주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Ninja Professional Blender BL660 Power Button Panel Replacement
필요한 것
    1. Ninja Professional Blender BL660 Power Button Panel Replacement, Blender Base: 1 단계, 이미지 2개 중 1개 Ninja Professional Blender BL660 Power Button Panel Replacement, Blender Base: 1 단계, 이미지 2개 중 2개
      • Using the Phillips #1 screwdriver, remove the 5 screws (13mm long, 6mm wide) holding the outer base.
      • Lift the base up to remove it.
      댓글 쓰기
    2. Ninja Professional Blender BL660 Power Button Panel Replacement: 2 단계, 이미지 2개 중 1개 Ninja Professional Blender BL660 Power Button Panel Replacement: 2 단계, 이미지 2개 중 2개
      • Remove the midsection by pulling it up. If the section is stuck, use the iFixit plastic opening tool to pry it off.
      • Pull the power cord through the mid-section opening.
      댓글 쓰기
    3. Ninja Professional Blender BL660 Power Button Panel Replacement: 3 단계, 이미지 2개 중 1개 Ninja Professional Blender BL660 Power Button Panel Replacement: 3 단계, 이미지 2개 중 2개
      • Using the Phillips #1 screwdriver, remove the 6 screws (13 mm long, 6 mm wide).
      댓글 쓰기
    4. Ninja Professional Blender BL660 Power Button Panel Replacement: 4 단계, 이미지 2개 중 1개 Ninja Professional Blender BL660 Power Button Panel Replacement: 4 단계, 이미지 2개 중 2개
      • Using the Phillips #1 screwdriver, remove the two screws (5 mm long, 3 mm wide) holding the power cord onto the motor cover.
      댓글 쓰기
    5. Ninja Professional Blender BL660 Power Button Panel Replacement: 5 단계, 이미지 2개 중 1개 Ninja Professional Blender BL660 Power Button Panel Replacement: 5 단계, 이미지 2개 중 2개
      • Using the iFixit plastic opening tool, pry the motor cover off the general housing. Once it is loose, lift it up to remove it off the base.
      • Slide the cover all the way to the end of the power cord.
      • Please note that the power cord does not completely come off the cover.
      댓글 쓰기
    1. Ninja Professional Blender BL660 Power Button Panel Replacement, Power Button Panel: 6 단계, 이미지 3개 중 1개 Ninja Professional Blender BL660 Power Button Panel Replacement, Power Button Panel: 6 단계, 이미지 3개 중 2개 Ninja Professional Blender BL660 Power Button Panel Replacement, Power Button Panel: 6 단계, 이미지 3개 중 3개
      • Using the Phillips #2 screwdriver, remove the four screws holding the circuit board to the housing.
      댓글 쓰기
    2. Ninja Professional Blender BL660 Power Button Panel Replacement: 7 단계, 이미지 1개 중 1개
      • Using a pair of scissors, cut the zip ties holding the power wires in order to give the circuit board mobility.
      댓글 쓰기
    3. Ninja Professional Blender BL660 Power Button Panel Replacement: 8 단계, 이미지 1개 중 1개
      • Using a Phillips #2 screwdriver, remove the 5 screws holding the power button panel cover.
      댓글 쓰기
    4. Ninja Professional Blender BL660 Power Button Panel Replacement: 9 단계, 이미지 3개 중 1개 Ninja Professional Blender BL660 Power Button Panel Replacement: 9 단계, 이미지 3개 중 2개 Ninja Professional Blender BL660 Power Button Panel Replacement: 9 단계, 이미지 3개 중 3개
      • Pull the power button panel cover off.
      • The power button panel comes off as a whole unit. Replace as needed.
      • Ninja Kitchen does not sell the power button panel. You will have to purchase one from a third party vendor.
      댓글 쓰기
결론
취소: 해당 안내서를 완성하지 않았습니다.
작성자
4다른 기여자 명과 함께
Hernan Mendoza
회원 가입일: 09/22/17
210 평판
안내서 2개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 1
지난 7일: 11
지난 30일: 45
전체 시간: 2,045
