Lens Assembly: 16 단계, 이미지 2개 중 2개
      • Use the Phillips screwdriver to remove the four 6 mm screw that hold on the bracket housing.
      댓글 쓰기
    2. Nikon Coolpix B700 Flash Unit Replacement: 17 단계, 이미지 1개 중 1개
      • Remove the tripod mount from it's slot.
      댓글 쓰기
    3. Nikon Coolpix B700 Flash Unit Replacement: 18 단계, 이미지 3개 중 1개 Nikon Coolpix B700 Flash Unit Replacement: 18 단계, 이미지 3개 중 2개 Nikon Coolpix B700 Flash Unit Replacement: 18 단계, 이미지 3개 중 3개
      • Now you just have to slide the lens assembly out of the housing.
      댓글 쓰기
    1. Nikon Coolpix B700 Flash Unit Replacement, Motherboard: 19 단계, 이미지 1개 중 1개
      • Use the metal spudger to open the latch to remove the ribbon.
      댓글 쓰기
    2. Nikon Coolpix B700 Flash Unit Replacement: 20 단계, 이미지 1개 중 1개
      • Use the Phillips screwdriver to remove the single 6 mm screw.
      댓글 쓰기
    3. Nikon Coolpix B700 Flash Unit Replacement: 21 단계, 이미지 2개 중 1개 Nikon Coolpix B700 Flash Unit Replacement: 21 단계, 이미지 2개 중 2개
      • Gently lift the button assembly. Slide the motherboard out from the shell.
      댓글 쓰기
    4. Nikon Coolpix B700 Flash Unit Replacement: 22 단계, 이미지 2개 중 1개 Nikon Coolpix B700 Flash Unit Replacement: 22 단계, 이미지 2개 중 2개
      • Desolder the black, gray, and white wires from the motherboard.
      • The motherboard is labeled with the wire colors.
      댓글 쓰기
    1. Nikon Coolpix B700 Flash Unit Replacement, Flash Unit: 23 단계, 이미지 1개 중 1개
      • Using a Phillips screwdriver, remove the two 6 mm screws that hold the flash assembly.
      댓글 쓰기
    2. Nikon Coolpix B700 Flash Unit Replacement: 24 단계, 이미지 2개 중 1개 Nikon Coolpix B700 Flash Unit Replacement: 24 단계, 이미지 2개 중 2개
      • Now while pushing the flash button slide out the flash assembly from the housing.
      • The flash button could fall out when the assembly is removed.
      • During reassembly, insert the flash unit assembly first, then reconnect the flash button.
      댓글 쓰기
결론
취소: 해당 안내서를 완성하지 않았습니다.
다른 한 분이 해당 안내서를 완성하였습니다.
작성자
4다른 기여자 명과 함께
Carlos Salgado
회원 가입일: 02/27/19
1,456 평판
안내서 7개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 2
지난 7일: 6
지난 30일: 30
전체 시간: 871
