주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Nikon D40 Viewfinder Replacement
필요한 것
    1. Nikon D40 Viewfinder Replacement, Back Cover: 1 단계, 이미지 1개 중 1개
      • Remove the two visible 6.0 mm Philips #0 screws on the left and right sides of the viewfinder. These screws are highlighted in red.
      댓글 쓰기
    2. Nikon D40 Viewfinder Replacement: 2 단계, 이미지 2개 중 1개 Nikon D40 Viewfinder Replacement: 2 단계, 이미지 2개 중 2개
      • Remove the four 6.0 mm Philips #0 screws on the left and right sides of the camera.
      댓글 쓰기
    3. Nikon D40 Viewfinder Replacement: 3 단계, 이미지 1개 중 1개
      • Remove the four highlighted 3.0 mm Philips #0 screws on the bottom of the camera.
      댓글 쓰기
    4. Nikon D40 Viewfinder Replacement: 4 단계, 이미지 1개 중 1개
      • While pulling the bottom down, remove the back of the camera.
      • Be careful not to pull too hard on the back as it is connected via a ribbon cable. Be sure to disconnect this cable on the main board.
      • To disconnect the ribbon cable pull the small black tab upward and pull gently on the cable.
      댓글 쓰기
    1. Nikon D40 Viewfinder Replacement, Viewfinder: 5 단계, 이미지 1개 중 1개
      • You will be able to see the ribbon cables coming out from the back panel, disconnect the cables.
      • Be careful not to pull too hard on the ribbon cables.
      댓글 쓰기
    2. Nikon D40 Viewfinder Replacement: 6 단계, 이미지 1개 중 1개
      • Slowly push the upper body up until you see the frame of the viewfinder
      • Be careful while pulling the top camera body.
      댓글 쓰기
    3. Nikon D40 Viewfinder Replacement: 7 단계, 이미지 1개 중 1개
      • Use a spudger to keep the upper body separate from the printed circuit board.
      • Wiggle the plastic eyepiece out of the frame. This may require some force.
      댓글 쓰기
    4. Nikon D40 Viewfinder Replacement: 8 단계, 이미지 1개 중 1개
      • Remove the viewfinder with the plastic opening tool.
      • Do not push too hard while using the opening tool.
      댓글 쓰기
    5. Nikon D40 Viewfinder Replacement: 9 단계, 이미지 1개 중 1개
      • The viewfinder has been removed!
      댓글 쓰기
결론
취소: 해당 안내서를 완성하지 않았습니다.
다른 2명이 해당 안내서를 완성하였습니다.
작성자
1다른 기여자 명과 함께
Amy Chen
회원 가입일: 01/23/14
193 평판
안내서 1개를 작성함
Cal Poly, Team 6-19, Maness Winter 2014 Cal Poly, Team 6-19, Maness Winter 2014 회원
CPSU-MANESS-W14S6G19
4 회원들
안내서 7개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 13
지난 30일: 49
전체 시간: 4,048
