주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Nikon Coolpix P510 Lens Assembly Replacement
필요한 것
    1. Nikon Coolpix P510 Lens Assembly Replacement, Lens Assembly: 1 단계, 이미지 2개 중 1개 Nikon Coolpix P510 Lens Assembly Replacement, Lens Assembly: 1 단계, 이미지 2개 중 2개
      • Flip the camera upside down and remove six 3mm PH00 Philips screws with a Philips screwdriver.
      • On the thumb grip, remove the one 4mm PH00 Philips screw.
      댓글 쓰기
    2. Nikon Coolpix P510 Lens Assembly Replacement: 2 단계, 이미지 1개 중 1개
      • With the camera upside down, remove the three 3mm PH00 Philips screws on the left side.
      • One of the screws are under the HDMI and A/V Out cover.
      댓글 쓰기
    3. Nikon Coolpix P510 Lens Assembly Replacement: 3 단계, 이미지 1개 중 1개
      • On the opposite side of the camera, remove the two 3mm PH00 Philips screws.
      댓글 쓰기
    4. Nikon Coolpix P510 Lens Assembly Replacement: 4 단계, 이미지 1개 중 1개
      • open the display and remove the two Ph 00 screws near the hinge
      댓글 쓰기
    5. Nikon Coolpix P510 Lens Assembly Replacement: 5 단계, 이미지 3개 중 1개 Nikon Coolpix P510 Lens Assembly Replacement: 5 단계, 이미지 3개 중 2개 Nikon Coolpix P510 Lens Assembly Replacement: 5 단계, 이미지 3개 중 3개
      • Open the flash and use a plastic opening tool to pop the tab under it as shown.
      • Now pull the casing apart.
      • The tripod attachment may fall out on its own, or you will need to pull it out.
      댓글 쓰기
    6. Nikon Coolpix P510 Lens Assembly Replacement: 6 단계, 이미지 2개 중 1개 Nikon Coolpix P510 Lens Assembly Replacement: 6 단계, 이미지 2개 중 2개
      • Unplug the two ribbon cables to completely detach the back, by securely opening the latch
      댓글 쓰기
    7. Nikon Coolpix P510 Lens Assembly Replacement: 7 단계, 이미지 3개 중 1개 Nikon Coolpix P510 Lens Assembly Replacement: 7 단계, 이미지 3개 중 2개 Nikon Coolpix P510 Lens Assembly Replacement: 7 단계, 이미지 3개 중 3개
      • With the back separated, you need to remove six 3mm PH000 Philips screws with a Philips screwdriver.
      • Remove one 5mm PH00 Philips screw
      • To remove the top right corner screw, you may need to lift the corner of the case to gain access to it.
      • With all the screws out, the metal plate should simply lift off.
      댓글 쓰기
    8. Nikon Coolpix P510 Lens Assembly Replacement: 8 단계, 이미지 2개 중 1개 Nikon Coolpix P510 Lens Assembly Replacement: 8 단계, 이미지 2개 중 2개
      • With the metal plate off, unplug this ribbon cable from the motherboard.
      • To remove the flat-topped connector, you simply lift it up to unplug it.
      댓글 쓰기
    9. Nikon Coolpix P510 Lens Assembly Replacement: 9 단계, 이미지 3개 중 1개 Nikon Coolpix P510 Lens Assembly Replacement: 9 단계, 이미지 3개 중 2개 Nikon Coolpix P510 Lens Assembly Replacement: 9 단계, 이미지 3개 중 3개
      • To get the lens assembly out, you need to remove four 6mm PH00 Philips screws
      댓글 쓰기
    10. Nikon Coolpix P510 Lens Assembly Replacement: 10 단계, 이미지 2개 중 1개 Nikon Coolpix P510 Lens Assembly Replacement: 10 단계, 이미지 2개 중 2개
      • With the support screws out, you can simply slide the assembly out of the casing.
      댓글 쓰기
    11. Nikon Coolpix P510 Lens Assembly Replacement: 11 단계, 이미지 3개 중 1개 Nikon Coolpix P510 Lens Assembly Replacement: 11 단계, 이미지 3개 중 2개 Nikon Coolpix P510 Lens Assembly Replacement: 11 단계, 이미지 3개 중 3개
      • If you are moving on to take the lens casing off, you do not need to do this step.
      • With the assembly out we need to take of this last piece by removing the three 3mm PH000 Philips screws.
      댓글 쓰기
결론
취소: 해당 안내서를 완성하지 않았습니다.
다른 9명이 해당 안내서를 완성하였습니다.
작성자
5다른 기여자 명과 함께
Brian Hulsey
회원 가입일: 03/31/15
1,554 평판
안내서 6개를 작성함
Colorado Springs, Team 2-2, Panko Spring 2015 Colorado Springs, Team 2-2, Panko Spring 2015 회원
UCCS-PANKO-S15S2G2
3 회원들
안내서 15개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 2
지난 7일: 9
지난 30일: 70
전체 시간: 4,898
