주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Nikon Coolpix S4100 External Casing Replacement
필요한 것
    1. Nikon Coolpix S4100 External Casing Replacement, External Casing: 1 단계, 이미지 3개 중 1개 Nikon Coolpix S4100 External Casing Replacement, External Casing: 1 단계, 이미지 3개 중 2개 Nikon Coolpix S4100 External Casing Replacement, External Casing: 1 단계, 이미지 3개 중 3개
      • Using a Philips #000 head screwdriver, remove the 8 screws (3.30 mm) visible on the external part of the camera.
      • There are 2 on each side, and 4 on the bottom.
      댓글 쓰기
    2. Nikon Coolpix S4100 External Casing Replacement: 2 단계, 이미지 1개 중 1개
      • Remove the black casing on the back of the camera that runs around the LCD screen.
      댓글 쓰기
    3. Nikon Coolpix S4100 External Casing Replacement: 3 단계, 이미지 1개 중 1개
      • Using the Philips #000 head screwdriver, remove the 1.90 mm internal screw located just above the lanyard mount.
      댓글 쓰기
    4. Nikon Coolpix S4100 External Casing Replacement: 4 단계, 이미지 3개 중 1개 Nikon Coolpix S4100 External Casing Replacement: 4 단계, 이미지 3개 중 2개 Nikon Coolpix S4100 External Casing Replacement: 4 단계, 이미지 3개 중 3개
      • Pry off the front shell casing.
      • If you find this difficult, use a prying tool to help gently remove the casing.
      댓글 쓰기
    5. Nikon Coolpix S4100 External Casing Replacement: 5 단계, 이미지 1개 중 1개
      • Using the Philips #000 head screwdriver, remove the 3.30 mm screw located on the side of the camera near the lanyard mount.
      댓글 쓰기
    6. Nikon Coolpix S4100 External Casing Replacement: 6 단계, 이미지 2개 중 1개 Nikon Coolpix S4100 External Casing Replacement: 6 단계, 이미지 2개 중 2개
      • Using the Philips #000 head screwdriver, remove 2 additional 3.30 mm screws holding the lanyard mount in place.
      댓글 쓰기
    7. Nikon Coolpix S4100 External Casing Replacement: 7 단계, 이미지 3개 중 1개 Nikon Coolpix S4100 External Casing Replacement: 7 단계, 이미지 3개 중 2개 Nikon Coolpix S4100 External Casing Replacement: 7 단계, 이미지 3개 중 3개
      • Remove the lanyard mount and accompanying side shell casing off of the camera.
      댓글 쓰기
    8. Nikon Coolpix S4100 External Casing Replacement: 8 단계, 이미지 1개 중 1개
      • Using the Philips #000 head screwdriver, remove the 3.30 mm screw securing the top shell casing.
      댓글 쓰기
    9. Nikon Coolpix S4100 External Casing Replacement: 9 단계, 이미지 1개 중 1개
      • Using the Philips #000 head screwdriver, remove the 3.40 mm screw located on the front of the camera in the upper corner by the LED light.
      댓글 쓰기
    10. Nikon Coolpix S4100 External Casing Replacement: 10 단계, 이미지 1개 중 1개
      • Remove the remaining side shell casing.
      댓글 쓰기
    11. Nikon Coolpix S4100 External Casing Replacement: 11 단계, 이미지 1개 중 1개
      • Remove the top shell casing.
      댓글 쓰기
결론
취소: 해당 안내서를 완성하지 않았습니다.
다른 2명이 해당 안내서를 완성하였습니다.
작성자
6다른 기여자 명과 함께
Matthew Willis
회원 가입일: 09/22/15
598 평판
안내서 4개를 작성함
Baylor, Team 4-2, Williams Fall 2015 Baylor, Team 4-2, Williams Fall 2015 회원
BU-WILLIAMS-F15S4G2
4 회원들
안내서 24개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 1
지난 7일: 7
지난 30일: 41
전체 시간: 1,484
