주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Nikon Coolpix L18 LCD Screen Replacement
필요한 것
    1. Nikon Coolpix L18 LCD Screen Replacement, Back Cover: 1 단계, 이미지 1개 중 1개
      • Remove the memory stick from the camera.
      • Remove the batteries from the camera.
      댓글 쓰기
    2. Nikon Coolpix L18 LCD Screen Replacement: 2 단계, 이미지 2개 중 1개 Nikon Coolpix L18 LCD Screen Replacement: 2 단계, 이미지 2개 중 2개
      • Remove all six 4.3mm silver screws along the perimeter of the camera using the Phillips #00 screwdriver.
      • There is one screw hidden under the AV cover that also needs to be removed.
      댓글 쓰기
    3. Nikon Coolpix L18 LCD Screen Replacement: 3 단계, 이미지 1개 중 1개
      • Pry the back cover from the left side of the camera. Remove the cover gently.
      댓글 쓰기
    1. Nikon Coolpix L18 LCD Screen Replacement, LCD Screen: 4 단계, 이미지 1개 중 1개
      • This is where energy for the flash is stored. Even with batteries removed, if you touch these connections, you can be shocked, depending on if the flash capacitor has a stored charge. It may not have a stored charge, but work around this assuming it does.
      • Newer cameras of decent quality usually have a bleeder resistor to drain the flash capacitor. This may not work anymore and the flash capacitor may still have a charge.
      댓글 쓰기
    2. Nikon Coolpix L18 LCD Screen Replacement: 5 단계, 이미지 1개 중 1개
      • Remove the tape on the right side of the LCD screen.
      • Gently lift the LCD screen from its base.
      • Don't tug on the screen because it is still connected to the motherboard.
      댓글 쓰기
    3. Nikon Coolpix L18 LCD Screen Replacement: 6 단계, 이미지 1개 중 1개
      • Lift the black latch connecting the LCD ribbon to the motherboard.
      • Gently pull the LCD ribbon out.
      댓글 쓰기
결론
취소: 해당 안내서를 완성하지 않았습니다.
다른 8명이 해당 안내서를 완성하였습니다.
작성자
8다른 기여자 명과 함께
Nonny
회원 가입일: 10/11/10
234 평판
안내서 2개를 작성함
Cal Poly, Team 9-23, Regan Fall 2010 Cal Poly, Team 9-23, Regan Fall 2010 회원
CPSU-REGAN-F10S9G23
4 회원들
안내서 40개를 작성함
4가이드 댓글
Good work! Appreciate it.
Oasis World - 답글 공유
I need a new LCD screen replacement. A link to buy a new one?
William Pullman - 답글 공유
Where can I get a replacement LCD screen for a Nikon L18 camera?
I found one for my Nikon Coolpix L18 on eBay.
Mark Fraylick - 답글 공유
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 6
지난 30일: 36
전체 시간: 7,778
