주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Nintendo 3DS Speaker Assembly Replacement
필요한 것
  1. Nintendo 3DS Speaker Assembly Replacement, Loosen the rear screws: 1 단계, 이미지 1개 중 1개
    이 단계에 사용된 도구:
    Phillips #00 Screwdriver
    $5.49
    • Use a Phillips PH00 screwdriver to loosen the four screws along the top of the back cover.
    • All screws in this device are JIS screws. Official iFixit PH000-PH1 Phillips screwdrivers are designed to be compatible with JIS screws, so they are safe to use. Using a screwdriver other than an official iFixit screwdriver or a JIS screwdriver may result in stripped screws.
    • The screws are held in place by locking washers, and will not come out of the back cover.
    댓글 쓰기
  2. Nintendo 3DS Speaker Assembly Replacement, Remove the rear cover: 2 단계, 이미지 2개 중 1개 Nintendo 3DS Speaker Assembly Replacement, Remove the rear cover: 2 단계, 이미지 2개 중 2개
    • Hold the device in one hand and turn it over.
    • Grab the top edge of the back cover with your opposite hand so that the cover does not fall back into place.
    • Flip the 3DS over again so that the back cover is facing up.
    • Pull the back cover up and away from the rest of the device to remove it.
    댓글 쓰기
  3. Nintendo 3DS Speaker Assembly Replacement, Battery: 3 단계, 이미지 3개 중 1개 Nintendo 3DS Speaker Assembly Replacement, Battery: 3 단계, 이미지 3개 중 2개 Nintendo 3DS Speaker Assembly Replacement, Battery: 3 단계, 이미지 3개 중 3개
    • Insert a plastic opening tool into the notch in the lower case above the battery.
    • Pry the battery up with the plastic opening tool.
    • Grab the top edge of the battery and lift it out of the lower case.
    댓글 쓰기
  4. Nintendo 3DS Speaker Assembly Replacement, Lower Case: 4 단계, 이미지 1개 중 1개
    • Use a JIS #00 screwdriver to remove the nine 6.3 mm black screws from the lower case.
    • JIS (Japanese Industrial Standards) screws are not the same as Phillips. To avoid stripping these screws, make sure you are using a JIS #00 screwdriver and not a PHILLIPS #00 screwdriver. You can use a PHILLIPS #00 with a lot of downwards force but be warned this will deform the screw head and you risk stripping it.
    • iFixit's Phillips head screwdriver is designed to reduce damage on JIS head screws so it should be fine to use, still apply more force. Make sure it's iFixit's official Phillips screwdriver as we are unaware of any other manufacturer who does this.
    • Use a JIS #00 screwdriver to remove the 2.4 mm silver screw above the game cartridge slot.
    댓글 쓰기
  5. Nintendo 3DS Speaker Assembly Replacement: 5 단계, 이미지 3개 중 1개 Nintendo 3DS Speaker Assembly Replacement: 5 단계, 이미지 3개 중 2개 Nintendo 3DS Speaker Assembly Replacement: 5 단계, 이미지 3개 중 3개
    • Lift the bottom edge of the lower case off the rest of the 3DS.
    • There are still two ribbon cables connecting the mother board to the case, so be sure not to pull the lower case all the way off.
    • Use a plastic opening tool to pry the shoulder button ribbon cables off their sockets on the motherboard.
    • Remove the lower case from the device.
    댓글 쓰기
  6. Nintendo 3DS Speaker Assembly Replacement, Circle Pad Joystick: 6 단계, 이미지 1개 중 1개
    • Remove the two 7.7 mm Phillips screws securing the back of the Circle Pad to the motherboard.
    댓글 쓰기
  7. Nintendo 3DS Speaker Assembly Replacement: 7 단계, 이미지 3개 중 1개 Nintendo 3DS Speaker Assembly Replacement: 7 단계, 이미지 3개 중 2개 Nintendo 3DS Speaker Assembly Replacement: 7 단계, 이미지 3개 중 3개
    • Use the flat end of a spudger to pry the back of the Circle Pad off the motherboard.
    • Lift the Circle Pad joystick off the motherboard and lay it on its back so that the ribbon cable connector is accessible.
    댓글 쓰기
  8. Nintendo 3DS Speaker Assembly Replacement: 8 단계, 이미지 3개 중 1개 Nintendo 3DS Speaker Assembly Replacement: 8 단계, 이미지 3개 중 2개 Nintendo 3DS Speaker Assembly Replacement: 8 단계, 이미지 3개 중 3개
    • Use the flat end of a spudger or your fingernail to flip up the retaining flap on the Circle Pad ribbon cable ZIF socket.
    • Be sure you are prying up on the hinged retaining flap, not the socket itself.
    • Lift the Circle Pad joystick off the motherboard.
    댓글 쓰기
  9. Nintendo 3DS Speaker Assembly Replacement: 9 단계, 이미지 2개 중 1개 Nintendo 3DS Speaker Assembly Replacement: 9 단계, 이미지 2개 중 2개
    • To decrease the chance of losing it during repairs, you may want to remove the two thin pads underneath the Circle Pad joystick.
    • Use a spudger or screwdriver to lift the pads up and remove them from the device.
    댓글 쓰기
  10. Nintendo 3DS Speaker Assembly Replacement, SD Board: 10 단계, 이미지 1개 중 1개
    • Remove the two 4.5 mm Phillips screws securing the SD board to the motherboard.
    댓글 쓰기
  11. Nintendo 3DS Speaker Assembly Replacement: 11 단계, 이미지 2개 중 1개 Nintendo 3DS Speaker Assembly Replacement: 11 단계, 이미지 2개 중 2개
    • Use the flat end of a spudger to pry the SD board ribbon cable connector off its socket on the motherboard.
    댓글 쓰기
  12. Nintendo 3DS Speaker Assembly Replacement: 12 단계, 이미지 3개 중 1개 Nintendo 3DS Speaker Assembly Replacement: 12 단계, 이미지 3개 중 2개 Nintendo 3DS Speaker Assembly Replacement: 12 단계, 이미지 3개 중 3개
    • Insert the flat end of a spudger between the SD board and the motherboard.
    • Pry up slowly to loosen the SD board from the RF shield underneath it. If you pry too quickly, you may tear the shield or break its solder points.
    • Run the spudger along the sides of the SD board to free it from the adhesive holding it in place.
    • Once completely freed, lift the SD board straight off the motherboard.
    댓글 쓰기
  13. Nintendo 3DS Speaker Assembly Replacement, Pry the Wi-Fi card up: 13 단계, 이미지 2개 중 1개 Nintendo 3DS Speaker Assembly Replacement, Pry the Wi-Fi card up: 13 단계, 이미지 2개 중 2개
    • Slide the flat end of a spudger under the corner of the Wi-Fi board, and lift it away from the motherboard.
    • The Wi-Fi antenna cable is still connected to the Wi-Fi board, so you cannot completely remove the Wi-Fi board yet.
    댓글 쓰기
  14. Nintendo 3DS Speaker Assembly Replacement, Disconnect the Wi-Fi board: 14 단계, 이미지 3개 중 1개 Nintendo 3DS Speaker Assembly Replacement, Disconnect the Wi-Fi board: 14 단계, 이미지 3개 중 2개 Nintendo 3DS Speaker Assembly Replacement, Disconnect the Wi-Fi board: 14 단계, 이미지 3개 중 3개
    • Lift the Wi-Fi board off the motherboard and rotate it so that the bottom side is facing up.
    • Use the flat end of a spudger to pry the Wi-Fi antenna cable connector off its socket on the Wi-Fi board.
    • Remove the Wi-Fi board from the device.
    댓글 쓰기
  15. Nintendo 3DS Speaker Assembly Replacement, Motherboard Assembly: 15 단계, 이미지 2개 중 1개 Nintendo 3DS Speaker Assembly Replacement, Motherboard Assembly: 15 단계, 이미지 2개 중 2개
    이 단계에 사용된 도구:
    • Grasp the microphone ribbon cable near the microphone with a pair of tweezers.
    • Pull the microphone straight up out of the upper case.
    댓글 쓰기
  16. Nintendo 3DS Speaker Assembly Replacement: 16 단계, 이미지 3개 중 1개 Nintendo 3DS Speaker Assembly Replacement: 16 단계, 이미지 3개 중 2개 Nintendo 3DS Speaker Assembly Replacement: 16 단계, 이미지 3개 중 3개
    • Use the flat end of a spudger or your fingernail to flip up the retaining flap on the speaker assembly ribbon cable ZIF socket.
    • Be sure you are prying up on the hinged retaining flap, NOT the socket itself. Damaging the socket or cable will result in a 3DS that will blink its power LED when you press the power button - and do nothing else.
    • Disconnect the speaker assembly ribbon cable with a pair of tweezers.
    댓글 쓰기
  17. Nintendo 3DS Speaker Assembly Replacement: 17 단계, 이미지 2개 중 1개 Nintendo 3DS Speaker Assembly Replacement: 17 단계, 이미지 2개 중 2개
    • Use the flat end of a spudger or your fingernail to flip up the retaining flap on the camera ribbon cable ZIF socket.
    • When reassembling, note that the gold contacts face toward the motherboard (as opposed to the camera cable's gold contacts facing away).
    댓글 쓰기
  18. Nintendo 3DS Speaker Assembly Replacement: 18 단계, 이미지 3개 중 1개 Nintendo 3DS Speaker Assembly Replacement: 18 단계, 이미지 3개 중 2개 Nintendo 3DS Speaker Assembly Replacement: 18 단계, 이미지 3개 중 3개
    • Remove seven Phillips screws securing the motherboard to the upper case:
    • Four 2.5 mm gold screws
    • Two 3.5 mm black screws
    • One 2.5 mm silver screw
    • When you remove this screw the volume slider can fall out.
    • Lift the side of the motherboard that sits along the bottom edge of the 3DS.
    댓글 쓰기
  19. Nintendo 3DS Speaker Assembly Replacement: 19 단계, 이미지 3개 중 1개 Nintendo 3DS Speaker Assembly Replacement: 19 단계, 이미지 3개 중 2개 Nintendo 3DS Speaker Assembly Replacement: 19 단계, 이미지 3개 중 3개
    • Continue lifting the motherboard assembly and rotate it until it is resting next to the rest of the device.
    • Use the flat end of a spudger or your fingernail to flip up the retaining flap on the LCD ribbon cable ZIF socket.
    • Be sure you are prying up on the hinged retaining flap, not the socket itself. Damaging the socket or cable will result in a 3DS that won't have a functional top screen.
    댓글 쓰기
  20. Nintendo 3DS Speaker Assembly Replacement: 20 단계, 이미지 1개 중 1개
    • Remove the motherboard assembly from the rest of the device.
    댓글 쓰기
  21. Nintendo 3DS Speaker Assembly Replacement, Upper Display Front Panel: 21 단계, 이미지 1개 중 1개
    이 단계에 사용된 도구:
    • Before continuing with disassembly, use a pair of tweezers to remove the clear plastic diffuser for the wireless notification LED. The small piece is likely to fall out on its own, and may be difficult to find if it lands on the floor.
    댓글 쓰기
  22. Nintendo 3DS Speaker Assembly Replacement: 22 단계, 이미지 2개 중 1개 Nintendo 3DS Speaker Assembly Replacement: 22 단계, 이미지 2개 중 2개
    • De-route the Wi-Fi antenna cable from the bottom of the upper case.
    • This step is not necessary if you are only replacing the front panel; however, the replacement of the upper screen, speakers, cameras, and Wi-Fi antenna require it.
    댓글 쓰기
  23. Nintendo 3DS Speaker Assembly Replacement: 23 단계, 이미지 2개 중 1개 Nintendo 3DS Speaker Assembly Replacement: 23 단계, 이미지 2개 중 2개
    • Heat the edges of the upper display front panel with a hair dryer or heat gun to soften the adhesive holding it to the display bezel.
    • Begin prying the edges of the front panel off with a plastic opening tool.
    • If it is difficult to pry the front panel off, reheat the area you are working on with the heat gun, and then return to prying. Applying excessive force could crack the front panel.
    댓글 쓰기
  24. Nintendo 3DS Speaker Assembly Replacement: 24 단계, 이미지 2개 중 1개 Nintendo 3DS Speaker Assembly Replacement: 24 단계, 이미지 2개 중 2개
    • Continue prying the remaining sides of the front panel by sliding the plastic opening tool down each edge.
    • Too little heat will result in excessive bending/breaking of the front panel, and too much will melt and destroy the LCD underneath. Take your time.
    댓글 쓰기
  25. Nintendo 3DS Speaker Assembly Replacement: 25 단계, 이미지 2개 중 1개 Nintendo 3DS Speaker Assembly Replacement: 25 단계, 이미지 2개 중 2개
    • With all of the sides free, lift the upper display front panel off the display bezel.
    댓글 쓰기
  26. Nintendo 3DS Speaker Assembly Replacement, Rear Display Bezel: 26 단계, 이미지 1개 중 1개
    • Remove the six 3.6 mm Phillips screws securing the rear display bezel to the front display bezel.
    댓글 쓰기
  27. Nintendo 3DS Speaker Assembly Replacement: 27 단계, 이미지 2개 중 1개 Nintendo 3DS Speaker Assembly Replacement: 27 단계, 이미지 2개 중 2개
    • Flip the device over so that the rear display bezel is on top and the hinge is on the side opposite from you.
    • Lift the edge of the rear display bezel closest to you and rotate it towards the hinge.
    • Continue to lift the rear display bezel off the rest of the device until it is free.
    • There are clips toward the bottom of the rear display bezel holding it in place. Use enough force to disengage the clips, but be careful not to break them.
    댓글 쓰기
  28. Nintendo 3DS Speaker Assembly Replacement, Upper Display Assembly: 28 단계, 이미지 1개 중 1개
    • Remove the 3D adjustment switch from the front display bezel.
    • This step is not necessary for disassembly, but the switch is likely to fall out on its own. By removing it yourself, you reduce the chance of losing it.
    댓글 쓰기
  29. Nintendo 3DS Speaker Assembly Replacement: 29 단계, 이미지 3개 중 1개 Nintendo 3DS Speaker Assembly Replacement: 29 단계, 이미지 3개 중 2개 Nintendo 3DS Speaker Assembly Replacement: 29 단계, 이미지 3개 중 3개
    • Insert a metal probe into the space above the ABXY buttons with the point touching the metal hinge.
    • Push the hinge towards the center of the upper case. This will require a fair amount of force.
    • Before and after images of the hinge location when looking at the back of the upper display are shown.
    댓글 쓰기
  30. Nintendo 3DS Speaker Assembly Replacement: 30 단계, 이미지 3개 중 1개 Nintendo 3DS Speaker Assembly Replacement: 30 단계, 이미지 3개 중 2개 Nintendo 3DS Speaker Assembly Replacement: 30 단계, 이미지 3개 중 3개
    • Before proceeding, note how the 3 ribbon cables are oriented (what direction the gold contacts face) and layered together (which cable is on top of which). The cables are too short to reach if they are threaded through in any other orientation.
    • Slowly pull the upper display assembly away from the upper case.
    • Make sure that the various ribbon cables are being fed through the slit in the upper case.
    • Separate the upper display assembly from the upper case.
    댓글 쓰기
  31. Nintendo 3DS Speaker Assembly Replacement, Speaker Assembly: 31 단계, 이미지 2개 중 1개 Nintendo 3DS Speaker Assembly Replacement, Speaker Assembly: 31 단계, 이미지 2개 중 2개
    • Carefully feed the speaker assembly ribbon cable through the hole in the upper display bezel.
    • You must gently coil the ribbon cables (similar to an ice-cream cone) to allow them to fit - the cables are wider than the hole.
    댓글 쓰기
  32. Nintendo 3DS Speaker Assembly Replacement: 32 단계, 이미지 1개 중 1개
    • Remove the 2.5 mm Phillips screw securing the right speaker board to the upper display bezel.
    댓글 쓰기
  33. Nintendo 3DS Speaker Assembly Replacement: 33 단계, 이미지 3개 중 1개 Nintendo 3DS Speaker Assembly Replacement: 33 단계, 이미지 3개 중 2개 Nintendo 3DS Speaker Assembly Replacement: 33 단계, 이미지 3개 중 3개
    이 단계에 사용된 도구:
    • Use the flat end of a spudger or your fingernail to flip up the retaining flaps on the parallax barrier ribbon cable ZIF sockets.
    • Use a pair of metal tweezers to disconnect the two ribbon cables.
    댓글 쓰기
  34. Nintendo 3DS Speaker Assembly Replacement: 34 단계, 이미지 3개 중 1개 Nintendo 3DS Speaker Assembly Replacement: 34 단계, 이미지 3개 중 2개 Nintendo 3DS Speaker Assembly Replacement: 34 단계, 이미지 3개 중 3개
    • Use the flat end of a spudger to pry the left and right speakers out of their places in the upper display bezel.
    • Pry the camera status LED out of the upper display bezel with the tip of a spudger.
    댓글 쓰기
  35. Nintendo 3DS Speaker Assembly Replacement: 35 단계, 이미지 1개 중 1개
    • Remove the speaker assembly from the rest of the display assembly.
    댓글 쓰기
결론
취소: 해당 안내서를 완성하지 않았습니다.
다른 27명이 해당 안내서를 완성하였습니다.
작성자
5다른 기여자 명과 함께
David Hodson
회원 가입일: 04/13/10
156,367 평판
안내서 127개를 작성함
6가이드 댓글
Getting the new assembly ribbon cable through the hinge is excruciatingly tedious. I tore my cable when I tried fishing it through with a small hooked pry tool. Learn from my mistakes
Ellie Horne - 답글 공유
Whatever you do, don’t accidentally hook the display ribbon cable into the slot for the speaker ribbon cable when reassembling. It holds it too firmly, and will rip easily. I now have to spend $15 on a new lcd ribbon cable.
Juicy Fruit - 답글 공유
I bought a new speaker cable to replace on my sons 3ds. I’m in sure oh to connect the speakers to the new cable. Any help? Or are there any places out there that I can send it to get it fix?
laura1402 - 답글 공유
This can be fix the error of the 3d screen comprovetion? i have a 3ds with that problem, any advice?
kosmosalfa - 답글 공유
For reassembly: when trying to put the ribbon cable through the hinge, you need to curve the end a bit to make it ‘flush’ with the hinge. I would also reccomend pulling the black hinge part out and lace the ribbon cable throught that way, then lace it through the hinge part, and then put the black hinge part back in the hinge socket.
Electronik - 답글 공유
댓글 쓰기
조회 통계:
지난 24시간: 23
지난 7일: 126
지난 30일: 644
전체 시간: 76,019
