주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Nintendo 3DS 2015 Battery Replacement
필요한 것
  1. Nintendo 3DS 2015 Battery Replacement, Battery: 1 단계, 이미지 1개 중 1개
    • Unscrew the two 3mm Phillips #1 head screws along the top edge of the device.
    • The screws on the back panel strip easily. Go slowly and press down firmly.
    • The screws on the back panel are held in by locking washers, so they won't come out of the back panel.
    댓글 쓰기
  2. Nintendo 3DS 2015 Battery Replacement: 2 단계, 이미지 2개 중 1개 Nintendo 3DS 2015 Battery Replacement: 2 단계, 이미지 2개 중 2개
    • Pull the top corner tabs of the front face plate outward and towards you.
    • Pull the faceplate up and out of the slots at the bottom of the device.
    • Set aside the back faceplate.
    댓글 쓰기
  3. Nintendo 3DS 2015 Battery Replacement: 3 단계, 이미지 3개 중 1개 Nintendo 3DS 2015 Battery Replacement: 3 단계, 이미지 3개 중 2개 Nintendo 3DS 2015 Battery Replacement: 3 단계, 이미지 3개 중 3개
    • Insert a plastic opening tool into the notch at the top of the battery.
    • Pry the battery up with the plastic opening tool.
    댓글 쓰기
결론
취소: 해당 안내서를 완성하지 않았습니다.
다른 7명이 해당 안내서를 완성하였습니다.
작성자
4다른 기여자 명과 함께
Tyler Starr
회원 가입일: 10/06/16
1,779 평판
안내서 7개를 작성함
Cal Poly, Team 4-6, Livingston Fall 2016 Cal Poly, Team 4-6, Livingston Fall 2016 회원
CPSU-LIVINGSTON-F16S4G6
4 회원들
안내서 46개를 작성함
6가이드 댓글
The link to the Nintendo store to buy a battery no longer functions.
David Clarke - 답글 공유
My console has been off and without a battery for months now and I haven't been able to get a replacement battery until very recently, I replaced it just now and the orange led lights on (albeit for a short time) but the console won't turn on. The blue led lights up briefly then goes out again and the console remains off. Could it be something wrong with the console itself rather than the battery? Edit: Should I just leave it plugged in for a while even if the orange led doesn't stay on?
Leon J - 답글 공유
I solved it by cleaning the contacts, reseating the battery and removing the microSD card. The SD card can then be put back in later
Leon J - 답글 공유
How's the battery life on it so far? I know you just posted 2 days ago, but I was just curious.
Will Reds - 답글 공유
i bought one of these batteries but it’s slightly smaller than the original battery and and the charge does not last long, maybe 1-2 hours
Jessica V - 답글 공유
댓글 쓰기
조회 통계:
지난 24시간: 7
지난 7일: 60
지난 30일: 305
전체 시간: 12,702
