주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Nintendo 2DS Motherboard Replacement
필요한 것
  1. Nintendo 2DS Motherboard Replacement, Battery: 1 단계, 이미지 1개 중 1개
    • Remove the two Phillips captive screws securing the upper rear panel.
    • The captive screws will not completely detach from the back panel.
    댓글 쓰기
  2. Nintendo 2DS Motherboard Replacement: 2 단계, 이미지 2개 중 1개 Nintendo 2DS Motherboard Replacement: 2 단계, 이미지 2개 중 2개
    • Hinge the upper rear panel upwards and outwards to remove it.
    댓글 쓰기
  3. Nintendo 2DS Motherboard Replacement: 3 단계, 이미지 3개 중 1개 Nintendo 2DS Motherboard Replacement: 3 단계, 이미지 3개 중 2개 Nintendo 2DS Motherboard Replacement: 3 단계, 이미지 3개 중 3개
    • Remove the battery from its housing by lifting it up from the side closest to the outside edge.
    댓글 쓰기
  4. Nintendo 2DS Motherboard Replacement, Rear Panel: 4 단계, 이미지 1개 중 1개
    • Remove the ten Phillips screws attaching the rear panel.
    댓글 쓰기
  5. Nintendo 2DS Motherboard Replacement: 5 단계, 이미지 1개 중 1개
    • The rear panel is attached to the motherboard by a ribbon cable, so be careful not to lift the rear panel too far from the device.
    • Carefully pull the rear panel straight up from the device.
    댓글 쓰기
  6. Nintendo 2DS Motherboard Replacement: 6 단계, 이미지 1개 중 1개
    • Use your fingernail or the flat end of a spudger to flip up the connector securing the ribbon cable to the motherboard
    • Remove the cable from the connector
    • Take the opportunity to remove the Left and Right triggers, they have hinges that may break and springs that may jump away.
    댓글 쓰기
  7. Nintendo 2DS Motherboard Replacement, Remove Side Panels: 7 단계, 이미지 2개 중 1개 Nintendo 2DS Motherboard Replacement, Remove Side Panels: 7 단계, 이미지 2개 중 2개
    • Hold the side panels of the device's case with your fingers and pull outward to remove them.
    • The panels should come off easily with little force required.
    • There are three ribbon cables which have already been unplugged in this picture, disconnect these before disassembling the device further.
    댓글 쓰기
  8. Nintendo 2DS Motherboard Replacement, Unscrew Motherboard: 8 단계, 이미지 1개 중 1개
    • Remove the 12 brass-colored Phillips screws securing the main board.
    • Be very careful not to strip any of these screws. Stripping can occur very easily, and may make replacement of the motherboard impossible.
    • The circle pad has disappeared in this picture. Don't worry, we'll deal with that in the next step
    댓글 쓰기
  9. Nintendo 2DS Motherboard Replacement, Remove Top Panel: 9 단계, 이미지 3개 중 1개 Nintendo 2DS Motherboard Replacement, Remove Top Panel: 9 단계, 이미지 3개 중 2개 Nintendo 2DS Motherboard Replacement, Remove Top Panel: 9 단계, 이미지 3개 중 3개
    • The top panel can only be removed when the mother board is not secured.
    • There are two additional screws located on the top rail. Remove these to fully remove the buttons and top rail.
    • There are two screws holding down the joystick base that must be removed. (Be careful of the ribbon cable—it stays connected!)
    • Hold the top panel with your fingers and pull away from the device to remove it.
    • The top panel should come off easily, with very little force applied.
    댓글 쓰기
  10. Nintendo 2DS Motherboard Replacement, Remove Motherboard: 10 단계, 이미지 2개 중 1개 Nintendo 2DS Motherboard Replacement, Remove Motherboard: 10 단계, 이미지 2개 중 2개
    • Detach the 2 ribbon cables by lifting the black flip connectors that hold them.
    • Lift out the rectangular board seated in the face and lift out the white square which is the joystick motor (takes a little effort). Both stay attached to the motherboard.
    • On some models, you'll need to remove three more tiny ribbon cables at the bottom of the screen. They are secured by flip up connectors. BE GENTLE!
    • Holding the motherboard on either side, lift to remove it.
    댓글 쓰기
결론
취소: 해당 안내서를 완성하지 않았습니다.
다른 34명이 해당 안내서를 완성하였습니다.
작성자
9다른 기여자 명과 함께
Fina Beauchamp
회원 가입일: 01/12/15
3,388 평판
안내서 6개를 작성함
Cal Poly, Team 70-1, Forte Winter 2015 Cal Poly, Team 70-1, Forte Winter 2015 회원
CPSU-FORTE-W15S70G1
4 회원들
안내서 36개를 작성함
13가이드 댓글
o meu 2ds esta com um defeito que, quando eu aperto o botão de power ele liga e apos alguns segundo desliga e faz um pequeno barulho.
thiagopereira10000 - 답글 공유
Would a jis #000 screw driver work better? As i tried a ph +000 and the gold motherboard screws just dont fit right
Demon09 - 답글 공유
I have a question. After I replaced the mother board I have been having issues with it freezing after a couple mins running. Do you know why
briana1987be - 답글 공유
I have a similar problem. After I replaced mine it will not open any app, and it does not show the status bar. Does anyone know why?
Steve David - 답글 공유
Now that I've removed the motherboard, how do I fix it? The instructible is great as far as it goes, but it doesn't go far enough
Danielle Chester - 답글 공유
댓글 쓰기
조회 통계:
지난 24시간: 22
지난 7일: 139
지난 30일: 578
전체 시간: 68,560
