주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Nikon D3000 Motherboard Replacement
필요한 것
  1. Nikon D3000 Motherboard Replacement, Motherboard: 1 단계, 이미지 2개 중 1개 Nikon D3000 Motherboard Replacement, Motherboard: 1 단계, 이미지 2개 중 2개
    • Remove six 3 mm x 2.5 mm Phillips head screws from the bottom right of the camera bottom.
    • Remove three 3 mm x 5.5 mm Phillips head screws from the bottom left of the camera bottom
    • Lift the battery cover and remove two 3 mm x 5 mm Phillips head screws.
    댓글 쓰기
  2. Nikon D3000 Motherboard Replacement: 2 단계, 이미지 3개 중 1개 Nikon D3000 Motherboard Replacement: 2 단계, 이미지 3개 중 2개 Nikon D3000 Motherboard Replacement: 2 단계, 이미지 3개 중 3개
    • Remove the two 3 mm x 5.5 mm Phillips head screws from the either side of the viewfinder.
    • Remove four 3 mm x 5.5 mm Phillips head screws from the sides of the camera.
    • Remove two 3 mm x 4 mm Phillips head screws from under the SD card door.
    댓글 쓰기
  3. Nikon D3000 Motherboard Replacement: 3 단계, 이미지 2개 중 1개 Nikon D3000 Motherboard Replacement: 3 단계, 이미지 2개 중 2개
    • Use the following process for removing all ribbon connectors.
    • Lift the back of the camera and, using the blue prying tool, lift the tab from the LCD ribbon connector.
    • Slide the ribbon connector away from the bottom of the camera and remove the back cover containing the LCD to expose the motherboard.
    댓글 쓰기
  4. Nikon D3000 Motherboard Replacement: 4 단계, 이미지 2개 중 1개 Nikon D3000 Motherboard Replacement: 4 단계, 이미지 2개 중 2개
    • Soldering irons are hot; take all necessary precautions to not burn yourself or equipment.
    • Be sure to label each gray wire to be removed from the motherboard as they are the same color and can be mixed up during reassembly.
    • Lift the tab on the ribbon connector and pull away the ribbon to expose a 4 mm x 4 mm Phillips head screw.
    • De-solder the red (upper), two grey (lower), red (lower), and blue (lower) wires from the motherboard.
    • Remove five 4 mm x 4 mm Phillips head screws holding the motherboard to the camera frame.
    댓글 쓰기
  5. Nikon D3000 Motherboard Replacement: 5 단계, 이미지 2개 중 1개 Nikon D3000 Motherboard Replacement: 5 단계, 이미지 2개 중 2개
    • Lift the tabs and pull away the ribbon connectors shown .
    • Lift the motherboard and disconnect the grey connector from the bottom.
    • Disconnect and remove the motherboard.
    댓글 쓰기
결론
취소: 해당 안내서를 완성하지 않았습니다.
다른 3명이 해당 안내서를 완성하였습니다.
작성자
1다른 기여자 명과 함께
Randall Heath
회원 가입일: 08/25/15
899 평판
안내서 3개를 작성함
USF Tampa, Team 14-7, Meier Fall 2015 USF Tampa, Team 14-7, Meier Fall 2015 회원
USFT-MEIER-F15S14G7
4 회원들
안내서 6개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 11
지난 30일: 58
전체 시간: 4,886
