주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Nikon Coolpix S6800 Display Replacement
필요한 것
    1. Nikon Coolpix S6800 Display Replacement, Midframe: 1 단계, 이미지 1개 중 1개
      • Turn the camera upside down and locate the two, black screws.
      • Using the Philips #00 Screwdriver, remove each screw.
      댓글 쓰기
    2. Nikon Coolpix S6800 Display Replacement: 2 단계, 이미지 1개 중 1개
      • Rotate the camera to the left side and remove the two, black, #00 Philips screws.
      댓글 쓰기
    3. Nikon Coolpix S6800 Display Replacement: 3 단계, 이미지 1개 중 1개
      • Rotate the camera to the right side and remove the two, black, #00 Philips screws.
      • The last screw that you remove will catch as the cover is trying to pop off. Try to keep the cover in place to allow for the screw to just fall out. Once you remove the screws, be careful not to lose the screws for reassembly.
      댓글 쓰기
    4. Nikon Coolpix S6800 Display Replacement: 4 단계, 이미지 1개 중 1개
      • Carefully remove the back plate from the body of the camera.
      • All of the external screws are black with rounded heads.
      댓글 쓰기
    5. Nikon Coolpix S6800 Display Replacement: 5 단계, 이미지 1개 중 1개
      • Using the Philips #00 Screwdriver, remove the two screws that are holding the keypad.
      댓글 쓰기
    6. Nikon Coolpix S6800 Display Replacement: 6 단계, 이미지 2개 중 1개 Nikon Coolpix S6800 Display Replacement: 6 단계, 이미지 2개 중 2개
      • Flip the keypad away from the camera
      • Be careful with the electric ribbon. Do not crease it or tug on it. Gently flip it away from the camera.
      댓글 쓰기
    7. Nikon Coolpix S6800 Display Replacement: 7 단계, 이미지 2개 중 1개 Nikon Coolpix S6800 Display Replacement: 7 단계, 이미지 2개 중 2개
      • Gently pull the display away from the camera body.
      • Fold the display away from the camera
      • Be careful with the display. Do not press on it or drop it.
      댓글 쓰기
    8. Nikon Coolpix S6800 Display Replacement: 8 단계, 이미지 2개 중 1개 Nikon Coolpix S6800 Display Replacement: 8 단계, 이미지 2개 중 2개
      • Remove the visible midframe screws.
      • There is a screw beneath the foam square that must be removed as well.
      • The screw holding the silver wrist-strap loop on the side of the camera must also be removed.
      • Gently lift the midframe up and out of the device.
      • Be careful moving the midframe away from the ribbons don't force it, gently slide the plate away from the ribbons.
      댓글 쓰기
    1. Nikon Coolpix S6800 Display Replacement, Display: 9 단계, 이미지 2개 중 1개 Nikon Coolpix S6800 Display Replacement, Display: 9 단계, 이미지 2개 중 2개
      • Flip up the little black tab on the connecter of the display's ribbon.
      • Don't use a metal object for this step. A fingernail will do. Simply slide your fingernail under the lip and lift slowly. You may need to lift in different areas along the tab to get it all the way up.
      • The top tab in the second picture is up while the bottom tab is down to show a comparison.
      댓글 쓰기
    2. Nikon Coolpix S6800 Display Replacement: 10 단계, 이미지 1개 중 1개
      • Gently pull out the ribbon. It should come out easily, don't force it.
      댓글 쓰기
    3. Nikon Coolpix S6800 Display Replacement: 11 단계, 이미지 1개 중 1개
      • Take the new display and orient it the same way as the old screen before it was removed.
      • Gently slide the end of the electric ribbon into the connector.
      • To make sure that the ribbon is completely in the connector give it a firm push but don't force anything. The ribbon should slide in with only a little resistance.
      • Don't bend the ribbon.
      댓글 쓰기
결론
취소: 해당 안내서를 완성하지 않았습니다.
작성자
2다른 기여자 명과 함께
sam ford
회원 가입일: 03/30/15
518 평판
안내서 4개를 작성함
UMass Dartmouth, Team 1-2, Shastany Spring 2015 UMass Dartmouth, Team 1-2, Shastany Spring 2015 회원
UMASSD-SHASTANY-S15S1G2
4 회원들
안내서 36개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 14
지난 30일: 42
전체 시간: 2,121
