주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Nintendo 3DS XL Microphone Replacement
필요한 것
  1. Nintendo 3DS XL Microphone Replacement, Remove the back cover screws: 1 단계, 이미지 1개 중 1개
    • Use a JIS 00 screwdriver to loosen the 4.2 mm‑long screws on the top edge of the back cover.
    • The screws have locking washers that prevent the screws from falling out. Keep these in place.
    댓글 쓰기
  2. Nintendo 3DS XL Microphone Replacement, Remove the back cover: 2 단계, 이미지 2개 중 1개 Nintendo 3DS XL Microphone Replacement, Remove the back cover: 2 단계, 이미지 2개 중 2개
    • Use a plastic opening tool to pry off the clips securing the back cover, starting at the top corners and working your way down.
    • Use your hands to keep the clips from reattaching.
    • Use your hands to remove the back cover.
    댓글 쓰기
  3. Nintendo 3DS XL Microphone Replacement: 3 단계, 이미지 3개 중 1개 Nintendo 3DS XL Microphone Replacement: 3 단계, 이미지 3개 중 2개 Nintendo 3DS XL Microphone Replacement: 3 단계, 이미지 3개 중 3개
    • Insert the plastic opening tool into the opening located on the right side of the battery.
    • Pry the battery out of its recess and remove it.
    댓글 쓰기
  4. Nintendo 3DS XL Microphone Replacement, Microphone: 4 단계, 이미지 2개 중 1개 Nintendo 3DS XL Microphone Replacement, Microphone: 4 단계, 이미지 2개 중 2개
    이 단계에 사용된 도구:
    • Using tweezers pull out the rubber bumpers that are located at the top of the device on either side of the game cartridge compartment.
    댓글 쓰기
  5. Nintendo 3DS XL Microphone Replacement: 5 단계, 이미지 2개 중 1개 Nintendo 3DS XL Microphone Replacement: 5 단계, 이미지 2개 중 2개
    • Remove the six 6.2 mm screws using a Phillips #000 screwdriver.
    댓글 쓰기
  6. Nintendo 3DS XL Microphone Replacement: 6 단계, 이미지 1개 중 1개
    • Remove the 2.3 mm screw located above the game cartridge slot with a Phillips #000 screwdriver.
    댓글 쓰기
  7. Nintendo 3DS XL Microphone Replacement: 7 단계, 이미지 3개 중 1개 Nintendo 3DS XL Microphone Replacement: 7 단계, 이미지 3개 중 2개 Nintendo 3DS XL Microphone Replacement: 7 단계, 이미지 3개 중 3개
    • With a plastic opening tool pry off the lower case starting at the bottom edge and working around the perimeter.
    • Two ribbon cables connect the case to the circuit board. Be careful to not pull the case too hard and rip the ribbon cables.
    댓글 쓰기
  8. Nintendo 3DS XL Microphone Replacement: 8 단계, 이미지 3개 중 1개 Nintendo 3DS XL Microphone Replacement: 8 단계, 이미지 3개 중 2개 Nintendo 3DS XL Microphone Replacement: 8 단계, 이미지 3개 중 3개
    • Remove the ribbon cables located underneath the left and right bumpers by prying up the base of the cables with a plastic opening tool.
    • Completely remove the lower case from the rest of the device and set aside.
    댓글 쓰기
  9. Nintendo 3DS XL Microphone Replacement: 9 단계, 이미지 3개 중 1개 Nintendo 3DS XL Microphone Replacement: 9 단계, 이미지 3개 중 2개 Nintendo 3DS XL Microphone Replacement: 9 단계, 이미지 3개 중 3개
    • Position the device such that the game cartridge slot is located at the top.
    • Locate the microphone in the bottom left corner.
    • Using tweezers remove the microphone.
    • There will be a ribbon that connects the microphone to the motherboard.
    댓글 쓰기
  10. Nintendo 3DS XL Microphone Replacement: 10 단계, 이미지 2개 중 1개 Nintendo 3DS XL Microphone Replacement: 10 단계, 이미지 2개 중 2개
    • Using the flat head side of the spudger carefully lift up the flap and remove the ribbon.
    • The attached microphone can now be removed.
    댓글 쓰기
결론
취소: 해당 안내서를 완성하지 않았습니다.
다른 6명이 해당 안내서를 완성하였습니다.
작성자
5다른 기여자 명과 함께
Charlene Donlon
회원 가입일: 04/08/14
11,225 평판
안내서 8개를 작성함
Cal Poly, Team 9-13, Regan Spring 2014 Cal Poly, Team 9-13, Regan Spring 2014 회원
CPSU-REGAN-S14S9G13
5 회원들
안내서 56개를 작성함
2가이드 댓글
Hello! Do these instructions apply to the New 3DS XL as well? I followed steps from 1-8, but when I get to step 9, the layout is different and I can’t find the mic. Any help would be greatly appreciated!
Melissa Cardenas - 답글 공유
please learn to repair the mic of new 3ds xl
andrew.hws - 답글 공유
댓글 쓰기
조회 통계:
지난 24시간: 3
지난 7일: 35
지난 30일: 153
전체 시간: 15,777
