주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Nikon Coolpix L18 Lens Replacement
필요한 것
    1. Nikon Coolpix L18 Lens Replacement, Back Cover: 1 단계, 이미지 1개 중 1개
      • Remove the memory stick from the camera.
      • Remove the batteries from the camera.
      댓글 쓰기
    2. Nikon Coolpix L18 Lens Replacement: 2 단계, 이미지 2개 중 1개 Nikon Coolpix L18 Lens Replacement: 2 단계, 이미지 2개 중 2개
      • Remove all six 4.3mm silver screws along the perimeter of the camera using the Phillips #00 screwdriver.
      • There is one screw hidden under the AV cover that also needs to be removed.
      댓글 쓰기
    3. Nikon Coolpix L18 Lens Replacement: 3 단계, 이미지 1개 중 1개
      • Pry the back cover from the left side of the camera. Remove the cover gently.
      댓글 쓰기
    1. Nikon Coolpix L18 Lens Replacement, LCD Screen: 4 단계, 이미지 1개 중 1개
      • This is where energy for the flash is stored. Even with batteries removed, if you touch these connections, you can be shocked, depending on if the flash capacitor has a stored charge. It may not have a stored charge, but work around this assuming it does.
      • Newer cameras of decent quality usually have a bleeder resistor to drain the flash capacitor. This may not work anymore and the flash capacitor may still have a charge.
      댓글 쓰기
    2. Nikon Coolpix L18 Lens Replacement: 5 단계, 이미지 1개 중 1개
      • Remove the tape on the right side of the LCD screen.
      • Gently lift the LCD screen from its base.
      • Don't tug on the screen because it is still connected to the motherboard.
      댓글 쓰기
    3. Nikon Coolpix L18 Lens Replacement: 6 단계, 이미지 1개 중 1개
      • Lift the black latch connecting the LCD ribbon to the motherboard.
      • Gently pull the LCD ribbon out.
      댓글 쓰기
    1. Nikon Coolpix L18 Lens Replacement, Front Cover: 7 단계, 이미지 1개 중 1개
      • Pry back the front cover of the camera starting from the right side.
      댓글 쓰기
    1. Nikon Coolpix L18 Lens Replacement, Lens: 8 단계, 이미지 2개 중 1개 Nikon Coolpix L18 Lens Replacement, Lens: 8 단계, 이미지 2개 중 2개
      • Remove the 6 Phillips #00 screws anchoring the LCD base to the motherboard.
      • Remove the LCD base plate.
      댓글 쓰기
    2. Nikon Coolpix L18 Lens Replacement: 9 단계, 이미지 1개 중 1개
      • Gently pull the lens ribbon out.
      댓글 쓰기
    3. Nikon Coolpix L18 Lens Replacement: 10 단계, 이미지 1개 중 1개
      • Desolder the connection of the motherboard to the lens ribbon using a soldering iron and desoldering wick.
      댓글 쓰기
    4. Nikon Coolpix L18 Lens Replacement: 11 단계, 이미지 1개 중 1개
      • Lift up the black and copper covering on the left side of the camera.
      댓글 쓰기
    5. Nikon Coolpix L18 Lens Replacement: 12 단계, 이미지 1개 중 1개
      이 단계에 사용된 도구:
      • Pull the wiring at the top right of the camera away from the lens with tweezers.
      댓글 쓰기
    6. Nikon Coolpix L18 Lens Replacement: 13 단계, 이미지 1개 중 1개
      • Remove the cross-hair shaped wire cap to the left of the lens.
      댓글 쓰기
    7. Nikon Coolpix L18 Lens Replacement: 14 단계, 이미지 2개 중 1개 Nikon Coolpix L18 Lens Replacement: 14 단계, 이미지 2개 중 2개
      • Remove the 3 screws holding the lens to the camera frame.
      • Two 3.8mm black Phillips #00 screws on the sides of the lens.
      • One 4.6mm silver Phillips #00 screw on the bottom of the lens.
      댓글 쓰기
    8. Nikon Coolpix L18 Lens Replacement: 15 단계, 이미지 1개 중 1개
      • There is a screw behind flash tube holding lens. Remove it, then gently pull the lens out. Be sure that the lens's ribbon clears the motherboard.
      댓글 쓰기
결론
취소: 해당 안내서를 완성하지 않았습니다.
다른 6명이 해당 안내서를 완성하였습니다.
작성자
10다른 기여자 명과 함께
Andrea Govea
회원 가입일: 10/11/10
371 평판
안내서 2개를 작성함
Cal Poly, Team 9-23, Regan Fall 2010 Cal Poly, Team 9-23, Regan Fall 2010 회원
CPSU-REGAN-F10S9G23
4 회원들
안내서 10개를 작성함
3가이드 댓글
Be careful. I got painful shock from the flash capacitor even though the camera had been turned off and the batteries removed. It is the red and black wires and green tube on the left side.
Discharge it through a resistor. Trying to short it with a screwdriver made ahuge spark and left a mark on the screwdriver.
sdalimon - 답글 공유
Aconteceu-me o mesmo, agora não a consigo ligar.
O meu caro Sdalimon tem alguma sugestão?
Cumprimentos.
Alberto Lopes - 답글 공유
.....okay but how do I fix it???
John V - 답글 공유
댓글 쓰기
조회 통계:
지난 24시간: 4
지난 7일: 19
지난 30일: 96
전체 시간: 18,773
