주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Nikon D500 Back Panel Removal
필요한 것
      • Remove the Memory Card(s) from the camera
      • Remove the Battery from the Camera, and close the battery compartment cover
      댓글 쓰기
    1. Nikon D500 Back Panel Removal, Remove 2 exposed screws: 2 단계, 이미지 1개 중 1개
      • Remove the 2 screws beside the memory slots, then close the cover.
      • Note: make sure to remove the memory cards first!
      댓글 쓰기
    2. Nikon D500 Back Panel Removal, Remove 2 screws under grip: 3 단계, 이미지 1개 중 1개
      • Remove the 2 screws under the rubber grip part by peeling back the rubber grip
      • Try not to damage the double sided adhesive under the rubber.
      댓글 쓰기
    3. Nikon D500 Back Panel Removal, Remove 2 screws under rear grip: 4 단계, 이미지 1개 중 1개
      • Remove the 2 screws under the rubber pad marked in red.
      • Try not to damage the double-sided adhesive under the rubber.
      • Note: There is a 3rd screw under the flap, which holds the back to the top (marked in yellow). If needing to remove the back panel not just the memory cover flap, it can be removed at this time as well.
      댓글 쓰기
      • Lift out the assembly panel, it should come free without much force.
      • May open the panel to release it.
      댓글 쓰기
    1. Nikon D500 Back Panel Removal, Remove top screw: 6 단계, 이미지 1개 중 1개
      • Remove the screw above the viewfinder
      댓글 쓰기
    2. Nikon D500 Back Panel Removal, Remove the bottom panel plate: 7 단계, 이미지 1개 중 1개
      • Remove the 4 screws holding the plate to the bottom.
      • Remove the bottom plate
      댓글 쓰기
    3. Nikon D500 Back Panel Removal, Remove screws from the bottom: 8 단계, 이미지 1개 중 1개
      • Remove the 4 screws (1 was under the plate removed under the last step)
      댓글 쓰기
    4. Nikon D500 Back Panel Removal, Remove Screw under grip: 9 단계, 이미지 1개 중 1개
      • Remove the screw under the grip, if it has not been removed doing a previous step
      댓글 쓰기
    5. Nikon D500 Back Panel Removal, Remove Screw on Left: 10 단계, 이미지 1개 중 1개
      • Remove the exposed screw on the Left side
      댓글 쓰기
    6. Nikon D500 Back Panel Removal, Carefully remove the back assembly: 11 단계, 이미지 1개 중 1개
      • Carefully pull the back plate off the camera
      • There are 2 ribbon cables that need to be disconnected from the main board to free the rear panel from the camera.
      • To release the cables by flipping up the tap on the side away from the cable
      • When reconnecting the cables, make sure the cables are fully seated before flipping the latch back down.
      • The black cable goes to the LCD (on the tilt screen), the other one goes to the buttons.
      • The black LCD cable does have less slack, so is easier to release first, and reconnect last.
      댓글 쓰기
결론
취소: 해당 안내서를 완성하지 않았습니다.
다른 한 분이 해당 안내서를 완성하였습니다.
작성자
1다른 기여자 명과 함께
Wolphin
회원 가입일: 11/11/19
1,795 평판
안내서 9개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 3
지난 7일: 9
지난 30일: 59
전체 시간: 2,973
